[PATCH 1/2] cpu part of the virtualization layer for i386
Philipp Eppelt philipp.eppelt at mailbox.tu-dresden.de
Wed Nov 27 22:55:45 UTC 2013
 cpukit/score/cpu/i386/Makefile.am                  |  1 +
 cpukit/score/cpu/i386/cpu.c                        | 20 +++++
 cpukit/score/cpu/i386/preinstall.am                |  4 +
 cpukit/score/cpu/i386/rtems/score/cpu.h            | 50 ++++++++++---
 cpukit/score/cpu/i386/rtems/score/interrupts.h     | 31 ++++++++
 .../cpu/i386/rtems/score/virtualizationlayercpu.h  | 85 ++++++++++++++++++++++
 6 files changed, 179 insertions(+), 12 deletions(-)
 create mode 100644 cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h
diff --git a/cpukit/score/cpu/i386/Makefile.am b/cpukit/score/cpu/i386/Makefile.am
index e35a81c..8f196c5 100644
--- a/cpukit/score/cpu/i386/Makefile.am
+++ b/cpukit/score/cpu/i386/Makefile.am
@@ -12,6 +12,7 @@ include_rtems_score_HEADERS += rtems/score/registers.h
 include_rtems_score_HEADERS += rtems/score/idtr.h
 include_rtems_score_HEADERS += rtems/score/cpuatomic.h
 include_rtems_score_HEADERS += rtems/score/cpusmplock.h
+include_rtems_score_HEADERS += rtems/score/virtualizationlayercpu.h
 noinst_LIBRARIES = libscorecpu.a
 libscorecpu_a_SOURCES = cpu.c cpu_asm.S
diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
index c87a76d..4dd44bb 100644
--- a/cpukit/score/cpu/i386/cpu.c
+++ b/cpukit/score/cpu/i386/cpu.c
@@ -26,6 +26,10 @@
 #include <rtems/bspIo.h>
+#if defined(RTEMS_PARAVIRT)
+#include <rtems/score/virtualizationlayercpu.h>
+#endif
 void _CPU_Initialize(void)
 #if CPU_HARDWARE_FP
@@ -97,6 +101,20 @@ uint32_t   _CPU_ISR_Get_level( void )
   return level;
+void *_CPU_Thread_Idle_body( uintptr_t ignored )
+  while(1)
+    _CPU_Virtual_idle_thread();
+  return NULL;
+#else
   while(1){
@@ -105,6 +123,8 @@ void *_CPU_Thread_Idle_body( uintptr_t ignored )
   return NULL;
+#endif /*RTEMS_PARAVIRT*/
 struct Frame_ {
 	struct Frame_  *up;
 	uintptr_t		pc;
diff --git a/cpukit/score/cpu/i386/preinstall.am b/cpukit/score/cpu/i386/preinstall.am
index f9faf87..363e1fb 100644
--- a/cpukit/score/cpu/i386/preinstall.am
+++ b/cpukit/score/cpu/i386/preinstall.am
@@ -59,3 +59,7 @@ $(PROJECT_INCLUDE)/rtems/score/cpusmplock.h: rtems/score/cpusmplock.h $(PROJECT_
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpusmplock.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpusmplock.h
+$(PROJECT_INCLUDE)/rtems/score/virtualizationlayercpu.h: rtems/score/virtualizationlayercpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/virtualizationlayercpu.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/virtualizationlayercpu.h
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 43422ed..4e509b7 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -35,6 +35,10 @@ extern "C" {
 #include <rtems/score/registers.h>	/* formerly part of libcpu */
 #endif
+#endif
 /* conditional compilation parameters */
 #define CPU_INLINE_ENABLE_DISPATCH       TRUE
@@ -376,11 +380,22 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
 #define _CPU_ISR_Flash( _level )   i386_flash_interrupts( _level )
-#define _CPU_ISR_Set_level( _new_level ) \
-    if ( _new_level ) __asm__ volatile ( "cli" ); \
-    else              __asm__ volatile ( "sti" ); \
+  #define _CPU_ISR_Set_level( _new_level ) \
+      if( _new_level )  _CPU_Virtual_Interrupts_close(); \
+      else		_CPU_Virtual_Interrupts_open(); \
+#else
+      if ( _new_level ) __asm__ volatile ( "cli" ); \
+      else              __asm__ volatile ( "sti" ); \
 uint32_t   _CPU_ISR_Get_level( void );
