[rtems commit] bsps/arm: Add SMP support
Fri May 31 14:51:44 UTC 2013
Hello Joel,
On 05/31/2013 03:31 PM, Joel Sherrill wrote:
> Just a note that I added an argument to the sim-scripts
> framework for number of cores.  I didn't do more than
> check that it appeared to work.
> It would be appreciated if you could follow what I did
> in pc386.in and make similar changes to the realview
> support file. Then we will know if I got it right.
I checked in a new support script "sim-scripts/realview_pbx_a9_qemu_smp".  I
moved the default of ${number_of_cores} to the BSP specific script part.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
