BSP for Sterallis Launchpad LM4F120
saket sinha saket.sinha89 at gmail.com
Wed May 1 15:41:02 UTC 2013
Dear Sir,
         Thank you for the response.
>>Great! Please go through our GSoC Getting Started [1], add yourself to
>>the table of student proposals [2], and start your official proposal
>>application in Melange [3].
        I am doing that only. All this wont take much time. The important
part is to discuss with you whether my project is feasible or not.
>>What is the processor architecture and CPU family?
ARM® Cortex™-M4 microcontroller from Texas Instruments.
>>Is the architecture and CPU already supported in RTEMS?
I have seen on RTEMS Wiki that BSP for Steraliis ARM® Cortex™-M3 has been
implemented but the new family M4 has not been .
>> If not, what is the effort need to port the architecture/CPU?
   This is what I need to discuss.
>>Does gcc support it?
Yes.
>>Is there a simulator that can be used to develop and test your code?
QEMU
>>Are there similar BSPs already that exist in RTEMS for you to derive
>>your BSP from?
Yes sir BSP with RTEMS support for Sterallis ARM Cortex M3 family has
already been implemented and is avilable on RTEMS wiki.
>>What peripherals and devices are available on the board for which
>>you will write drivers?
GPIO, UART, SPI, I2C etc.
Kindly guide me for the same.
Regards,
Saket Sinha
> For the specific project you are interested in, we need to identify
> whether this is a feasible and useful project. For this we first need
> to know more about the board/platform.
> * What is the processor architecture and CPU family?
> * Is the architecture and CPU already supported in RTEMS?
> ** If not, what is the effort need to port the architecture/CPU? Does
> gcc support it?
> * Is there a simulator that can be used to develop and test your code?
> * Are there similar BSPs already that exist in RTEMS for you to derive
> your BSP from?
> * What peripherals and devices are available on the board for which
> You may need to dig a little to find answers to some of these
> questions, and ask for help if you get lost or confused. A bare BSP
> with console and clock for a supported CPU is often quite simple, so
> adding additional features to the project in such a case may be
> necessary to have a compelling proposal.
> [1] http://wiki.rtems.org/wiki/index.php/GSoC_Getting_Started
> [2]
> http://wiki.rtems.org/wiki/index.php/RTEMSSummerOfCode#Students_Proposals
> [3] http://www.google-melange.com/gsoc/org/google/gsoc2013/rtems
> -Gedare
> On Wed, May 1, 2013 at 11:10 AM, saket sinha <saket.sinha89 at gmail.com>
> wrote:
> > Dear Sir,
> >      I am interested in applying in GSOC 2013 with  the project idea "BSP
> > for Sterallis Launchpad LM4F120 ".
> > Regards,
> > Saket Sinha
> > rtems-devel mailing list
> > rtems-devel at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130501/46db77b6/attachment-0001.html>
