Thread Execution Control
Thu Nov 21 10:52:40 UTC 2013
On 2013-11-20 17:46, Gedare Bloom wrote:
> On Wed, Nov 20, 2013 at 7:19 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> the following text tries to explain a problem with the current SMP
>> implementation and presents one possible solution.
>> ==== Thread Execution Control ====
>> Currently threads are assigned to processors for execution by the scheduler
>> responsible for this thread.  It is unknown to the system when a thread
>> actually starts or terminates execution.  The termination event is important
>> for the following features
>> * explicit thread migration, e.g. if a thread should move from one scheduler
>> domain to another,
>> * thread deletion, since the thread stack is in use until the thread stopped
>> execution, or
>> * restart of threads executing on a remote processor.
> Restating what you just said, the problem you have is that thread
> start and termination/migration is not represented explicitly to the
> scheduler, for example the task state transitions diagram
> http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Scheduling-Concepts-Task-State-Transitions.html#Scheduling-Concepts-Task-State-Transitions
> contains "deletion" events, but those events appear to be regular
> 'block' calls from the scheduler.
The scheduler can give commands like "execute this thread on processor X", but
such a command will only be carried out with some delay, e.g. due to a
necessary inter-processor interrupt.
> One exception I have to this summary is that there is in fact a hook
> already for when a thread terminates, which is _Scheduler_Free().
The problem is to get a safe context for _Scheduler_Free().
> Possibly this hook is not able to be overloaded for the requirements
> stated below. Especially for the case of migration rather than
> termination, when a thread leaves one scheduling domain to go to
> another. (However, from the prior discussion, will there be such
> cases? Partitioned/Clustered schedulers do not support migrations
> usually.)
For the MrsP suggested by Burns and Wellings we will allow migration between
scheduler instances of the same kind.
>> One approach could be to spin on the per-processor variable reflecting the
>> executing thread.  This has at least two problems
>> # it doesn't work if the executing thread wants to alter its own state, and
>> # this spinning must be done with the scheduler lock held and interrupts
>> disabled, this is a disaster for the interrupt latency,
> I don't understand this approach at all, but you dismiss it anyway so
> I won't try harder.
Spinning may be still an option in some cases if we use a thread generation
counter as indicator.
>> The proposed solution is to use an optional event handler which is active in
>> case the thread execution termination matters.  In _Thread_Dispatch() we
> Will this event handler be per-thread, per-cpu, or per-scheduler instance?
The scheduler needs such a handler item for each owned processor.
>> have
>> already the post-switch extensions invoked after a thread switch.  The only
>> restriction is here that we cannot block since the executing thread might be
>> an
>> idle thread and it would be dramatic for the thread dispatch latency.  We
>> can
>> now on demand prepend an event handler to the post-switch extensions and
> Is it possible to communicate the previously executing thread to this
> new handler? When post-switch executes, the thread that was switched
> out is no longer known.
The new post-switch handler will have a context pointer which can be used to
retrieve this information.
>> perform
>> the actions necessary after the thread of interest stopped execution.
>> Currently the post-switch extensions are registered in a global list, but we
>> have to introduce per-processor lists for our purpose.  This gives rise to
> What will be the purpose of these lists? Dynamically adding/remove
> per-cpu post-switch events?
Yes, the overhead by post-switch handlers is significant so in order to improve
the average-case it makes sense to dynamically add/remove them.
>> locking issues.  We have to consider the following requirements
>> * prepending to and removal from the list should be performed under
>> protection of the per-processor lock,
>> * forward iteration through the list should be possible without locking
>> (atomic operations are required here),
>> * removal of nodes during iteration must be possible,
>> * it is acceptable that nodes added after iteration begin are not visited
>> during the iteration in progress.
> Sounds like a good use for something like RCU, but not RCU, since
> AFAIK that is patent-encumbered in a non-RTEMS friendly way.
I think the only critical part is the forward iteration.  Here we have to be
careful in the prepend to update the pointers in the right order.
>> The execution time of post-switch event handlers increases the worst-case
>> On demand post-switch handlers help to implement the Multiprocessor Resource
>> Sharing Protocol (MrsP) proposed by Burns and Wellings.  Threads executing a
>> global critical section can add a post-switch handler which will trigger the
>> thread migration in case of pre-emption by a local high-priority thread.
> This is interesting. The requirement "the supporting RTOS must be
> aware that there is a separate priority associated with each processor
> in the thread’s affinity set" implies a bit of added complexity and
> shared data in the scheduling logic, in addition to support for thread
> migration. I could see migration within a cluster being useful with
> this sharing protocol; I'm not sure how it will work with a fixed
> partitioned scheduler.
We will do benchmarks for this MrsP locking protocol, at the moment its just an
interesting option.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
