Proposed Pthread affinity APIs
Tue Nov 12 19:15:17 UTC 2013
Good catch Sebastian. _GNU_SOURCE is definitely the "standard"
non-standard way of getting this non-portable behavior.
On Tue, Nov 12, 2013 at 2:13 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Sorry. Missed a major point.
> _GNU_SOURCE is transformed into multiple other
> defines in features.h in glibc.
> #ifdef  _GNU_SOURCE
> # define __USE_GNU      1
> #endif
> Our sys/features.h does not have the comparable
> ifdef. We are likely missing others as it turns
> on about ten other feature flags in the glibc
> features.h.
> I guess we need to follow this pattern and add
> _GNU_SOURCE to our sys/features.h. The others
> need another round of thought.
> --joel
> On 11/12/2013 1:02 PM, Joel Sherrill wrote:
>> On 11/12/2013 12:32 PM, Sebastian Huber wrote:
>>> On 11/12/2013 03:11 PM, Joel Sherrill wrote:
>>>> On 11/12/2013 2:27 AM, Sebastian Huber wrote:
>>>>>> On 2013-11-11 21:30, Jennifer Averett wrote:
>>>>>>>> @@ -206,6 +206,24 @@
>>>>>>>>   int   _EXFUN(pthread_attr_setguardsize,
>>>>>>>>         (pthread_attr_t *__attr, size_t __guardsize));
>>>>>>>> +#if defined(__USE_GNU) && defined(__rtems__)
>>>>>>>> +/* POSIX thread APIs beyond the POSIX standard but provided in RTEMS
>>>>>>>> + * for compatibility with GNU/Linux.
>>>>>> Who is supposed to define this __USE_GNU?
>>>> The application or implementation before including
>>>> the header files.  This is common practice and how
>>>> it is done in /usr/include/pthread.h on GNU/Linux.
>>>> http://man7.org/linux/man-pages/man3/pthread_attr_setaffinity_np.3.html
>>>> There are also other constants like thus __USE_XOPEN2K, __USE_BSD,
>>>> and __USE_XOPEN2K8 are pretty common. It is similar to the STDC
>>>> one but that's usually tripped by gcc, while these are application
>>>> choices on what library API standard to adhere to.
>>>> Sorry to sound pendantic but this is the common practice.
>>> Yes, exactly this is why I asked.  In the man page you have:
>>> *#define _GNU_SOURCE */* See feature_test_macros(7) */
>>> *#include <pthread.h>*
>>> You use __USE_GNU.
>> /usr/include/pthread.h on Linux has __USE_GNU.  I don't
>> see a _USE_GNU in the .h files.
>> feature_test_macros(7) uses all _ versions.
>> I would guess the std C version is adding it.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> rtems-devel mailing list
> rtems-devel at rtems.org
