[PATCH 2/4] score: Remove idle field of Per_CPU_Control
Sebastian Huber
Wed May 29 15:31:07 UTC 2013
This field is unused except for special case simulator clock drivers.
In these places use an alternative. Add and use
_Thread_Set_exit_status() and _Thread_Get_exit_status().
c/src/lib/libbsp/shared/clockdrv_shell.h | 7 +++++--
c/src/lib/libcpu/bfin/clock/clock.c | 7 +++++--
c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c | 7 +++++--
cpukit/sapi/src/exinit.c | 4 ++--
cpukit/sapi/src/exshutdown.c | 3 +--
cpukit/score/include/rtems/score/percpu.h | 5 -----
cpukit/score/inline/rtems/score/thread.inl | 16 ++++++++++++++++
cpukit/score/src/threadcreateidle.c | 11 ++++++-----
testsuites/sptests/spsimplesched02/init.c | 13 +++++++++++--
9 files changed, 51 insertions(+), 22 deletions(-)
diff --git a/c/src/lib/libbsp/shared/clockdrv_shell.h b/c/src/lib/libbsp/shared/clockdrv_shell.h
index 3e8d08c..7919261 100644
--- a/c/src/lib/libbsp/shared/clockdrv_shell.h
+++ b/c/src/lib/libbsp/shared/clockdrv_shell.h
@@ -73,8 +73,11 @@ rtems_isr Clock_isr(
#ifdef CLOCK_DRIVER_USE_FAST_IDLE
do {
rtems_clock_tick();
- } while ( _Thread_Executing == _Thread_Idle &&
- _Thread_Heir == _Thread_Executing);
+ } while (
+ _Thread_Heir == _Thread_Executing
+ && _Thread_Executing->Start.entry_point
+ == rtems_configuration_get_idle_task()
Clock_driver_support_at_tick();
return;
diff --git a/c/src/lib/libcpu/bfin/clock/clock.c b/c/src/lib/libcpu/bfin/clock/clock.c
index 530e5ba..4652586 100644
--- a/c/src/lib/libcpu/bfin/clock/clock.c
+++ b/c/src/lib/libcpu/bfin/clock/clock.c
@@ -39,8 +39,11 @@ static rtems_isr clockISR(rtems_vector_number vector) {
do {
rtems_clock_tick();
- } while (_Thread_Executing == _Thread_Idle &&
+ } while (
#else
rtems_clock_tick();
#endif
diff --git a/c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c b/c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c
index 01b72aa..3033b70 100644
--- a/c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c
+++ b/c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c
@@ -98,8 +98,11 @@ static void clockHandler(void)
#if (CLOCK_DRIVER_USE_FAST_IDLE == 1)
do {
rtems_clock_tick();
+ } while (
#else
rtems_clock_tick();
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 4ee2471..a0203eb 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -237,7 +237,7 @@ void rtems_initialize_start_multitasking(void)
- status = _Per_CPU_Information[0].idle->Wait.return_code;
+ status = _Thread_Get_exit_status();
rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, status );
diff --git a/cpukit/sapi/src/exshutdown.c b/cpukit/sapi/src/exshutdown.c
index 2b99995..b81e8b5 100644
--- a/cpukit/sapi/src/exshutdown.c
+++ b/cpukit/sapi/src/exshutdown.c
@@ -44,8 +44,7 @@ void rtems_shutdown_executive(
_SMP_Request_other_cores_to_shutdown();
#endif
- _Per_CPU_Information[0].idle->Wait.return_code = result;
+ _Thread_Set_exit_status( result );
_System_state_Set( SYSTEM_STATE_SHUTDOWN );
_Thread_Stop_multitasking();
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 735b422..f545310 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -162,9 +162,6 @@ typedef struct {
/** This is the heir thread for this this CPU. */
Thread_Control *heir;
- /** This is the idle thread for this CPU. */
- Thread_Control *idle;
/** This is the time of the last context switch on this CPU. */
