[PATCH] sptests: add test for priority inversion with multiple locks
Gedare Bloom
gedare at rtems.org
Sun May 19 02:45:32 UTC 2013
On May 18, 2013 3:06 PM, "Joel Sherrill" <Joel.Sherrill at oarcorp.com> wrote:
> When the other test works should we remove the original test submitted
with this code?
No. Even when we fix the bugs, the tests will probably help coverage and
avoid regressions. The fixes should at least be ported back to 4.10 too.
> I think we should switch to this as the default behavior when it works.
Agreed for priority semaphores. Although I wonder if a better solution
exists that does not need strict LIFO p/v operations.
> We do need to check coverage.
Ok. I stumbled on a compile error when turning on strict mutex. :(
I also noticed that sp36, which uses strict mutex, is disabled / missing
from Makefile.am.
-Gedare
> Gedare Bloom <gedare at rtems.org> wrote:
> This test exposes a potential priority inversion when priority
> inheritance is used and multiple locks are acquired by a low priority
> task. The scenario consists of 2 tasks of different priority and 2
> semaphore/mutexes using priority inheritance.
> Using ENABLE_STRICT_ORDER_MUTEX=1 prevents the priority inversion.
> I hope to write another test soon that demonstrates a different
> priority inversion when there are 3 tasks and 2 mutexes while using
> the current implementation of strict order mutex.
> -Gedare
> On Sat, May 18, 2013 at 2:57 PM, Gedare Bloom <gedare at rtems.org> wrote:
> > testsuites/sptests/Makefile.am | 2 +-
> > testsuites/sptests/configure.ac | 1 +
> > testsuites/sptests/spsem01/Makefile.am | 21 +++++
> > testsuites/sptests/spsem01/init.c | 154
> > testsuites/sptests/spsem01/spsem01.doc | 19 ++++
> > testsuites/sptests/spsem01/spsem01.scn | 16 ++++
> > 6 files changed, 212 insertions(+), 1 deletions(-)
> > create mode 100644 testsuites/sptests/spsem01/Makefile.am
> > create mode 100644 testsuites/sptests/spsem01/init.c
> > create mode 100644 testsuites/sptests/spsem01/spsem01.doc
> > create mode 100644 testsuites/sptests/spsem01/spsem01.scn
> > diff --git a/testsuites/sptests/Makefile.am
b/testsuites/sptests/Makefile.am
> > index 4b0fff6..9acf477 100644
> > --- a/testsuites/sptests/Makefile.am
> > +++ b/testsuites/sptests/Makefile.am
> > @@ -25,7 +25,7 @@ SUBDIRS = \
> > spintrcritical09 spintrcritical10 spintrcritical11
spintrcritical12 \
> > spintrcritical13 spintrcritical14 spintrcritical15
spintrcritical16 \
> > spintrcritical17 spintrcritical18 spmkdir spmountmgr01 spheapprot \
> > - spsimplesched01 spsimplesched02 spsimplesched03 spnsext01 \
> > + spsem01 spsimplesched01 spsimplesched02 spsimplesched03 spnsext01 \
> > spedfsched01 spedfsched02 spedfsched03 \
> > spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
> > spatomic01 spatomic02 spatomic03 spatomic04 spatomic05 \
> > diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/
configure.ac
> > index ba3aa92..9f40fa1 100644
> > --- a/testsuites/sptests/configure.ac
> > +++ b/testsuites/sptests/configure.ac
> > @@ -188,6 +188,7 @@ spprintk/Makefile
> > spprivenv01/Makefile
> > spqreslib/Makefile
> > sprbtree01/Makefile
> > +spsem01/Makefile
> > spsimplesched01/Makefile
> > spsimplesched02/Makefile
> > spsimplesched03/Makefile
> > diff --git a/testsuites/sptests/spsem01/Makefile.am
b/testsuites/sptests/spsem01/Makefile.am
> > new file mode 100644
> > index 0000000..a957b05
> > --- /dev/null
> > +++ b/testsuites/sptests/spsem01/Makefile.am
> > @@ -0,0 +1,21 @@
> > +rtems_tests_PROGRAMS = spsem01
> > +spsem01_SOURCES = init.c
> > +dist_rtems_tests_DATA = spsem01.scn
> > +dist_rtems_tests_DATA += spsem01.doc
> > +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> > +include $(top_srcdir)/../automake/compile.am
> > +include $(top_srcdir)/../automake/leaf.am
> > +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> > +LINK_OBJS = $(spsem01_OBJECTS)
> > +LINK_LIBS = $(spsem01_LDLIBS)
> > +spsem01$(EXEEXT): $(spsem01_OBJECTS) $(spsem01_DEPENDENCIES)
> > + @rm -f spsem01$(EXEEXT)
> > + $(make-exe)
> > +include $(top_srcdir)/../automake/local.am
> > diff --git a/testsuites/sptests/spsem01/init.c
b/testsuites/sptests/spsem01/init.c
> > index 0000000..4a123f4
> > --- /dev/null
> > +++ b/testsuites/sptests/spsem01/init.c
> > @@ -0,0 +1,154 @@
> > + * Copyright (c) 2013 Gedare Bloom.
