[PATCH 4/4] arm: Support VFP-D32 and Neon
Sebastian Huber
Wed May 8 09:48:55 UTC 2013
.../make/custom/realview_pbx_a9_qemu.cfg | 2 +-
c/src/lib/libbsp/arm/shared/start/start.S | 20 +++
.../make/custom/xilinx_zynq_a9_qemu.cfg | 2 +-
cpukit/score/cpu/arm/arm-context-validate.S | 160 +++++++++++++++++++-
.../score/cpu/arm/arm-context-volatile-clobber.S | 40 +++++
cpukit/score/cpu/arm/arm-exception-frame-print.c | 25 +++
cpukit/score/cpu/arm/arm_exc_interrupt.S | 39 ++++-
cpukit/score/cpu/arm/armv4-exception-default.S | 47 +++++--
cpukit/score/cpu/arm/cpu.c | 23 +++
cpukit/score/cpu/arm/cpu_asm.S | 12 ++-
cpukit/score/cpu/arm/rtems/score/arm.h | 11 +-
cpukit/score/cpu/arm/rtems/score/cpu.h | 74 ++++++++--
12 files changed, 415 insertions(+), 40 deletions(-)
diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg b/c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg
index fbee001..5b63eed 100644
--- a/c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg
+++ b/c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg
@@ -2,6 +2,6 @@ include $(RTEMS_ROOT)/make/custom/default.cfg
RTEMS_CPU = arm
-CPU_CFLAGS = -mcpu=cortex-a9 -mthumb
+CPU_CFLAGS = -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9
CFLAGS_OPTIMIZE_V ?= -O0 -g
diff --git a/c/src/lib/libbsp/arm/shared/start/start.S b/c/src/lib/libbsp/arm/shared/start/start.S
index cb91d41..e79a5fc 100644
--- a/c/src/lib/libbsp/arm/shared/start/start.S
+++ b/c/src/lib/libbsp/arm/shared/start/start.S
@@ -154,6 +154,26 @@ _start:
/* Stay in SVC mode */
+#ifdef ARM_MULTILIB_VFP_D32
+ /* Read CPACR */
+ mrc p15, 0, r0, c1, c0, 2
+ /* Enable CP10 and CP11 */
+ orr r0, r0, #(1 << 20)
+ orr r0, r0, #(1 << 22)
+ /* Clear ASEDIS and D32DIS */
+ bic r0, r0, #(3 << 30)
+ /* Write CPACR */
+ mcr p15, 0, r0, c1, c0, 2
+ isb
+ /* Enable FPU */
+ mov r0, #(1 << 30)
+ vmsr FPEXC, r0
+#endif
* Branch to start hook 0.
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg b/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg
--- a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg
RTEMS_CPU = arm
diff --git a/cpukit/score/cpu/arm/arm-context-validate.S b/cpukit/score/cpu/arm/arm-context-validate.S
index 4591d20..ad2ebb9 100644
--- a/cpukit/score/cpu/arm/arm-context-validate.S
+++ b/cpukit/score/cpu/arm/arm-context-validate.S
@@ -17,6 +17,7 @@
#endif
#include <rtems/asm.h>
+#include <rtems/score/cpu.h>
#define FRAME_OFFSET_R4 0
#define FRAME_OFFSET_R5 4
@@ -28,7 +29,20 @@
#define FRAME_OFFSET_R11 28
#define FRAME_OFFSET_LR 32
-#define FRAME_SIZE (FRAME_OFFSET_LR + 4)
+ #define FRAME_OFFSET_D8 40
+ #define FRAME_OFFSET_D9 48
+ #define FRAME_OFFSET_D10 56
+ #define FRAME_OFFSET_D11 64
+ #define FRAME_OFFSET_D12 72
+ #define FRAME_OFFSET_D13 80
+ #define FRAME_OFFSET_D14 88
+ #define FRAME_OFFSET_D15 96
+ #define FRAME_SIZE (FRAME_OFFSET_D15 + 8)
+#else
+ #define FRAME_SIZE (FRAME_OFFSET_LR + 4)
+#endif
.section .text
@@ -57,6 +71,17 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
mov r1, lr
str r1, [sp, #FRAME_OFFSET_LR]
+ vstr d8, [sp, #FRAME_OFFSET_D8]
+ vstr d9, [sp, #FRAME_OFFSET_D9]
+ vstr d10, [sp, #FRAME_OFFSET_D10]
+ vstr d11, [sp, #FRAME_OFFSET_D11]
+ vstr d12, [sp, #FRAME_OFFSET_D12]
+ vstr d13, [sp, #FRAME_OFFSET_D13]
+ vstr d14, [sp, #FRAME_OFFSET_D14]
+ vstr d15, [sp, #FRAME_OFFSET_D15]
+#endif
/* Fill */
/* R1 is used for temporary values */
@@ -70,7 +95,20 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
mov \reg, r1
.endm
+ /* R3 contains the FPSCR */
+ vmrs r3, FPSCR
