affinity tests
Fri Nov 8 15:46:22 UTC 2013
Following up on Jennifer. The "real functional" tests
require SMP to be enabled. But cpu_set_t manipulation
and the pthread_attr methods are always available.
Newlib doesn't know SMP vs. non-SMP.
So the basic tests of cpu_set_t and pthread_attr_XXX_np
are what we are talking about.
Tests which check that the affinity requested is honored
is a different matter. [And may require knowing which
CPU you are running on.. hmm.. have to think more about
testing affinity.]
--joel
On 11/8/2013 9:38 AM, Jennifer Averett wrote:
> Since the header information is in newlib it will always be there.
> Where should the affinity tests be added?
> A)      In the smp tests and change the smptests so those are always
> compiled
> B)      In psxtests
> Any other suggestions?
> Jennifer Averett
> On-Line Applications Research
> 256-319-2752
