[PATCH 2/4] score: Add CPU context validation
Sebastian Huber
Wed May 8 09:48:53 UTC 2013
cpukit/score/cpu/arm/Makefile.am | 2 +
cpukit/score/cpu/arm/arm-context-validate.S | 139 +++++++++++
.../score/cpu/arm/arm-context-volatile-clobber.S | 37 +++
cpukit/score/cpu/arm/rtems/score/cpu.h | 4 +
cpukit/score/cpu/avr/rtems/score/cpu.h | 12 +
cpukit/score/cpu/bfin/rtems/score/cpu.h | 12 +
cpukit/score/cpu/h8300/rtems/score/cpu.h | 12 +
cpukit/score/cpu/i386/rtems/score/cpu.h | 12 +
cpukit/score/cpu/lm32/rtems/score/cpu.h | 12 +
cpukit/score/cpu/m32c/rtems/score/cpu.h | 12 +
cpukit/score/cpu/m32r/rtems/score/cpu.h | 12 +
cpukit/score/cpu/m68k/rtems/score/cpu.h | 12 +
cpukit/score/cpu/mips/rtems/score/cpu.h | 12 +
cpukit/score/cpu/moxie/rtems/score/cpu.h | 12 +
cpukit/score/cpu/nios2/Makefile.am | 2 +
cpukit/score/cpu/nios2/nios2-context-validate.S | 146 +++++++++++
.../cpu/nios2/nios2-context-volatile-clobber.S | 42 +++
cpukit/score/cpu/nios2/rtems/score/cpu.h | 4 +
cpukit/score/cpu/no_cpu/rtems/score/cpu.h | 27 ++
cpukit/score/cpu/powerpc/Makefile.am | 2 +
cpukit/score/cpu/powerpc/ppc-context-validate.S | 263 ++++++++++++++++++++
.../cpu/powerpc/ppc-context-volatile-clobber.S | 45 ++++
cpukit/score/cpu/powerpc/rtems/score/cpu.h | 4 +
cpukit/score/cpu/sh/rtems/score/cpu.h | 12 +
cpukit/score/cpu/sparc/rtems/score/cpu.h | 12 +
cpukit/score/cpu/sparc64/rtems/score/cpu.h | 12 +
cpukit/score/cpu/v850/rtems/score/cpu.h | 12 +
testsuites/sptests/Makefile.am | 1 +
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/spcontext01/Makefile.am | 19 ++
testsuites/sptests/spcontext01/init.c | 188 ++++++++++++++
testsuites/sptests/spcontext01/spcontext01.doc | 11 +
testsuites/sptests/spcontext01/spcontext01.scn | 2 +
33 files changed, 1107 insertions(+), 0 deletions(-)
create mode 100644 cpukit/score/cpu/arm/arm-context-validate.S
create mode 100644 cpukit/score/cpu/arm/arm-context-volatile-clobber.S
create mode 100644 cpukit/score/cpu/nios2/nios2-context-validate.S
create mode 100644 cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S
create mode 100644 cpukit/score/cpu/powerpc/ppc-context-validate.S
create mode 100644 cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S
create mode 100644 testsuites/sptests/spcontext01/Makefile.am
create mode 100644 testsuites/sptests/spcontext01/init.c
create mode 100644 testsuites/sptests/spcontext01/spcontext01.doc
create mode 100644 testsuites/sptests/spcontext01/spcontext01.scn
diff --git a/cpukit/score/cpu/arm/Makefile.am b/cpukit/score/cpu/arm/Makefile.am
index 61a278b..37ab901 100644
--- a/cpukit/score/cpu/arm/Makefile.am
+++ b/cpukit/score/cpu/arm/Makefile.am
@@ -16,6 +16,8 @@ libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
libscorecpu_a_SOURCES =
libscorecpu_a_SOURCES += cpu.c
libscorecpu_a_SOURCES += cpu_asm.S
+libscorecpu_a_SOURCES += arm-context-validate.S
+libscorecpu_a_SOURCES += arm-context-volatile-clobber.S
libscorecpu_a_SOURCES += arm_exc_abort.S
libscorecpu_a_SOURCES += arm_exc_interrupt.S
libscorecpu_a_SOURCES += arm_exc_handler_low.S
diff --git a/cpukit/score/cpu/arm/arm-context-validate.S b/cpukit/score/cpu/arm/arm-context-validate.S
new file mode 100644
index 0000000..4591d20
--- /dev/null
+++ b/cpukit/score/cpu/arm/arm-context-validate.S
@@ -0,0 +1,139 @@
+ * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/asm.h>
+#define FRAME_OFFSET_R4 0
+#define FRAME_OFFSET_R5 4
+#define FRAME_OFFSET_R6 8
+#define FRAME_OFFSET_R7 12
+#define FRAME_OFFSET_R8 16
+#define FRAME_OFFSET_R9 20
+#define FRAME_OFFSET_R10 24
