[PATCH 3/3] bsp/leon3: Console driver changes
Tue Nov 26 08:19:36 UTC 2013
Move declaration of global variables and functions to <leon.h> header
file.  Make several global variables and functions static.
 c/src/lib/libbsp/sparc/leon3/console/console.c     |   73 ++++----------------
 .../libbsp/sparc/leon3/console/printk_support.c    |   14 +---
 c/src/lib/libbsp/sparc/leon3/include/leon.h        |   37 ++++++++++
 3 files changed, 56 insertions(+), 68 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
index 1860e5c..7e72633 100644
--- a/c/src/lib/libbsp/sparc/leon3/console/console.c
+++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
@@ -31,42 +31,11 @@
 #include <assert.h>
 #include <rtems/bspIo.h>
-#include <amba.h>
+#include <leon.h>
 #include <rtems/termiostypes.h>
-/* Let user override which on-chip APBUART will be debug UART
- * 0 = Default APBUART. On MP system CPU0=APBUART0, CPU1=APBUART1...
- * 1 = APBUART[0]
- * 2 = APBUART[1]
- * 3 = APBUART[2]
 int syscon_uart_index __attribute__((weak)) = 0;
- *  apbuart_outbyte_polled
- *  This routine transmits a character using polling.
-extern void apbuart_outbyte_polled(
-  struct apbuart_regs *regs,
-  unsigned char ch,
-  int do_cr_on_newline,
-  int wait_sent
-/* body is in printk_support.c */
- *  apbuart_inbyte_nonblocking
- *  This routine polls for a character.
-extern int apbuart_inbyte_nonblocking(struct apbuart_regs *regs);
 /* body is in debugputs.c */
 struct apbuart_priv {
@@ -154,15 +123,13 @@ static int leon3_console_write_support(int minor, const char *buf, size_t len)
 #else
- * Prototypes to avoid warnings
-ssize_t console_write_polled(int minor, const char *buf, size_t len);
-int console_pollRead(int minor);
  *  Console Termios Support Entry Points
+static ssize_t leon3_console_write_polled(
+  int minor,
+  const char *buf,
+  size_t len
   struct apbuart_priv *uart = leon3_console_get_uart(minor);
   int nwrite = 0;
@@ -174,7 +141,7 @@ ssize_t console_write_polled(int minor, const char *buf, size_t len)
   return nwrite;
+static int leon3_console_pollRead(int minor)
@@ -183,15 +150,7 @@ int console_pollRead(int minor)
 #endif
-int console_set_attributes(int minor, const struct termios *t);
-int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg);
-int console_scan_uarts(void);
+static int leon3_console_set_attributes(int minor, const struct termios *t)
   unsigned int scaler;
@@ -259,7 +218,7 @@ int console_set_attributes(int minor, const struct termios *t)
 /* AMBA PP find routine. Extract AMBA PnP information into data structure. */
+static int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
   struct ambapp_apb_info *apb = (struct ambapp_apb_info *)dev->devinfo;
@@ -281,15 +240,13 @@ int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
 /* Find all UARTs */
+static void leon3_console_scan_uarts(void)
   memset(apbuarts, 0, sizeof(apbuarts));
   /* Find APBUART cores */
   ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS), VENDOR_GAISLER,
                   GAISLER_APBUART, find_matching_apbuart, NULL);
-  return uarts;
@@ -310,7 +267,7 @@ rtems_device_driver console_initialize(
   rtems_termios_initialize();
   /* Find UARTs */
-  console_scan_uarts();
+  leon3_console_scan_uarts();
   /* Update syscon_uart_index to index used as /dev/console
    * Let user select System console by setting syscon_uart_index. If the
@@ -429,7 +386,7 @@ rtems_device_driver console_open(
     leon3_console_last_close,    /* lastClose */
     NULL,                        /* pollRead */
     leon3_console_write_support, /* write */
-    console_set_attributes,      /* setAttributes */
+    leon3_console_set_attributes,/* setAttributes */
     NULL,                        /* stopRemoteTx */
     NULL,                        /* startRemoteTx */
     1                            /* outputUsesInterrupts */
@@ -439,9 +396,9 @@ rtems_device_driver console_open(
   static const rtems_termios_callbacks Callbacks = {
     leon3_console_first_open,    /* firstOpen */
     NULL,                        /* lastClose */
-    console_pollRead,            /* pollRead */
-    console_write_polled,        /* write */
+    leon3_console_pollRead,      /* pollRead */
+    leon3_console_write_polled,  /* write */
     0                            /* outputUsesInterrupts */
diff --git a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
index 9815053..ecc44b6 100644
--- a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
+++ b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
@@ -16,28 +16,22 @@
 #include <bsp.h>
+#include <leon.h>
 #include <rtems/libio.h>
 #include <assert.h>
- * 1 = APBUART[0]
- * 2 = APBUART[1]
- * 3 = APBUART[2]
 int debug_uart_index __attribute__((weak)) = 0;
-struct apbuart_regs *dbg_uart = NULL;
+static struct apbuart_regs *dbg_uart = NULL;
 /* Before UART driver has registered (or when no UART is available), calls to
  * printk that gets to bsp_out_char() will be filling data into the
  * pre_printk_dbgbuf[] buffer, hopefully the buffer can help debugging the
  * early BSP boot.. At least the last printk() will be caught.
-char pre_printk_dbgbuf[32] = {0};
-int pre_printk_pos = 0;
+static char pre_printk_dbgbuf[32] = {0};
+static int pre_printk_pos = 0;
 /* Initialize the BSP system debug console layer. It will scan AMBA Plu&Play
  * for a debug APBUART and enable RX/TX for that UART.
diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
index 42c47d6..3b1ef8a 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
@@ -267,6 +267,43 @@ static inline unsigned int leon_r32_no_cache(uintptr_t addr)
 	return tmp;
+/* Let user override which on-chip APBUART will be debug UART
+ * 0 = Default APBUART. On MP system CPU0=APBUART0, CPU1=APBUART1...
+ * 1 = APBUART[0]
+ * 2 = APBUART[1]
+ * 3 = APBUART[2]
+extern int syscon_uart_index;
+ * 1 = APBUART[0]
+ * 2 = APBUART[1]
+ * 3 = APBUART[2]
+extern int debug_uart_index;
+ *  apbuart_outbyte_polled
+ *  This routine transmits a character using polling.
+void apbuart_outbyte_polled(
+  struct apbuart_regs *regs,
+  unsigned char ch,
+  int do_cr_on_newline,
+  int wait_sent
+ *  apbuart_inbyte_nonblocking
+ *  This routine polls for a character.
+int apbuart_inbyte_nonblocking(struct apbuart_regs *regs);
 #endif /* !ASM */
 #ifdef __cplusplus
1.7.7
