[PATCH 1/9] dosfs: UTF-8 Support: UI, backwards compatibility
Gedare Bloom
gedare at rtems.org
Fri May 31 15:05:33 UTC 2013
OK my mistakes. I had trouble telling what is public or private.
On Fri, May 31, 2013 at 11:00 AM, Sebastian Huber
> On 05/31/2013 04:47 PM, Gedare Bloom wrote:
>> On Fri, May 31, 2013 at 9:42 AM, Ralf Kirchner
>> <ralf.kirchner at embedded-brains.de> wrote:
>>> >@@ -25,6 +28,170 @@
>>> > extern "C" {
>>> > #endif
>>> >+typedef struct rtems_dosfs_convert_control rtems_dosfs_convert_control;
>> I think it is usual to put the struct definition before the function
>> prototypes in header files. I don't know if we have any rule about it
>> though.
> Its the first declaration in the file, so it is before the function
> prototypes.
>>> >@@ -131,6 +309,9 @@ int msdos_format (
>>> >+int rtems_dosfs_initialize(rtems_filesystem_mount_table_entry_t
>>> > *mt_entry,
>>> >+ const void *data);
>> Can you give doxygen for this function now too? I know it did not have
>> it, but it might be helpful.
> Its explicitly outside of the Doxygen group, because this function is not
> part of the public interface.
>>> >+ rtems_dosfs_convert_control *converter;
>>> > } msdos_fs_info_t;
>> Please add a comment about the converter field.
>> Why no doxygen comments for these new functions?
> All this stuff is not part of the public interface.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> rtems-devel mailing list
> rtems-devel at rtems.org