+#define FRAME_OFFSET_R11 28
+#define FRAME_OFFSET_LR 32
+#define FRAME_SIZE (FRAME_OFFSET_LR + 4)
+ .section .text
+FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
+ /* Save */
+ sub sp, sp, #FRAME_SIZE
+ mov r1, r4
+ str r1, [sp, #FRAME_OFFSET_R4]
+ mov r1, r5
+ str r1, [sp, #FRAME_OFFSET_R5]
+ mov r1, r6
+ str r1, [sp, #FRAME_OFFSET_R6]
+ mov r1, r7
+ str r1, [sp, #FRAME_OFFSET_R7]
+ mov r1, r8
+ str r1, [sp, #FRAME_OFFSET_R8]
+ mov r1, r9
+ str r1, [sp, #FRAME_OFFSET_R9]
+ mov r1, r10
+ str r1, [sp, #FRAME_OFFSET_R10]
+ mov r1, r11
+ str r1, [sp, #FRAME_OFFSET_R11]
+ mov r1, lr
+ str r1, [sp, #FRAME_OFFSET_LR]
+ /* Fill */
+ /* R1 is used for temporary values */
+ mov r1, r0
+ /* R2 contains the stack pointer */
+ mov r2, sp
+.macro fill_register reg
+ add r1, r1, #1
+ mov \reg, r1
+.endm
+ fill_register r3
+ fill_register r4
+ fill_register r5
+ fill_register r6
+ fill_register r7
+ fill_register r8
+ fill_register r9
+ fill_register r10
+ fill_register r11
+ fill_register r12
+ fill_register lr
+ /* Check */
+check:
+.macro check_register reg
+ add r1, r1, #1
+ cmp \reg, r1
+ bne restore
+.endm
+ cmp r2, sp
+ bne restore
+ mov r1, r0
+ check_register r3
+ check_register r4
+ check_register r5
+ check_register r6
+ check_register r7
+ check_register r8
+ check_register r9
+ check_register r10
+ check_register r11
+ check_register r12
+ check_register lr
+ b check
+ /* Restore */
+restore:
+ ldr r1, [sp, #FRAME_OFFSET_R4]
+ mov r4, r1
+ ldr r1, [sp, #FRAME_OFFSET_R5]
+ mov r5, r1
+ ldr r1, [sp, #FRAME_OFFSET_R6]
+ mov r6, r1
+ ldr r1, [sp, #FRAME_OFFSET_R7]
+ mov r7, r1
+ ldr r1, [sp, #FRAME_OFFSET_R8]
+ mov r8, r1
+ ldr r1, [sp, #FRAME_OFFSET_R9]
+ mov r9, r1
+ ldr r1, [sp, #FRAME_OFFSET_R10]
+ mov r10, r1
+ ldr r1, [sp, #FRAME_OFFSET_R11]
+ mov r11, r1
+ ldr r1, [sp, #FRAME_OFFSET_LR]
+ mov lr, r1
+ add sp, sp, #FRAME_SIZE
+ bx lr
+FUNCTION_END(_CPU_Context_validate)
diff --git a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
index 0000000..b79e570
--- /dev/null
+++ b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
@@ -0,0 +1,37 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+ .section .text
+FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
+.macro clobber_register reg
+ sub r0, r0, #1
+ mov \reg, r0
+.endm
+ clobber_register r1
+ clobber_register r2
+ clobber_register r3
+ clobber_register r12
+ bx lr
+FUNCTION_END(_CPU_Context_volatile_clobber)
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index 5ed6b9b..b6f39ac 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -423,6 +423,10 @@ void _CPU_Context_save_fp( Context_Control_fp **fp_context_ptr );
void _CPU_Context_restore_fp( Context_Control_fp **fp_context_ptr );
+void _CPU_Context_volatile_clobber( uintptr_t pattern );
+void _CPU_Context_validate( uintptr_t pattern );
static inline uint32_t CPU_swap_u32( uint32_t value )
#if defined(__thumb2__)
diff --git a/cpukit/score/cpu/avr/rtems/score/cpu.h b/cpukit/score/cpu/avr/rtems/score/cpu.h
index 5f1577a..080f387 100644
--- a/cpukit/score/cpu/avr/rtems/score/cpu.h
+++ b/cpukit/score/cpu/avr/rtems/score/cpu.h
@@ -1114,6 +1114,18 @@ void _CPU_Context_restore_fp(
+static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
+ /* TODO */
+static inline void _CPU_Context_validate( uintptr_t pattern )
+ while (1) {
+ /* TODO */
/* FIXME */
typedef CPU_Interrupt_frame CPU_Exception_frame;
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index 1b26527..aba01e9 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -1213,6 +1213,18 @@ void _CPU_Context_restore_fp(