+ movs r4, #0x001f
+ movt r4, #0xf800
+ bic r3, r3, r4
+ and r4, r4, r0
+ orr r3, r3, r4
+ vmsr FPSCR, r3
+#else
fill_register r3
+#endif
fill_register r4
fill_register r5
fill_register r6
@@ -82,6 +120,46 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
fill_register r12
fill_register lr
+.macro fill_vfp_register reg
+ add r1, r1, #1
+ vmov \reg, r1, r1
+.endm
+ fill_vfp_register d0
+ fill_vfp_register d1
+ fill_vfp_register d2
+ fill_vfp_register d3
+ fill_vfp_register d4
+ fill_vfp_register d5
+ fill_vfp_register d6
+ fill_vfp_register d7
+ fill_vfp_register d8
+ fill_vfp_register d9
+ fill_vfp_register d10
+ fill_vfp_register d11
+ fill_vfp_register d12
+ fill_vfp_register d13
+ fill_vfp_register d14
+ fill_vfp_register d15
+ fill_vfp_register d16
+ fill_vfp_register d17
+ fill_vfp_register d18
+ fill_vfp_register d19
+ fill_vfp_register d20
+ fill_vfp_register d21
+ fill_vfp_register d22
+ fill_vfp_register d23
+ fill_vfp_register d24
+ fill_vfp_register d25
+ fill_vfp_register d26
+ fill_vfp_register d27
+ fill_vfp_register d28
+ fill_vfp_register d29
+ fill_vfp_register d30
+ fill_vfp_register d31
+#endif
/* Check */
check:
@@ -96,7 +174,10 @@ check:
mov r1, r0
+#ifndef ARM_MULTILIB_VFP_D32
check_register r3
+#endif
check_register r4
check_register r5
check_register r6
@@ -108,6 +189,10 @@ check:
check_register r12
check_register lr
+ b check_vfp
+#endif
b check
/* Restore */
@@ -132,8 +217,81 @@ restore:
ldr r1, [sp, #FRAME_OFFSET_LR]
mov lr, r1
+ vldr d8, [sp, #FRAME_OFFSET_D8]
+ vldr d9, [sp, #FRAME_OFFSET_D9]
+ vldr d10, [sp, #FRAME_OFFSET_D10]
+ vldr d11, [sp, #FRAME_OFFSET_D11]
+ vldr d12, [sp, #FRAME_OFFSET_D12]
+ vldr d13, [sp, #FRAME_OFFSET_D13]
+ vldr d14, [sp, #FRAME_OFFSET_D14]
+ vldr d15, [sp, #FRAME_OFFSET_D15]
+#endif
add sp, sp, #FRAME_SIZE
bx lr
FUNCTION_END(_CPU_Context_validate)
+check_vfp:
+.macro check_vfp_register reg
+ add r1, r1, #1
+ vmov r4, r5, \reg
+ cmp r4, r5
+ bne 1f
+ cmp r1, r4
+ bne 1f
+ b 2f
+1:
+ b restore
+2:
+.endm
+ vmrs r4, FPSCR
+ cmp r4, r3
+ bne restore
+ check_vfp_register d0
+ check_vfp_register d1
+ check_vfp_register d2
+ check_vfp_register d3
+ check_vfp_register d4
+ check_vfp_register d5
+ check_vfp_register d6
+ check_vfp_register d7
+ check_vfp_register d8
+ check_vfp_register d9
+ check_vfp_register d10
+ check_vfp_register d11
+ check_vfp_register d12
+ check_vfp_register d13
+ check_vfp_register d14
+ check_vfp_register d15
+ check_vfp_register d16
+ check_vfp_register d17
+ check_vfp_register d18
+ check_vfp_register d19
+ check_vfp_register d20
+ check_vfp_register d21
+ check_vfp_register d22
+ check_vfp_register d23
+ check_vfp_register d24
+ check_vfp_register d25
+ check_vfp_register d26
+ check_vfp_register d27
+ check_vfp_register d28
+ check_vfp_register d29
+ check_vfp_register d30
+ check_vfp_register d31
+ /* Restore r4 and r5 */
+ mov r1, r0
+ fill_register r4
+ fill_register r5
+ b check
+#endif
diff --git a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
index b79e570..3b1011d 100644
--- a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
+++ b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
@@ -27,6 +27,46 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
mov \reg, r0
.endm
+ vmrs r1, FPSCR
+ movs r2, #0x001f
+ movt r2, #0xf800
+ bic r1, r1, r2
+ and r2, r2, r0
+ orr r1, r1, r2
+ vmsr FPSCR, r1
+.macro clobber_vfp_register reg
+ sub r0, r0, #1
+ vmov \reg, r0, r0
+.endm
+ clobber_vfp_register d0
+ clobber_vfp_register d1
+ clobber_vfp_register d2