Timestamp_Control time_of_last_context_switch;
@@ -283,8 +280,6 @@ void _Per_CPU_Wait_for_state(
_Per_CPU_Information[bsp_smp_processor_id()].heir
#define _Thread_Executing \
_Per_CPU_Information[bsp_smp_processor_id()].executing
-#define _Thread_Idle \
- _Per_CPU_Information[bsp_smp_processor_id()].idle
#define _ISR_Nest_level \
_Per_CPU_Information[bsp_smp_processor_id()].isr_nest_level
#define _CPU_Interrupt_stack_low \
diff --git a/cpukit/score/inline/rtems/score/thread.inl b/cpukit/score/inline/rtems/score/thread.inl
index 681cfcc..b089c9b 100644
--- a/cpukit/score/inline/rtems/score/thread.inl
+++ b/cpukit/score/inline/rtems/score/thread.inl
@@ -344,6 +344,22 @@ RTEMS_INLINE_ROUTINE void _Thread_Internal_free (
_Objects_Free( &_Thread_Internal_information, &the_task->Object );
+RTEMS_INLINE_ROUTINE void _Thread_Set_exit_status( uint32_t exit_status )
+ Thread_Control *idle = (Thread_Control *)
+ _Thread_Internal_information.local_table[ 1 ];
+ idle->Wait.return_code = exit_status;
+RTEMS_INLINE_ROUTINE uint32_t _Thread_Get_exit_status( void )
+ const Thread_Control *idle = (const Thread_Control *)
+ return idle->Wait.return_code;
* This routine returns the C library re-enterant pointer.
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index a0279de..cc4282e 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -40,9 +40,11 @@ static inline void _Thread_Create_idle_helper(
int cpu
- Objects_Name name;
+ Per_CPU_Control *per_cpu;
+ Objects_Name name;
+ Thread_Control *idle;
+ per_cpu = &_Per_CPU_Information[ cpu ];
name.name_u32 = name_u32;
@@ -79,9 +81,8 @@ static inline void _Thread_Create_idle_helper(
* WARNING!!! This is necessary to "kick" start the system and
* MUST be done before _Thread_Start is invoked.
- _Per_CPU_Information[ cpu ].idle =
- _Per_CPU_Information[ cpu ].heir =
- _Per_CPU_Information[ cpu ].executing = idle;
+ per_cpu->heir =
+ per_cpu->executing = idle;
_Thread_Start(
idle,
diff --git a/testsuites/sptests/spsimplesched02/init.c b/testsuites/sptests/spsimplesched02/init.c
index 8b053b6..d4faa7a 100644
--- a/testsuites/sptests/spsimplesched02/init.c
+++ b/testsuites/sptests/spsimplesched02/init.c
@@ -21,6 +21,7 @@ void ObtainRelease(bool suspendIdle);
* Keep the names and IDs in global variables so another task can use them.
+rtems_id Idle_id;
rtems_id Task_id[ 3 ]; /* array of task ids */
rtems_name Task_name[ 3 ]; /* array of task names */
rtems_name Semaphore_name[ 2 ];
@@ -48,7 +49,7 @@ void ObtainRelease( bool suspendIdle )
if (suspendIdle) {
puts( "INIT - Suspend Idle Task");
- status = rtems_task_suspend( _Thread_Idle->Object.id );
+ status = rtems_task_suspend( Idle_id );
directive_failed( status, "rtems_task_suspend idle" );
@@ -62,7 +63,7 @@ void ObtainRelease( bool suspendIdle )
if (suspendIdle) {
puts( "INIT - Resume Idle Task");
- status = rtems_task_resume( _Thread_Idle->Object.id );
+ status = rtems_task_resume( Idle_id );
directive_failed( status, "rtems_task_resume idle" );
@@ -75,6 +76,14 @@ rtems_task Init(
puts( "\n\n*** SIMPLE SCHEDULER 02 TEST ***" );
+ status = _Objects_Name_to_id_u32(
+ &_Thread_Internal_information,
+ rtems_build_name( 'I', 'D', 'L', 'E' ),
+ RTEMS_SEARCH_LOCAL_NODE,
+ &Idle_id
+ rtems_test_assert( status == RTEMS_SUCCESSFUL );
* Create the semaphore. Then obtain and release the
* semaphore with no other tasks running.
1.7.7