+ /* TODO */
+ while (1) {
+ /* TODO */
/* FIXME */
diff --git a/cpukit/score/cpu/h8300/rtems/score/cpu.h b/cpukit/score/cpu/h8300/rtems/score/cpu.h
index 6031f96..ea0ee7c 100644
--- a/cpukit/score/cpu/h8300/rtems/score/cpu.h
+++ b/cpukit/score/cpu/h8300/rtems/score/cpu.h
@@ -1097,6 +1097,18 @@ void _CPU_Context_restore_fp(
+ /* TODO */
+ while (1) {
+ /* TODO */
/* FIXME */
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 6667604..6a19fb1 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -667,6 +667,18 @@ void _CPU_Context_restore_fp(
} while (0)
#endif
+ /* TODO */
+ while (1) {
+ /* TODO */
void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
#endif /* ASM */
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index 1f8a370..eef9ac8 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
@@ -1202,6 +1202,18 @@ void _CPU_Context_restore_fp(
+ /* TODO */
+ while (1) {
+ /* TODO */
/* FIXME */
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index 8d9acc3..ccb9e38 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -1153,6 +1153,18 @@ void _CPU_Context_restore(
Context_Control *new_context
) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
+ /* TODO */
+ while (1) {
+ /* TODO */
/* FIXME */
diff --git a/cpukit/score/cpu/m32r/rtems/score/cpu.h b/cpukit/score/cpu/m32r/rtems/score/cpu.h
index 8c8a9c1..2c97ddb 100644
--- a/cpukit/score/cpu/m32r/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32r/rtems/score/cpu.h
@@ -1194,6 +1194,18 @@ void _CPU_Context_restore_fp(
+ /* TODO */
+ while (1) {
+ /* TODO */
/* FIXME */
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 0f244e1..2af5be8 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -711,6 +711,18 @@ void _CPU_Context_restore_fp(
+ /* TODO */
+ while (1) {
+ /* TODO */
* This method prints the CPU exception frame.
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index 130c960..229490b 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -1125,6 +1125,18 @@ void _CPU_Context_restore_fp(
+ /* TODO */
+ while (1) {
+ /* TODO */
void _BSP_Exception_frame_print( const CPU_Exception_frame *frame );
static inline void _CPU_Exception_frame_print(
diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
index e51798b..7c48d7b 100644
--- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
@@ -970,6 +970,18 @@ void _CPU_Context_restore_fp(
+ /* TODO */
+ while (1) {
+ /* TODO */
* @brief The set of registers that specifies the complete processor state.
diff --git a/cpukit/score/cpu/nios2/Makefile.am b/cpukit/score/cpu/nios2/Makefile.am
index 27bfb30..6fdc786 100644
--- a/cpukit/score/cpu/nios2/Makefile.am
+++ b/cpukit/score/cpu/nios2/Makefile.am
@@ -23,6 +23,8 @@ noinst_LIBRARIES = libscorecpu.a
libscorecpu_a_SOURCES += nios2-context-initialize.c
libscorecpu_a_SOURCES += nios2-context-switch.S
+libscorecpu_a_SOURCES += nios2-context-validate.S
+libscorecpu_a_SOURCES += nios2-context-volatile-clobber.S
libscorecpu_a_SOURCES += nios2-eic-il-low-level.S
libscorecpu_a_SOURCES += nios2-eic-rsie-low-level.S
libscorecpu_a_SOURCES += nios2-exception-frame-print.c
diff --git a/cpukit/score/cpu/nios2/nios2-context-validate.S b/cpukit/score/cpu/nios2/nios2-context-validate.S
index 0000000..9a5f5e1
--- /dev/null
+++ b/cpukit/score/cpu/nios2/nios2-context-validate.S
@@ -0,0 +1,146 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+#define FRAME_OFFSET_R16 0
+#define FRAME_OFFSET_R17 4
+#define FRAME_OFFSET_R18 8
+#define FRAME_OFFSET_R19 12
+#define FRAME_OFFSET_R20 16
+#define FRAME_OFFSET_R21 20
