[PATCH 6/9] fsdosfsname01: Add multibyte tests
Ralf Kirchner ralf.kirchner at embedded-brains.de
Fri May 31 13:42:22 UTC 2013
Test handling of file names and directory names according to Microsofts specification
for the FAT file system. Tests for multibyte file names and directory names have been added.
 testsuites/fstests/fsdosfsname01/fsdosfsname01.doc |    1 +
 testsuites/fstests/fsdosfsname01/init.c            |  286 +++++++++++++++++++-
 2 Dateien geändert, 286 Zeilen hinzugefügt(+), 1 Zeile entfernt(-)
diff --git a/testsuites/fstests/fsdosfsname01/fsdosfsname01.doc b/testsuites/fstests/fsdosfsname01/fsdosfsname01.doc
index adf11d3..7751067 100644
--- a/testsuites/fstests/fsdosfsname01/fsdosfsname01.doc
+++ b/testsuites/fstests/fsdosfsname01/fsdosfsname01.doc
@@ -16,3 +16,4 @@ directives:
 concepts:
 - Make sure short file- and directory names and long file- and directory names are handled correctly for the default character set (code page 850)
+- Make sure multibyte file names and directory names are handled correctly
diff --git a/testsuites/fstests/fsdosfsname01/init.c b/testsuites/fstests/fsdosfsname01/init.c
index 260d955..0ff8ce8 100644
--- a/testsuites/fstests/fsdosfsname01/init.c
+++ b/testsuites/fstests/fsdosfsname01/init.c
@@ -37,7 +37,9 @@
 #define NUMBER_OF_FILES 13
 #define NUMBER_OF_DIRECTORIES_INVALID 18
 #define NUMBER_OF_DIRECTORIES_DUPLICATED 2
+#define NUMBER_OF_MULTIBYTE_NAMES_DUPLICATED 2
 #define NUMBER_OF_FILES_DUPLICATED 2
+#define NUMBER_OF_NAMES_MULTIBYTE 10
 #define MAX_NAME_LENGTH ( 255 + 1 )
 #define MAX_NAME_LENGTH_INVALID ( 255 + 2 )
 #define MAX_DUPLICATES_PER_NAME 3
@@ -96,6 +98,34 @@ static const char DIRECTORY_NAMES_INVALID[
   {127}
+static const char NAMES_MULTIBYTE[
+  NUMBER_OF_NAMES_MULTIBYTE][MAX_NAME_LENGTH] = {
+  "đây là một tên tập tin dài",
+  "Bu uzun bir dosya adı",
+  "هذا هو اسم ملف طويل",
+  "αυτό είναι ένα μεγάλο όνομα αρχείου",
+  "это длинное имя",
+  "гэта доўгае імя",
+  "това е дълго име на файла",
+  "这是一个长文件名",
+  "shrtname",
+  "long_conventional_name"
+static const char NAMES_MULTIBYTE_IN_CODEPAGE_FORMAT[
+  "_\2030005~1._t",
+  "bu0008~1.bir",
+  "__000b~1.__",
+  "__000f~1.__",
+  "__0012~1.___",
+  "__0015~1.___",
+  "__0018~1.___",
+  "__001a~1",
+  "shrtname",
 static const char FILE_NAMES[NUMBER_OF_FILES][
   "a file",
@@ -168,6 +198,7 @@ static const name_duplicates MULTIBYTE_DUPLICATES[
 static const name_duplicates FILES_DUPLICATES[NUMBER_OF_FILES_DUPLICATED] = {
     "shrtfile",
@@ -265,6 +296,22 @@ static void mount_device_with_defaults( const char *start_dir )
   mount_device( start_dir, NULL );
+static void mount_device_with_iconv( const char *start_dir )
+  int                       rc;
+  rtems_dosfs_mount_options mount_opts;
+  rc = msdos_format( RAMDISK_PATH, &rqdata );
+  rtems_test_assert( rc == 0 );
+  rtems_resource_snapshot_take( &before_mount );
+  mount_opts.string_opts = rtems_dosfs_string_options_init_utf8( "CP850" );
+  mount_device( start_dir, &mount_opts );
 static void unmount_and_close_device( void )
   int                     rc;
@@ -429,6 +476,68 @@ static void test_handling_files(
+ * Try to find (and open) all of the file names from an
+ * array in a given directory
+static void test_finding_files(
+  const char        *dirname,
+  const char        *file_names,
+  const unsigned int number_of_files )
+  int            rc;
+  DIR           *dir_stream;
+  struct dirent *dp;
+  int            fd;
+  unsigned int   index_file;
+  char           filename[MAX_NAME_LENGTH * 2 + MOUNT_DIR_SIZE
+                          + START_DIR_SIZE + 4];
+  dir_stream = opendir( dirname );
+  rtems_test_assert( dir_stream != NULL );
+  dp = readdir( dir_stream );
+  rtems_test_assert( dp != NULL );
+  rtems_test_assert( 0 == strcmp( ".", dp->d_name ) );
+  rtems_test_assert( 0 == strcmp( "..", dp->d_name ) );
+  index_file = 0;
+  while ( dp != NULL ) {
+                         file_names + index_file * MAX_NAME_LENGTH,
+                         dp->d_name ) );
+    snprintf(
+      filename,
+      sizeof( filename ) - 1,
+      "%s/%s",
+      dirname,
+      file_names + index_file * MAX_NAME_LENGTH );
+    /* See if the file still exists and can be found */
+    fd = open( filename, O_RDWR );
+    rtems_test_assert( fd >= 0 );
+    rc = close( fd );
+    ++index_file;
+  rtems_test_assert( number_of_files == index_file );
+  rc = closedir( dir_stream );
  * Try opening files which do already exist (with different capitalization in their names)
 static void test_duplicated_files( const char *dirname,
@@ -541,6 +650,68 @@ static void test_handling_directories(
+ * Try to find all sub-directories from an array
+ * in a given start directory.
