affinity tests
Fri Nov 8 15:54:28 UTC 2013
pthread_attr can go in psxtests, cpu_set_t with 1 cpu can go in sptests.
SMP-aware versions should go in smptests, which should continue to be
conditional on --enable-smp switch.
There may need to be some psxsmptests in the future. They could
perhaps be integrated in the psxtests directory.
On Fri, Nov 8, 2013 at 10:46 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Following up on Jennifer. The "real functional" tests
> require SMP to be enabled. But cpu_set_t manipulation
> and the pthread_attr methods are always available.
> Newlib doesn't know SMP vs. non-SMP.
> So the basic tests of cpu_set_t and pthread_attr_XXX_np
> are what we are talking about.
> Tests which check that the affinity requested is honored
> is a different matter. [And may require knowing which
> CPU you are running on.. hmm.. have to think more about
> testing affinity.]
> --joel
> On 11/8/2013 9:38 AM, Jennifer Averett wrote:
>> Since the header information is in newlib it will always be there.
>> Where should the affinity tests be added?
>> A)      In the smp tests and change the smptests so those are always
>> compiled
>> B)      In psxtests
>> Any other suggestions?
>> Jennifer Averett
>> On-Line Applications Research
>> 256-319-2752
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> rtems-devel mailing list
> rtems-devel at rtems.org