+#define FRAME_OFFSET_R22 24
+#define FRAME_OFFSET_R23 28
+#define FRAME_OFFSET_FP 32
+#define FRAME_OFFSET_RA 36
+#define FRAME_SIZE (FRAME_OFFSET_RA + 4)
+ .set noat
+ .section .text
+ .global _CPU_Context_validate
+_CPU_Context_validate:
+ /* Save */
+ subi sp, sp, FRAME_SIZE
+ stw r16, FRAME_OFFSET_R16(sp)
+ stw r17, FRAME_OFFSET_R17(sp)
+ stw r18, FRAME_OFFSET_R18(sp)
+ stw r19, FRAME_OFFSET_R19(sp)
+ stw r20, FRAME_OFFSET_R20(sp)
+ stw r21, FRAME_OFFSET_R21(sp)
+ stw r22, FRAME_OFFSET_R22(sp)
+ stw r23, FRAME_OFFSET_R23(sp)
+ stw fp, FRAME_OFFSET_FP(sp)
+ stw ra, FRAME_OFFSET_RA(sp)
+ /* Fill */
+ /* AT contains the stack pointer */
+ mov at, sp
+ /* R2 is used for temporary values */
+ subi r3, r4, 1
+ addi r5, r4, 1
+ addi r6, r4, 2
+ addi r7, r4, 3
+ addi r8, r4, 4
+ addi r9, r4, 5
+ addi r10, r4, 6
+ addi r11, r4, 7
+ addi r12, r4, 8
+ addi r13, r4, 9
+ addi r14, r4, 10
+ addi r15, r4, 11
+ addi r16, r4, 12
+ addi r17, r4, 13
+ addi r18, r4, 14
+ addi r19, r4, 15
+ addi r20, r4, 16
+ addi r21, r4, 17
+ addi r22, r4, 18
+ addi r23, r4, 19
+ addi fp, r4, 20
+ addi ra, r4, 21
+ /* Check */
+check:
+ bne sp, at, restore
+ subi r2, r4, 1
+ bne r2, r3, restore
+ addi r2, r4, 1
+ bne r2, r5, restore
+ addi r2, r4, 2
+ bne r2, r6, restore
+ addi r2, r4, 3
+ bne r2, r7, restore
+ addi r2, r4, 4
+ bne r2, r8, restore
+ addi r2, r4, 5
+ bne r2, r9, restore
+ addi r2, r4, 6
+ bne r2, r10, restore
+ addi r2, r4, 7
+ bne r2, r11, restore
+ addi r2, r4, 8
+ bne r2, r12, restore
+ addi r2, r4, 9
+ bne r2, r13, restore
+ addi r2, r4, 10
+ bne r2, r14, restore
+ addi r2, r4, 11
+ bne r2, r15, restore
+ addi r2, r4, 12
+ bne r2, r16, restore
+ addi r2, r4, 13
+ bne r2, r17, restore
+ addi r2, r4, 14
+ bne r2, r18, restore
+ addi r2, r4, 15
+ bne r2, r19, restore
+ addi r2, r4, 16
+ bne r2, r20, restore
+ addi r2, r4, 17
+ bne r2, r21, restore
+ addi r2, r4, 18
+ bne r2, r22, restore
+ addi r2, r4, 19
+ bne r2, r23, restore
+ addi r2, r4, 20
+ bne r2, fp, restore
+ addi r2, r4, 21
+ bne r2, ra, restore
+ br check
+ /* Restore */
+restore:
+ ldw ra, FRAME_OFFSET_RA(sp)
+ ldw fp, FRAME_OFFSET_FP(sp)
+ ldw r23, FRAME_OFFSET_R23(sp)
+ ldw r22, FRAME_OFFSET_R22(sp)
+ ldw r21, FRAME_OFFSET_R21(sp)
+ ldw r20, FRAME_OFFSET_R20(sp)
+ ldw r19, FRAME_OFFSET_R19(sp)
+ ldw r18, FRAME_OFFSET_R18(sp)
+ ldw r17, FRAME_OFFSET_R17(sp)
+ ldw r16, FRAME_OFFSET_R16(sp)
+ addi sp, sp, FRAME_SIZE
+ ret
diff --git a/cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S b/cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S
index 0000000..7b484e7
--- /dev/null
+++ b/cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S
@@ -0,0 +1,42 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+ .set noat
+ .section .text
+ .global _CPU_Context_volatile_clobber
+_CPU_Context_volatile_clobber:
+ subi at, r4, 11
+ subi r2, r4, 12
+ subi r3, r4, 13
+ subi r5, r4, 1
+ subi r6, r4, 2
+ subi r7, r4, 3
+ subi r8, r4, 4
+ subi r9, r4, 5
+ subi r10, r4, 6
+ subi r11, r4, 7
+ subi r12, r4, 8
+ subi r13, r4, 9
+ subi r14, r4, 10
+ subi r15, r4, 11
+ ret
diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
index b0e94c5..d3b5046 100644
--- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
@@ -333,6 +333,10 @@ void _CPU_Context_restore(
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 8c4a61b..fae7677 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -1295,6 +1295,33 @@ void _CPU_Context_restore_fp(
+ * @ingroup CPUContext
+ * @brief Clobbers all volatile registers with values derived from the pattern
+ * parameter.
