[PATCH] ZYNQ BSP
Michal Simek
monstr at monstr.eu
Fri May 3 17:55:59 UTC 2013
Hi Sebastian,
Do you use mainline qemu (target realview-pbx-a9)?
What's your qemu command line for running it?
Thanks,
Michal
On 05/03/2013 05:44 PM, Sebastian Huber wrote:
> Hello Claus,
> I added a new BSP with Cortex-A9 MPCore support:
> http://git.rtems.org/rtems/commit/?id=a91dc98b5ad5ee9bc8d592c62753a467daf4e711
> It should be possible to use the MMU, cache, GIC and PT (Cortex-A9 MPCore Private Timer) support also for the Zync BSP.
> With that we only have to add a console driver to get a basic BSP.
> There is Qemu support for the Zync. It is desirable that this BSP runs on the simulator to test it.
Michal Simek, Ing. (M.Eng), OpenPGP -> KeyID: FE3D1F91
w: www.monstr.eu p: +42-0-721842854
Maintainer of Linux kernel - Microblaze cpu - http://www.monstr.eu/fdt/
Maintainer of Linux kernel - Xilinx Zynq ARM architecture
Microblaze U-BOOT custodian and responsible for u-boot arm zynq platform
Type: application/pgp-signature
Desc: OpenPGP digital signature
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130503/e8c2b956/attachment-0001.bin>
