[PATCH 11/11] smp: Move secondary CPU initialization request
Joel Sherrill
Joel.Sherrill at OARcorp.com
Mon May 27 16:12:54 UTC 2013
Are you sure it was a scheduling bug and not a dispatch disable nesting problem? If the count does not go back to zero, then a blocked thread will continue to execute.
If it is a bug I would like to know the detailed scenario so I can reproduce it in the simulator.
Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
On 05/27/2013 04:33 PM, Joel Sherrill wrote:
> The other CPUs are not brought out of reset until this is executed. Did you see a case where the first thread is not executed on the first core?
Not with the current simple SMP scheduler, but this code should not depend on a
particular scheduler implementation.
I will provide an alternative simple SMP scheduler in the next couple of days
since the current one didn't work. I encountered a situation in which a
blocking thread continued to execute.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