+ clobber_vfp_register d3
+ clobber_vfp_register d4
+ clobber_vfp_register d5
+ clobber_vfp_register d6
+ clobber_vfp_register d7
+ clobber_vfp_register d16
+ clobber_vfp_register d17
+ clobber_vfp_register d18
+ clobber_vfp_register d19
+ clobber_vfp_register d20
+ clobber_vfp_register d21
+ clobber_vfp_register d22
+ clobber_vfp_register d23
+ clobber_vfp_register d24
+ clobber_vfp_register d25
+ clobber_vfp_register d26
+ clobber_vfp_register d27
+ clobber_vfp_register d28
+ clobber_vfp_register d29
+ clobber_vfp_register d30
+ clobber_vfp_register d31
+#endif
clobber_register r1
clobber_register r2
clobber_register r3
diff --git a/cpukit/score/cpu/arm/arm-exception-frame-print.c b/cpukit/score/cpu/arm/arm-exception-frame-print.c
index 53d31ad..bc0f514 100644
--- a/cpukit/score/cpu/arm/arm-exception-frame-print.c
+++ b/cpukit/score/cpu/arm/arm-exception-frame-print.c
@@ -19,6 +19,29 @@
#include <rtems/bspIo.h>
+static void _ARM_VFP_context_print( const ARM_VFP_context *vfp_context )
+ if ( vfp_context != NULL ) {
+ const uint64_t *dx = &vfp_context->register_d0;
+ int i;
+ printk(
+ "FPEXC = 0x%08x\nFPSCR = 0x%08x\n",
+ vfp_context->register_fpexc,
+ vfp_context->register_fpscr
+ for ( i = 0; i < 32; ++i ) {
+ uint32_t low = (uint32_t) dx[i];
+ uint32_t high = (uint32_t) (dx[i] >> 32);
+ printk( "D%02i = 0x%08x%08x\n", i, high, low );
+#endif
void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
printk(
@@ -59,4 +82,6 @@ void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
#endif
frame->vector
+ _ARM_VFP_context_print( frame->vfp_context );
diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
index 82f3007..a627f52 100644
--- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
+++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
@@ -7,12 +7,13 @@
- * Copyright (c) 2009
- * embedded brains GmbH
- * Obere Lagerstr. 30
- * D-82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
+ * Copyright (c) 2009-2013 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Obere Lagerstr. 30
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
@@ -45,6 +46,10 @@
#define CONTEXT_LIST {r0, r1, r2, r3, EXCHANGE_LR, EXCHANGE_SPSR, r12}
#define CONTEXT_SIZE 28
+ #define VFP_CONTEXT_WITH_ALIGNMENT_SPACE (24 * 8 + 4 + 4)
+#endif
.extern _Thread_Dispatch_disable_level
.extern bsp_interrupt_dispatch
@@ -74,6 +79,17 @@ _ARMV4_Exception_interrupt:
stmdb sp!, CONTEXT_LIST
stmdb sp!, {lr}
+ /* Save VFP context */
+ sub sp, #VFP_CONTEXT_WITH_ALIGNMENT_SPACE
+ vmrs r0, FPSCR
+ add r1, sp, #4
+ bic r1, r1, #7
+ vstmia r1!, {d0-d7}
+ vstmia r1!, {d16-d31}
+ stm r1, {r0}
+#endif
/* Remember INT stack pointer */
mov r1, EXCHANGE_INT_SP
@@ -144,6 +160,17 @@ thread_dispatch_done:
/* Switch to ARM instructions if necessary */
SWITCH_FROM_THUMB_TO_ARM
+ /* Restore VFP context */
+ add r1, sp, #4
+ bic r1, r1, #7
+ vldmia r1!, {d0-d7}
+ vldmia r1!, {d16-d31}
+ ldm r1, {r0}
+ add sp, #VFP_CONTEXT_WITH_ALIGNMENT_SPACE
+ vmsr FPSCR, r0
+#endif
/* Restore link register */
ldmia sp!, {lr}
diff --git a/cpukit/score/cpu/arm/armv4-exception-default.S b/cpukit/score/cpu/arm/armv4-exception-default.S
index e5520d5..a5fe415 100644
--- a/cpukit/score/cpu/arm/armv4-exception-default.S
+++ b/cpukit/score/cpu/arm/armv4-exception-default.S
@@ -21,6 +21,9 @@
#ifdef ARM_MULTILIB_ARCH_V4
+#define MORE_CONTEXT_SIZE \
+ (ARM_EXCEPTION_FRAME_SIZE - ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET)
.extern _ARM_Exception_default
.globl _ARMV4_Exception_undef_default