+ * This function is used in test sptests/spcontext01.
+ * @param[in] pattern Pattern used to generate distinct register values.
+ * @brief Initializes and validates the CPU context with values derived from
+ * the pattern parameter.
+ * This function will not return if the CPU context remains consistent. In
+ * case this function returns the CPU port is broken.
* The CPU exception frame may be available in fatal error conditions like for
diff --git a/cpukit/score/cpu/powerpc/Makefile.am b/cpukit/score/cpu/powerpc/Makefile.am
index 7fd64ef..b205762 100644
--- a/cpukit/score/cpu/powerpc/Makefile.am
+++ b/cpukit/score/cpu/powerpc/Makefile.am
@@ -14,6 +14,8 @@ include_rtems_powerpc_HEADERS = rtems/powerpc/registers.h
libscorecpu_a_SOURCES = cpu.c
+libscorecpu_a_SOURCES += ppc-context-volatile-clobber.S
+libscorecpu_a_SOURCES += ppc-context-validate.S
libscorecpu_a_SOURCES += ppc-isr-vector-install.c
diff --git a/cpukit/score/cpu/powerpc/ppc-context-validate.S b/cpukit/score/cpu/powerpc/ppc-context-validate.S
index 0000000..0e3154e
--- /dev/null
+++ b/cpukit/score/cpu/powerpc/ppc-context-validate.S
@@ -0,0 +1,263 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+#include <rtems/score/cpu.h>
+#define LR_OFFSET 8
+#define CR_OFFSET 12
+#define OFFSET(i) ((i) * PPC_GPR_SIZE + 16)
+#define GPR14_OFFSET OFFSET(0)
+#define GPR15_OFFSET OFFSET(1)
+#define GPR16_OFFSET OFFSET(2)
+#define GPR17_OFFSET OFFSET(3)
+#define GPR18_OFFSET OFFSET(4)
+#define GPR19_OFFSET OFFSET(5)
+#define GPR20_OFFSET OFFSET(6)
+#define GPR21_OFFSET OFFSET(7)
+#define GPR22_OFFSET OFFSET(8)
+#define GPR23_OFFSET OFFSET(9)
+#define GPR24_OFFSET OFFSET(10)
+#define GPR25_OFFSET OFFSET(11)
+#define GPR26_OFFSET OFFSET(12)
+#define GPR27_OFFSET OFFSET(13)
+#define GPR28_OFFSET OFFSET(14)
+#define GPR29_OFFSET OFFSET(15)
+#define GPR30_OFFSET OFFSET(16)
+#define GPR31_OFFSET OFFSET(17)
+#define FRAME_SIZE \
+ ((OFFSET(18) + CPU_STACK_ALIGNMENT - 1) & (CPU_STACK_ALIGNMENT - 1))
+ /* Save */
+ stwu r1, -FRAME_SIZE(r1)
+ mflr r4
+ stw r4, LR_OFFSET(r1)
+ mfcr r4
+ stw r4, CR_OFFSET(r1)
+ stw r14, GPR14_OFFSET(r1)
+ stw r15, GPR15_OFFSET(r1)
+ stw r16, GPR16_OFFSET(r1)
+ stw r17, GPR17_OFFSET(r1)
+ stw r18, GPR18_OFFSET(r1)
+ stw r19, GPR19_OFFSET(r1)
+ stw r20, GPR20_OFFSET(r1)
+ stw r21, GPR21_OFFSET(r1)
+ stw r22, GPR22_OFFSET(r1)
+ stw r23, GPR23_OFFSET(r1)
+ stw r24, GPR24_OFFSET(r1)
+ stw r25, GPR25_OFFSET(r1)
+ stw r26, GPR26_OFFSET(r1)
+ stw r27, GPR27_OFFSET(r1)
+ stw r28, GPR28_OFFSET(r1)
+ stw r29, GPR29_OFFSET(r1)
+ stw r30, GPR30_OFFSET(r1)
+ stw r31, GPR31_OFFSET(r1)
+ /* Fill */
+ /* CR and GPR29 are equal most of the time */
+ addi r4, r3, 24
+ mtcr r4
+ addi r4, r3, 25
+ mtlr r4
+ addi r4, r3, 26
+ mtctr r4
+ addi r4, r3, 27
+ mtxer r4
+ addi r0, r3, 28
+ /* GPR4 is used for temporary values */
+ addi r5, r3, 1
+ addi r6, r3, 2
+ addi r7, r3, 3
+ addi r8, r3, 4
+ addi r9, r3, 5
+ addi r10, r3, 6
+ addi r11, r3, 7
+ addi r12, r3, 8
+ addi r14, r3, 9
+ addi r15, r3, 10
+ addi r16, r3, 11
+ addi r17, r3, 12
+ addi r18, r3, 13
+ addi r19, r3, 14
+ addi r20, r3, 15
+ addi r21, r3, 16
+ addi r22, r3, 17
+ addi r23, r3, 18
