Red-Black-Tree for Priority Queues
Fri Nov 15 17:12:38 UTC 2013
The current implementation has a bounded maximum
execution time. Does the Red-Black Tree have that
guarantee?
Technically the code to unroll the loop could be
deleted. In either case, how long would interrupts
have to be disabled?
On 11/15/2013 11:00 AM, Sebastian Huber wrote:
> Hello,
> I consider to replace the current priority queue implementation used for thread
> queues (not the scheduler ready queue) with red-black trees.  Currently we use
> four chains and linear operations in the corresponding priority subset.  A
> red-black tree root can be reduced to at most four pointers.  The four chain
> controls need twelve pointers in contrast.  It helps also to simplify complex
> functions like _Thread_queue_Enqueue_priority() which use _ISR_Flash().  Usage
> of _ISR_Flash() will be highly problematic in case we introduce fine grained
> locking for SMP.
> I have a question regarding the current red-black tree implementation.  In case
> the key to insert is already present (multiple) times in the tree, are there
> ordering guarantees with respect to the nodes with the same key?  Can I for
> example insert a key so that the new node is minimal/maximal with respect to
> the existing nodes with the same key value?