@@ -38,7 +41,7 @@
_ARMV4_Exception_undef_default:
/* Save context and load vector */
- sub sp, #20
+ sub sp, #MORE_CONTEXT_SIZE
stmdb sp!, {r0-r12}
mov r4, #1
@@ -47,7 +50,7 @@ _ARMV4_Exception_undef_default:
_ARMV4_Exception_swi_default:
- sub sp, #20
stmdb sp!, {r0-r12}
mov r4, #2
@@ -56,7 +59,7 @@ _ARMV4_Exception_swi_default:
_ARMV4_Exception_pref_abort_default:
- sub sp, #20
stmdb sp!, {r0-r12}
mov r4, #3
@@ -65,28 +68,28 @@ _ARMV4_Exception_pref_abort_default:
_ARMV4_Exception_data_abort_default:
- sub sp, #20
stmdb sp!, {r0-r12}
mov r4, #4
_ARMV4_Exception_reserved_default:
- sub sp, #20
stmdb sp!, {r0-r12}
mov r4, #5
_ARMV4_Exception_irq_default:
- sub sp, #20
stmdb sp!, {r0-r12}
mov r4, #6
_ARMV4_Exception_fiq_default:
- sub sp, #20
stmdb sp!, {r0-r12}
mov r4, #7
@@ -99,14 +102,36 @@ save_more_context:
orr r5, r3, #ARM_PSR_I
bic r5, #ARM_PSR_T
msr cpsr, r5
- mov r0, sp
+ sub r0, sp, #ARM_EXCEPTION_FRAME_SIZE
mov r1, lr
msr cpsr, r7
- add r5, sp, #72
- stmdb r5!, {r0-r4}
+ mov r5, #0
+ add r6, sp, #ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET
+ stm r6, {r0-r5}
- /* Call high level handler */
+ /* Argument for high level handler */
mov r0, sp
+ /* Ensure that the FPU is enabled */
+ vmrs r1, FPEXC
+ tst r1, #(1 << 30)
+ beq fpu_save_done
+ add r3, sp, #ARM_EXCEPTION_FRAME_VFP_CONTEXT_OFFSET
+ sub sp, #(ARM_VFP_CONTEXT_SIZE + 4)
+ add r4, sp, #4
+ bic r4, r4, #7
+ str r4, [r3]
+ vmrs r2, FPSCR
+ stmia r4!, {r1-r2}
+ vstmia r4!, {d0-d15}
+ vstmia r4!, {d16-d31}
+fpu_save_done:
+#endif
+ /* Call high level handler */
SWITCH_FROM_ARM_TO_THUMB r1
bl _ARM_Exception_default
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 5fd920e..958bd81 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -34,6 +34,29 @@
+ RTEMS_STATIC_ASSERT(
+ offsetof( Context_Control, register_d8 ) == ARM_CONTEXT_CONTROL_D8_OFFSET,
+ ARM_CONTEXT_CONTROL_D8_OFFSET
+#endif
+RTEMS_STATIC_ASSERT(
+ sizeof( CPU_Exception_frame ) == ARM_EXCEPTION_FRAME_SIZE,
+ ARM_EXCEPTION_FRAME_SIZE
+ offsetof( CPU_Exception_frame, register_sp )
+ == ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET,
+ ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET
+ sizeof( ARM_VFP_context ) == ARM_VFP_CONTEXT_SIZE,
+ ARM_VFP_CONTEXT_SIZE
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index 79e6df8..22dd7a3 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -30,7 +30,7 @@
#endif
-#include <rtems/score/cpu_asm.h>
@@ -57,9 +57,19 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
mrs r2, cpsr
stmia r0, {r2, r4, r5, r6, r7, r8, r9, r10, r11, r13, r14}
+ add r3, r0, #ARM_CONTEXT_CONTROL_D8_OFFSET
+ vstm r3, {d8-d15}
+#endif
/* Start restoring context */
_restore:
+ add r3, r1, #ARM_CONTEXT_CONTROL_D8_OFFSET
+ vldm r3, {d8-d15}
+#endif
ldmia r1, {r2, r4, r5, r6, r7, r8, r9, r10, r11, r13, r14}
msr cpsr, r2
#ifdef __thumb__
diff --git a/cpukit/score/cpu/arm/rtems/score/arm.h b/cpukit/score/cpu/arm/rtems/score/arm.h
index 91999b3..fb0f98e 100644
--- a/cpukit/score/cpu/arm/rtems/score/arm.h
+++ b/cpukit/score/cpu/arm/rtems/score/arm.h
@@ -37,15 +37,12 @@ extern "C" {
#define ARM_MULTILIB_ARCH_V4
#endif
-/* All ARM CPUs are assumed to not have floating point units */
-#if defined(__SOFTFP__)
-#define ARM_HAS_FPU 0
-#else
-#define ARM_HAS_FPU 1
-#warning "FPU-support not yet implemented for the arm"
+#if defined(__ARM_NEON__)
+ #define ARM_MULTILIB_VFP_D32
+#elif !defined(__SOFTFP__)
+ #error "FPU support not implemented"
#endif
* Define the name of the CPU family.
