[PATCH 2/4] score: Remove idle field of Per_CPU_Control
Wed May 29 19:14:46 UTC 2013
I think the use of _Objects_Name_to_id_u32 should be
calling rtems_task_ident.
On 5/29/2013 10:31 AM, Sebastian Huber wrote:
> diff --git a/testsuites/sptests/spsimplesched02/init.c b/testsuites/sptests/spsimplesched02/init.c
> index 8b053b6..d4faa7a 100644
> --- a/testsuites/sptests/spsimplesched02/init.c
> +++ b/testsuites/sptests/spsimplesched02/init.c
> @@ -21,6 +21,7 @@ void ObtainRelease(bool suspendIdle);
>    *  Keep the names and IDs in global variables so another task can use them.
> +rtems_id   Idle_id;
>   rtems_id   Task_id[ 3 ];         /* array of task ids */
>   rtems_name Task_name[ 3 ];       /* array of task names */
>   rtems_name Semaphore_name[ 2 ];
> @@ -48,7 +49,7 @@ void ObtainRelease( bool suspendIdle )
>     if (suspendIdle) {
>       puts( "INIT - Suspend Idle Task");
> -    status = rtems_task_suspend( _Thread_Idle->Object.id );
> +    status = rtems_task_suspend( Idle_id );
>       directive_failed( status, "rtems_task_suspend idle" );
> @@ -62,7 +63,7 @@ void ObtainRelease( bool suspendIdle )
>     if (suspendIdle) {
>       puts( "INIT - Resume Idle Task");
> -    status = rtems_task_resume( _Thread_Idle->Object.id );
> +    status = rtems_task_resume( Idle_id );
>       directive_failed( status, "rtems_task_resume idle" );
> @@ -75,6 +76,14 @@ rtems_task Init(
>     puts( "\n\n*** SIMPLE SCHEDULER 02 TEST ***" );
> +  status = _Objects_Name_to_id_u32(
> +    &_Thread_Internal_information,
> +    rtems_build_name( 'I', 'D', 'L', 'E' ),
> +    RTEMS_SEARCH_LOCAL_NODE,
> +    &Idle_id
> +  rtems_test_assert( status == RTEMS_SUCCESSFUL );
>      * Create the semaphore. Then obtain and release the
>      * semaphore with no other tasks running.