+ addi r24, r3, 19
+ addi r25, r3, 20
+ addi r26, r3, 21
+ addi r27, r3, 22
+ addi r28, r3, 23
+ /* GPR29 and CR are equal most of the time */
+ addi r29, r3, 24
+ /* GPR30 contains the MSR pattern */
+ mfmsr r30
+ xor r30, r30, r3
+ /* GPR31 contains the stack pointer */
+ mr r31, r1
+ /* Check */
+check:
+ mfcr r4
+ cmpw r4, r29
+ bne restore
+ addi r4, r3, 1
+ cmpw r4, r5
+ bne restore
+ addi r4, r3, 2
+ cmpw r4, r6
+ bne restore
+ addi r4, r3, 3
+ cmpw r4, r7
+ bne restore
+ addi r4, r3, 4
+ cmpw r4, r8
+ bne restore
+ addi r4, r3, 5
+ cmpw r4, r9
+ bne restore
+ addi r4, r3, 6
+ cmpw r4, r10
+ bne restore
+ addi r4, r3, 7
+ cmpw r4, r11
+ bne restore
+ addi r4, r3, 8
+ cmpw r4, r12
+ bne restore
+ lis r4, _SDA_BASE_ at h
+ ori r4, r4, _SDA_BASE_ at l
+ cmpw r4, r13
+ bne restore
+ addi r4, r3, 9
+ cmpw r4, r14
+ bne restore
+ addi r4, r3, 10
+ cmpw r4, r15
+ bne restore
+ addi r4, r3, 11
+ cmpw r4, r16
+ bne restore
+ addi r4, r3, 12
+ cmpw r4, r17
+ bne restore
+ addi r4, r3, 13
+ cmpw r4, r18
+ bne restore
+ addi r4, r3, 14
+ cmpw r4, r19
+ bne restore
+ addi r4, r3, 15
+ cmpw r4, r20
+ bne restore
+ addi r4, r3, 16
+ cmpw r4, r21
+ bne restore
+ addi r4, r3, 17
+ cmpw r4, r22
+ bne restore
+ addi r4, r3, 18
+ cmpw r4, r23
+ bne restore
+ addi r4, r3, 19
+ cmpw r4, r24
+ bne restore
+ addi r4, r3, 20
+ cmpw r4, r25
+ bne restore
+ addi r4, r3, 21
+ cmpw r4, r26
+ bne restore
+ addi r4, r3, 22
+ cmpw r4, r27
+ bne restore
+ addi r4, r3, 23
+ cmpw r4, r28
+ bne restore
+ addi r4, r3, 24
+ cmpw r4, r29
+ bne restore
+ mfmsr r4
+ xor r4, r4, r3
+ cmpw r4, r30
+ bne restore
+ addi r4, r3, 25
+ mflr r5
+ cmpw r4, r5
+ bne restore
+ addi r4, r3, 26
+ mfctr r5
+ cmpw r4, r5
+ bne restore
+ addi r4, r3, 27
+ mfxer r5
+ cmpw r4, r5
+ bne restore
+ addi r4, r3, 28
+ cmpw r4, r0
+ bne restore
+ cmpw r31, r1
+ bne restore
+#if 0
+ /* This is only valid if we use the EABI */
+ lis r4, _SDA2_BASE_ at h
+ ori r4, r4, _SDA2_BASE_ at l
+ cmpw r4, r2
+ bne restore
+#endif
+ mtcr r29
+ addi r5, r3, 1
+ b check
+ /* Restore */
+restore:
+ lwz r31, GPR31_OFFSET(r1)
+ lwz r30, GPR30_OFFSET(r1)
+ lwz r29, GPR29_OFFSET(r1)
+ lwz r28, GPR28_OFFSET(r1)
+ lwz r27, GPR27_OFFSET(r1)
+ lwz r26, GPR26_OFFSET(r1)
+ lwz r25, GPR25_OFFSET(r1)
+ lwz r24, GPR24_OFFSET(r1)
+ lwz r23, GPR23_OFFSET(r1)
+ lwz r22, GPR22_OFFSET(r1)
+ lwz r21, GPR21_OFFSET(r1)
+ lwz r20, GPR20_OFFSET(r1)
+ lwz r19, GPR19_OFFSET(r1)
+ lwz r18, GPR18_OFFSET(r1)
+ lwz r17, GPR17_OFFSET(r1)
+ lwz r16, GPR16_OFFSET(r1)
+ lwz r15, GPR15_OFFSET(r1)
+ lwz r14, GPR14_OFFSET(r1)
+ lwz r4, CR_OFFSET(r1)
+ mtcr r4
+ lwz r4, LR_OFFSET(r1)
+ mtlr r4
+ addi r1, r1, FRAME_SIZE
+ blr
diff --git a/cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S b/cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S
index 0000000..f4a5721
--- /dev/null
+++ b/cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S
@@ -0,0 +1,45 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+ addi r4, r3, 10
+ rlwinm r4, r4, 0, 20, 7
+ mfcr r5
+ rlwinm r5, r5, 0, 8, 19
+ or r4, r4, r5
+ mtcr r4
+ addi r4, r3, 11
+ mtctr r4
+ addi r4, r3, 12
+ mtxer r4
+ addi r0, r3, 13
+ addi r4, r3, 1