> > + * The license and distribution terms for this file may be
> > + * found in the file LICENSE in this distribution or at
> > + * http://www.rtems.com/license/LICENSE.
> > +#include <rtems.h>
> > +#include <stdio.h>
> > +#include "tmacros.h"
> > +/* configuration information */
> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > +#define CONFIGURE_EXTRA_TASK_STACKS (RTEMS_MINIMUM_STACK_SIZE * 3)
> > +#define CONFIGURE_MAXIMUM_TASKS 3
> > +#define CONFIGURE_MAXIMUM_SEMAPHORES 2
> > +#define CONFIGURE_INIT
> > +#include <rtems/confdefs.h>
> > +rtems_task Task01(rtems_task_argument ignored);
> > +rtems_task Task02(rtems_task_argument ignored);
> > +rtems_task Init(rtems_task_argument ignored);
> > +static int getprio(void)
> > + rtems_status_code status;
> > + rtems_task_priority pri;
> > + status = rtems_task_set_priority(RTEMS_SELF, RTEMS_CURRENT_PRIORITY,
&pri);
> > + directive_failed( status, "rtems_task_set_priority");
> > + return (int)pri;
> > +rtems_id Task_id[2];
> > +rtems_name Task_name[2];
> > +rtems_id sem_id[2];
> > +rtems_name sem_name[2];
> > + rtems_attribute sem_attr;
> > + printf("\n*** TEST SEMAPHORE01 ***\n");
> > + sem_attr = RTEMS_INHERIT_PRIORITY | RTEMS_BINARY_SEMAPHORE |
RTEMS_PRIORITY;
> > + sem_name[0] = rtems_build_name( 'S','0',' ',' ');
> > + status = rtems_semaphore_create(
> > + sem_name[0],
> > + 1,
> > + sem_attr,
> > + 0,
> > + &sem_id[0]
> > + directive_failed( status, "rtems_semaphore_create of S0");
> > + printf("init: S0 created\n");
> > + sem_name[1] = rtems_build_name( 'S','1',' ',' ');
> > + sem_name[1],
> > + 1,
> > + sem_attr,
> > + 0,
> > + &sem_id[1]
> > + directive_failed( status, "rtems_semaphore_create of S1");
> > + printf("init: S1 created\n");
> > + Task_name[0] = rtems_build_name( 'T','A','0','1');
> > + status = rtems_task_create(
> > + Task_name[0],
> > + 36,
> > + RTEMS_MINIMUM_STACK_SIZE*2,
> > + RTEMS_DEFAULT_MODES,
> > + RTEMS_DEFAULT_ATTRIBUTES,
> > + &Task_id[0]
> > + directive_failed( status, "rtems_task_create of TA01");
> > + printf("init: TA01 created with priority 36\n");
> > + Task_name[1] = rtems_build_name( 'T','A','0','2');
> > + Task_name[1],
> > + 34,
> > + &Task_id[1]
> > + directive_failed( status , "rtems_task_create of TA02\n");
> > + printf("init: TA02 created with priority 34\n");
> > + status = rtems_task_start( Task_id[0], Task01, 0);
> > + directive_failed( status, "rtems_task_start of TA01");
> > + status = rtems_task_delete( RTEMS_SELF);
> > + directive_failed( status, "rtems_task_delete of INIT");
> > +/* Task01 starts with priority 36 */
> > + printf("TA01: started with priority %d\n", getprio());
> > + status = rtems_semaphore_obtain( sem_id[0], RTEMS_WAIT, 0 );
> > + directive_failed( status, "rtems_semaphore_obtain of S0\n");
> > + printf("TA01: priority %d, holding S0\n", getprio());
> > + status = rtems_semaphore_obtain( sem_id[1], RTEMS_WAIT, 0 );
> > + directive_failed( status, "rtems_semaphore_obtain of S1");
