RFC: Submitting cpuset.h to newlib by itself
Thu Nov 14 15:15:25 UTC 2013
On 2013-11-14 16:10, Joel Sherrill wrote:
> On 11/14/2013 9:06 AM, Sebastian Huber wrote:
>> >On 2013-11-14 15:58, Jennifer Averett wrote:
>>> >>Line 64 of the last cpuset that was sent out:
>>> >>/* Define the cpu set structure */
>>> >>typedef struct _cpuset {
>>> >>    cpu_set_word_t __bits[_NCPUWORDS];
>>> >>} cpu_set_t;
>> >Ok, this is the Linux naming.  FreeBSD uses cpuset_t:
>> >http://www.freebsd.org/cgi/man.cgi?query=pthread_attr_affinity_np&sektion=3&apropos=0&manpath=FreeBSD+9.2-RELEASE
>> >Maybe we should add
>> >typedef cpu_set_t cpuset_t;
> Even if we do this, I don't think the APIs for setting
> affinity attributes can co-exist for BSD and Linux.
> I recall some cpuset method conflicts.
> If they don't conflict, I don't particularly have a problem
> with adding it in a follow up.
> Can you provide links to the ones you want to try to
> add?
Ok, sorry for the disturbance.  We can add this later on demand.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