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index b6f39ac..f00de73 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -8,7 +8,7 @@
* This include file contains information pertaining to the ARM
* processor.
- * Copyright (c) 2009-2011 embedded brains GmbH.
* Copyright (c) 2007 Ray Xu <Rayx.cn at gmail.com>
@@ -128,11 +128,7 @@
#define CPU_ISR_PASSES_FRAME_POINTER 0
-#if ( ARM_HAS_FPU == 1 )
- #define CPU_HARDWARE_FP TRUE
-#else
- #define CPU_HARDWARE_FP FALSE
-#endif
+#define CPU_HARDWARE_FP FALSE
#define CPU_SOFTWARE_FP FALSE
@@ -214,6 +210,18 @@
+ #define ARM_CONTEXT_CONTROL_D8_OFFSET 48
+#endif
+#define ARM_EXCEPTION_FRAME_SIZE 76
+#define ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET 52
+#define ARM_EXCEPTION_FRAME_VFP_CONTEXT_OFFSET 72
+#define ARM_VFP_CONTEXT_SIZE 264
#ifndef ASM
#ifdef __cplusplus
@@ -253,14 +261,22 @@ typedef struct {
#else
void *register_sp;
#endif
+ uint64_t register_d8;
+ uint64_t register_d9;
+ uint64_t register_d10;
+ uint64_t register_d11;
+ uint64_t register_d12;
+ uint64_t register_d13;
+ uint64_t register_d14;
+ uint64_t register_d15;
+#endif
} Context_Control;
typedef struct {
/* Not supported */
} Context_Control_fp;
-SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context;
extern uint32_t arm_cpu_mode;
static inline uint32_t arm_interrupt_disable( void )
@@ -419,10 +435,6 @@ void _CPU_Context_restore( Context_Control *new_context )
#define _CPU_Stop_multitasking _ARMV7M_Stop_multitasking
#endif
-void _CPU_Context_save_fp( Context_Control_fp **fp_context_ptr );
-void _CPU_Context_restore_fp( Context_Control_fp **fp_context_ptr );
void _CPU_Context_volatile_clobber( uintptr_t pattern );
void _CPU_Context_validate( uintptr_t pattern );
@@ -501,6 +513,43 @@ typedef enum {
#endif /* defined(ARM_MULTILIB_ARCH_V4) */
typedef struct {
+ uint32_t register_fpexc;
+ uint32_t register_fpscr;
+ uint64_t register_d0;
+ uint64_t register_d1;
+ uint64_t register_d2;
+ uint64_t register_d3;
+ uint64_t register_d4;
+ uint64_t register_d5;
+ uint64_t register_d6;
+ uint64_t register_d7;
+ uint64_t register_d16;
+ uint64_t register_d17;
+ uint64_t register_d18;
+ uint64_t register_d19;
+ uint64_t register_d20;
+ uint64_t register_d21;
+ uint64_t register_d22;
+ uint64_t register_d23;
+ uint64_t register_d24;
+ uint64_t register_d25;
+ uint64_t register_d26;
+ uint64_t register_d27;
+ uint64_t register_d28;
+ uint64_t register_d29;
+ uint64_t register_d30;
+ uint64_t register_d31;
+} ARM_VFP_context;
+typedef struct {
uint32_t register_r0;
uint32_t register_r1;
uint32_t register_r2;
@@ -524,6 +573,7 @@ typedef struct {
uint32_t register_xpsr;
uint32_t vector;
#endif
+ const ARM_VFP_context *vfp_context;
} CPU_Exception_frame;
typedef CPU_Exception_frame CPU_Interrupt_frame;
1.7.7