+ addi r5, r3, 2
+ addi r6, r3, 3
+ addi r7, r3, 4
+ addi r8, r3, 5
+ addi r9, r3, 6
+ addi r10, r3, 7
+ addi r11, r3, 8
+ addi r12, r3, 9
+ blr
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 37d8c34..080c5bb 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -992,6 +992,10 @@ void _CPU_Context_restore_fp(
typedef struct {
uint32_t EXC_SRR0;
uint32_t EXC_SRR1;
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index f5ad90c..d4412f6 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -886,6 +886,18 @@ void _CPU_Context_restore_fp(
+ /* TODO */
+ while (1) {
+ /* TODO */
/* FIXME */
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index b95d411..2209c89 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -1227,6 +1227,18 @@ void _CPU_Context_restore_fp(
+ /* TODO */
+ while (1) {
+ /* TODO */
typedef struct {
uint32_t trap;
CPU_Interrupt_frame *isf;
diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
index 36c7144..314143b 100644
--- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
@@ -1028,6 +1028,18 @@ void _CPU_Context_restore_fp(
+ /* TODO */
+ while (1) {
+ /* TODO */
/* FIXME */
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index c0b6f9e..12c824b 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
@@ -1128,6 +1128,18 @@ void _CPU_Context_restore_fp(
#endif
+ /* TODO */
+ while (1) {
+ /* TODO */
/* FIXME */
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index c9d20dd..4b0fff6 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -30,6 +30,7 @@ SUBDIRS = \
spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
spatomic01 spatomic02 spatomic03 spatomic04 spatomic05 \
spatomic06 spatomic07
+SUBDIRS += spcontext01
SUBDIRS += spfatal26
SUBDIRS += speventtransient01
SUBDIRS += speventsystem01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index a43a1ad..ba3aa92 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -27,6 +27,7 @@ AC_CHECK_SIZEOF([time_t])
# Explicitly list all Makefiles here
AC_CONFIG_FILES([Makefile
+spcontext01/Makefile
spfatal26/Makefile
spinternalerror02/Makefile
spinternalerror01/Makefile
diff --git a/testsuites/sptests/spcontext01/Makefile.am b/testsuites/sptests/spcontext01/Makefile.am
index 0000000..b1c7de2
--- /dev/null
+++ b/testsuites/sptests/spcontext01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spcontext01
+spcontext01_SOURCES = init.c
+dist_rtems_tests_DATA = spcontext01.scn spcontext01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spcontext01_OBJECTS)
+LINK_LIBS = $(spcontext01_LDLIBS)
+spcontext01$(EXEEXT): $(spcontext01_OBJECTS) $(spcontext01_DEPENDENCIES)
+ @rm -f spcontext01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spcontext01/init.c b/testsuites/sptests/spcontext01/init.c
index 0000000..f9c1803
--- /dev/null
+++ b/testsuites/sptests/spcontext01/init.c
@@ -0,0 +1,188 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+#include "tmacros.h"
+#define ITERATION_COUNT 2000
+#define PRIORITY_HIGH 2
+#define PRIORITY_LOW 3
+#define FINISH_EVENT RTEMS_EVENT_0
+typedef struct {
+ rtems_id control_task;
+ rtems_id validate_tasks[2];
+ size_t task_index;
+ int iteration_counter;
+} test_context;