@@ -497,16 +512,27 @@ uint32_t   _CPU_ISR_Get_level( void );
  *    + disable interrupts and halt the CPU
-#define _CPU_Fatal_halt( _error ) \
+  #define _CPU_Fatal_halt( _error ) \
-    uint32_t _error_lvalue = ( _error ); \
-    __asm__ volatile ( "cli ; \
-                    movl %0,%%eax ; \
-                    hlt" \
-                    : "=r" ((_error_lvalue)) : "0" ((_error_lvalue)) \
+    _CPU_Virtual_Interrupts_close(); \
+    _CPU_Virtual_exec_stop_error( _error ); \
+#else
+      uint32_t _error_lvalue = ( _error ); \
+      __asm__ volatile ( "cli ; \
+                      movl %0,%%eax ; \
+                      hlt" \
+                      : "=r" ((_error_lvalue)) : "0" ((_error_lvalue)) \
 #endif /* ASM */
 /* end of Fatal Error manager macros */
diff --git a/cpukit/score/cpu/i386/rtems/score/interrupts.h b/cpukit/score/cpu/i386/rtems/score/interrupts.h
index bed6330..8d47ea5 100644
--- a/cpukit/score/cpu/i386/rtems/score/interrupts.h
+++ b/cpukit/score/cpu/i386/rtems/score/interrupts.h
@@ -33,6 +33,36 @@ typedef int  (*rtems_raw_irq_is_enabled)	(const struct __rtems_raw_irq_connect_d
+  #include <rtems/score/virtualizationlayercpu.h>
+#define i386_disable_interrupts( _level ) \
+    _CPU_Virtual_Interrupts_disable( _level ); \
+#define i386_enable_interrupts( _level )  \
+    _CPU_Virtual_Interrupts_enable( _level ); \
+#define i386_flash_interrupts( _level ) \
+    _CPU_Virtual_Interrupts_enable(_level); \
+    _CPU_Virtual_Interrupts_disable(_level); \
+#define i386_get_interrupt_level( _level ) \
+    _CPU_Virtual_Interrupts_get_level( _level ); \
+#define _CPU_ISR_Disable( _level ) i386_disable_interrupts( _level )
+#define _CPU_ISR_Enable( _level ) i386_enable_interrupts( _level )
+#else /*RTEMS_PARAVIRT*/
@@ -75,6 +105,7 @@ typedef int  (*rtems_raw_irq_is_enabled)	(const struct __rtems_raw_irq_connect_d
 #endif
diff --git a/cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h b/cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h
new file mode 100644
index 0000000..ce269fa
--- /dev/null
+++ b/cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h
@@ -0,0 +1,85 @@
+ * COPYRIGHT (c) 2013 Philipp Eppelt.
+ *    philipp.eppelt at mailbox.tu-dresden.de
+ * Purpose:   CPU part of the virtualization layer.
+ * Licencse:  see RTEMS License.
+#ifndef RTEMS_VIRT_LAYER_CPU_H
+#define RTEMS_VIRT_LAYER_CPU_H
+#ifndef ASM
+/* Interrupts */
+ * \brief Requests an interrupt vector.
+int
+_CPU_Virtual_Irq_request( int vector );
+ * \brief Releases an interrupt vector.
+void
+_CPU_Virtual_Irq_detach( int vector );
+ * \brief Enables interrupt delivery or sets it to the specified level.
+ * Use this function in collaboration with _CPU_Virtual_Interrupts_disable and
+ * use its returned _level as argument to this function to assure proper
+ * behaviour.
+void
+_CPU_Virtual_Interrupts_enable( int _level );
+ * \brief Disables interrupt delivery and returns the previous level.
+void
+_CPU_Virtual_Interrupts_disable( int _level );
+ * \brief Enables and directly disables interrupt delivery.
+void
+_CPU_Virtual_Interrupts_flash( int _level );
+ * \brief Requests the current interrupt level.
+int
+_CPU_Virtual_Interrupts_get_level( int _level );
+void
+_CPU_Virtual_Interrupts_open(void);
+void
+_CPU_Virtual_Interrupts_close( void );
+/* Idle Thread */
+ * \brief Lowest priority thread, doing nothing, never returns;
+void
+_CPU_Virtual_idle_thread( void );
+/* Error handling */
+ * \brief Handlers execution errors.
+void
+_CPU_Virtual_exec_stop_error( int _error );
+#endif /* ASM */
+#endif /* RTEMS_VIRT_LAYER_CPU_H */
1.8.1.4