+ * In addition try to find and open files
+ * in these sub-directories.
+static void test_finding_directories(
+  const char        *start_dir,
+  const char        *directory_names,
+  const unsigned int number_of_directories,
+  unsigned int   index_directory;
+  int            rc;
+  DIR           *dir_stream;
+  char           dirname[MAX_NAME_LENGTH * 2];
+  dir_stream = opendir( start_dir );
+  index_directory = 0;
+                         directory_names + index_directory * MAX_NAME_LENGTH,
+                         dp->d_name ) );
+    snprintf(
+      dirname,
+      sizeof( dirname ) - 1,
+      "%s/%s",
+      start_dir,
+      directory_names + index_directory * MAX_NAME_LENGTH );
+    test_finding_files(
+      dirname,
+      file_names,
+      number_of_files );
+    ++index_directory;
+  rtems_test_assert( number_of_directories == index_directory );
  * Main test method
 static void test( void )
@@ -548,7 +719,6 @@ static void test( void )
   int  rc;
   char start_dir[MOUNT_DIR_SIZE + START_DIR_SIZE + 2];
   rc = mkdir( MOUNT_DIR, S_IRWXU | S_IRWXG | S_IRWXO );
@@ -595,6 +765,120 @@ static void test( void )
     &FILE_NAMES[0][0],
     NUMBER_OF_FILES );
+  rc = unmount( MOUNT_DIR );
+   * Again tests with code page 850 compatible directory and file names
+   * but with multibyte string compatible conversion methods which use
+   * iconv and utf8proc
+  rc                     = mount(
+    RAMDISK_PATH,
+    MOUNT_DIR,
+    "dosfs",
+    RTEMS_FILESYSTEM_READ_WRITE,
+    &mount_opts );
+  test_finding_directories(
+    &start_dir[0],
+    &DIRECTORY_NAMES[0][0],
+    NUMBER_OF_DIRECTORIES,
+    &FILE_NAMES[0][0],
+    NUMBER_OF_FILES );
+  unmount_and_close_device();
+  mount_device_with_iconv( start_dir );
+  test_creating_invalid_directories();
+  test_creating_directories(
+    &start_dir[0],
+    NUMBER_OF_DIRECTORIES );
+  test_handling_directories(
+    &start_dir[0],
+  test_creating_duplicate_directories(
+    &start_dir[0],
+    &DIRECTORY_DUPLICATES[0],
+    NUMBER_OF_DIRECTORIES_DUPLICATED );
+  test_duplicated_files(
+    MOUNT_DIR,
+    FILES_DUPLICATES,
+    NUMBER_OF_FILES_DUPLICATED );
+   * Tests with multibyte directory and file names and
+   * with multibyte string compatible conversion methods which use
+    &start_dir[0],
+    &MULTIBYTE_DUPLICATES[0],
+    NUMBER_OF_MULTIBYTE_NAMES_DUPLICATED );
+    MOUNT_DIR,
+    &start_dir[0],
+    &NAMES_MULTIBYTE[0][0],
+    NUMBER_OF_NAMES_MULTIBYTE );
+    &start_dir[0],
+    NUMBER_OF_NAMES_MULTIBYTE,
+  rc = mount(
+    RAMDISK_PATH,
+    MOUNT_DIR,
+    "dosfs",
+    NULL );
+    &start_dir[0],
+    &NAMES_MULTIBYTE_IN_CODEPAGE_FORMAT[0][0],
   del_ramdisk();
1.7.10.4