> > + printf("TA01: priority %d, holding S0, S1\n", getprio());
> > + /* Start Task 2 (TA02) with priority 34. It will run immediately. */
> > + status = rtems_task_start( Task_id[1], Task02, 0);
> > + directive_failed( status, "rtems_task_start of TA02\n");
> > + status = rtems_semaphore_release(sem_id[1]);
> > + directive_failed( status, "rtems_semaphore_release of S1\n");
> > + status = rtems_semaphore_release(sem_id[0]);
> > + directive_failed( status, "rtems_semaphore_release of S0\n");
> > + printf("TA01: priority %d\n", getprio());
> > + printf("TA01: exiting\n");
> > + printf("*** END OF SEMAPHORE01 ***\n");
> > + directive_failed( status, "rtems_task_delete TA01");
> > +/* TA02 starts at Task02 with priority 34 */
> > + printf("TA02: started with priority %d\n", getprio());
> > + /* Obtain S1, which should be held by TA01 by now */
> > + directive_failed( status, " rtems_semaphore_obtain S1");
> > + printf("TA02: priority %d, holding S1\n", getprio());
> > + printf("TA02: exiting\n");
> > + directive_failed( status, "rtems_task_delete TA02");
> > diff --git a/testsuites/sptests/spsem01/spsem01.doc
b/testsuites/sptests/spsem01/spsem01.doc
> > index 0000000..8a09526
> > --- /dev/null
> > +++ b/testsuites/sptests/spsem01/spsem01.doc
> > @@ -0,0 +1,19 @@
> > +This test exposes a potential priority inversion when priority
inheritance is
> > +used and multiple locks are acquired by a low priority task. The
scenario
> > +consists of 2 tasks of different priority and 2 semaphore/mutexes using
> > +priority inheritance. The scenario is:
> > +Task 1 has priority 36. Task 2 has priority 34.
> > +1. Task 1 obtains semaphore S1.
> > +2. Task 1 obtains semaphore S2
> > +3. Task 2 preempts Task 1.
> > +4. Task 2 blocks on S2. Task 1 inherits priority 34.
> > +5. Task 1 resumes. Task 1 releases S2. Task 1 continues to run at
priority 34.
> > +6. Task 1 releases S1. Task 1 changes priority back to 36.
> > +7. Task 2 now preempts Task 1 and begins operating again.
> > +During steps 5-6 Task 1 executes when Task 2 should be able to execute.
> > +Stepping down the priority of Task 1 when it releases S2 back to its
original
> > +priority when it obtained S2 fixes the priority inversion.
> > diff --git a/testsuites/sptests/spsem01/spsem01.scn
b/testsuites/sptests/spsem01/spsem01.scn
> > index 0000000..54efd16
> > --- /dev/null
> > +++ b/testsuites/sptests/spsem01/spsem01.scn
> > @@ -0,0 +1,16 @@
> > +*** TEST SEMAPHORE01 ***
> > +init: S0 created
> > +init: S1 created
> > +init: TA01 created with priority 36
> > +init: TA02 created with priority 34
> > +TA01: started with priority 36
> > +TA01: priority 36, holding S0
> > +TA01: priority 36, holding S0, S1
> > +TA02: started with priority 34
> > +TA02: priority 34, holding S1
> > +TA02: exiting
> > +TA01: priority 36
> > +TA01: exiting
> > +*** END OF SEMAPHORE01 ***
> > 1.7.1
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130518/1a9afe73/attachment-0001.html>