+static test_context test_instance;
+static void validate_task(rtems_task_argument arg)
+ _CPU_Context_validate(arg);
+ rtems_test_assert(0);
+static void start_validate_task(
+ rtems_id *id,
+ uintptr_t pattern,
+ rtems_task_priority priority
+ rtems_status_code sc;
+ sc = rtems_task_create(
+ rtems_build_name('V', 'A', 'L', 'I'),
+ priority,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ id
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_start(*id, validate_task, pattern);
+static void reset_timer_or_finish(test_context *self, rtems_id timer)
+ int i = self->iteration_counter;
+ if (i < ITERATION_COUNT) {
+ self->iteration_counter = i + 1;
+ sc = rtems_timer_reset(timer);
+ } else {
+ sc = rtems_event_send(self->control_task, FINISH_EVENT);
+static void switch_priorities(test_context *self)
+ size_t index = self->task_index;
+ size_t next = (index + 1) & 0x1;
+ size_t task_high = index;
+ size_t task_low = next;
+ rtems_task_priority priority;
+ self->task_index = next;
+ sc = rtems_task_set_priority(
+ self->validate_tasks[task_high],
+ PRIORITY_HIGH,
+ &priority
+ self->validate_tasks[task_low],
+ PRIORITY_LOW,
+ &priority
+static void clobber_and_switch_timer(rtems_id timer, void *arg)
+ uintptr_t pattern = (uintptr_t) 0xffffffffffffffffU;
+ test_context *self = arg;
+ reset_timer_or_finish(self, timer);
+ switch_priorities(self);
+ _CPU_Context_volatile_clobber(pattern);
+static void start_timer(test_context *self)
+ rtems_id timer;
+ sc = rtems_timer_create(rtems_build_name('C', 'L', 'S', 'W'), &timer);
+ sc = rtems_timer_fire_after(timer, 2, clobber_and_switch_timer, self);
+static void wait_for_finish(void)
+ rtems_event_set out;
+ sc = rtems_event_receive(
+ FINISH_EVENT,
+ RTEMS_WAIT | RTEMS_EVENT_ALL,
+ RTEMS_NO_TIMEOUT,
+ &out
+ rtems_test_assert(out == FINISH_EVENT);
+static void test(test_context *self)
+ uintptr_t pattern_0 = (uintptr_t) 0xaaaaaaaaaaaaaaaaU;
+ uintptr_t pattern_1 = (uintptr_t) 0x5555555555555555U;
+ memset(self, 0, sizeof(*self));
+ self->control_task = rtems_task_self();
+ start_validate_task(&self->validate_tasks[0], pattern_0, PRIORITY_LOW);
+ start_validate_task(&self->validate_tasks[1], pattern_1, PRIORITY_HIGH);
+ start_timer(self);
+ wait_for_finish();
+static void Init(rtems_task_argument arg)
+ test_context *self = &test_instance;
+ puts("\n\n*** TEST SPCONTEXT 1 ***");
+ test(self);
+ puts("*** END OF TEST SPCONTEXT 1 ***");
+ rtems_test_exit(0);
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_TASKS 3
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spcontext01/spcontext01.doc b/testsuites/sptests/spcontext01/spcontext01.doc
index 0000000..2c2c4cf
--- /dev/null
+++ b/testsuites/sptests/spcontext01/spcontext01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spcontext01
+directives:
+ TBD
+concepts:
+ - Ensure the context switching and interrupt processing works
diff --git a/testsuites/sptests/spcontext01/spcontext01.scn b/testsuites/sptests/spcontext01/spcontext01.scn
index 0000000..b7b823b
--- /dev/null
+++ b/testsuites/sptests/spcontext01/spcontext01.scn
@@ -0,0 +1,2 @@
+*** TEST SPCONTEXT 1 ***
+*** END OF TEST SPCONTEXT 1 ***
1.7.7
