[PATCH 1/9] dosfs: UTF-8 Support: UI, backwards compatibility
Fri May 31 15:00:09 UTC 2013
On 05/31/2013 04:47 PM, Gedare Bloom wrote:
> On Fri, May 31, 2013 at 9:42 AM, Ralf Kirchner
> <ralf.kirchner at embedded-brains.de>  wrote:
>> >@@ -25,6 +28,170 @@
>> >  extern "C" {
>> >  #endif
>> >+typedef struct rtems_dosfs_convert_control rtems_dosfs_convert_control;
> I think it is usual to put the struct definition before the function
> prototypes in header files. I don't know if we have any rule about it
> though.
Its the first declaration in the file, so it is before the function prototypes.
>> >@@ -131,6 +309,9 @@ int msdos_format (
>> >+int rtems_dosfs_initialize(rtems_filesystem_mount_table_entry_t *mt_entry,
>> >+                           const void                           *data);
> Can you give doxygen for this function now too? I know it did not have
> it, but it might be helpful.
Its explicitly outside of the Doxygen group, because this function is not part
of the public interface.
>> >+    rtems_dosfs_convert_control      *converter;
>> >  } msdos_fs_info_t;
> Please add a comment about the converter field.
> Why no doxygen comments for these new functions?
All this stuff is not part of the public interface.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
