RTEMS Scheduler Simulator Status Update
Joel Sherrill
joel.sherrill at OARcorp.com
Sat May 4 14:01:47 UTC 2013
On 5/3/2013 9:18 PM, yangwei weiyang wrote:
> Hi
> When i build the scheduler-sim it encountered some error:
> weiy at WeiY-host:/project/weiy/gsoc2013/rtems-schedsim$ autoconf
> configure.ac:18 <http://configure.ac:18>: error: possibly undefined
> macro: AM_INIT_AUTOMAKE
> If this token and others are legitimate, please use
> m4_pattern_allow.
> See the Autoconf documentation.
> configure.ac:19 <http://configure.ac:19>: error: possibly undefined
> macro: AM_MAINTAINER_MODE
You need to run the bootstrap script found at the top of the main
RTEMS source tree.
rtems-schedsim avoids duplicating files from the main source tree.
Can you build the RTEMS head? rtems-schedsim uses the same version
of autoconf and automake.
> Is there any reference about how to configure and build the schedsim.
There is a readme at the top of the source tree.
> 2013/5/2 Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>>
> Hi
> I just wanted to pass along that the RTEMS Scheduler
> Simulator is now updated and appears to be working
> great with the current RTEMS source. The git is:
> git://git.rtems.org/rtems-schedsim.git
> <http://git.rtems.org/rtems-schedsim.git>
> I also updated the wiki page:
> http://wiki.rtems.org/wiki/index.php/SuperCore_Scheduler#Scheduler_Simulator
> This should be of use to at least two GSOC proposals.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> rtems-devel mailing list
> rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
> Wei Yang
> Best Regards
> wei.a.yang at gmail.com <http://gmail.com>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130504/d7907651/attachment-0001.html>
