[PATCH] Mongoose HTTPd from 3.2 to 3.9 (last commit before MIT -> GPL)
Nick Withers
nick.withers at anu.edu.au
Wed Nov 27 23:33:41 UTC 2013
Just a ping, if anyone's got time to test :-)
Also, WebSockets are cool.
Nick Withers
Embedded Systems Programmer
Room 2.26, Building 57
Department of Nuclear Physics
Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
eMail: nick.withers at anu.edu.au
Phone: +61 2 6125 2091
Mobile: +61 414 397 446
On Fri, 2013-11-08 at 09:43 +1100, Nick Withers wrote:
> On Thu, 2013-11-07 at 09:12 -0500, Gedare Bloom wrote:
> > Hi Nick,
> > I don't have a network-capable RTEMS setup at the moment, so I can't
> > test/commit. However, have you tested the patched version? What RTEMS
> > version (HEAD?) did you use, and what BSP?
> Current Git master, yeah, with the PowerPC MVME3100.
> I haven't tested extensively (just basic pages and that WebSockets work
> when USE_WEBSOCKET's defined at build time (I'll try to figure out some
> autotools to get --enable-httpd-websocket or something going)) and it'd
> be good if someone else could check it, too.
> I'm not sure that "static"ing mg_connect(), mg_url_encode() and
> mg_vprintf() was necessarily the right thing to do it the later patch,
> either. Perhaps they're supposed to be exposed through mongoose.h,
> instead?
> > -Gedare
> > On Thu, Nov 7, 2013 at 5:28 AM, Nick Withers <nick.withers at anu.edu.au> wrote:
> > > On Thu, 2013-11-07 at 17:59 +1100, Nick Withers wrote:
> > >> Hey all,
> > >> The following patch updates the Mongoose HTTP server from 3.2 to 3.9, at
> > >> the last point before the MIT -> GPL license change (going off the
> > >> author's confirmation at https://groups.google.com/forum/#!
> > >> topic/mongoose-users/aafbOnHonkI ).
> > > The attached restores the sys/select.h include and static-ifies some
> > > functions to kill warnings.
> > >> ____
> > >> From 76c451c9d101068dee796b715d2201d6956b0347 Mon Sep 17 00:00:00 2001
> > >> From: Nick Withers <nick.withers at anu.edu.au>
> > >> Date: Thu, 7 Nov 2013 17:46:54 +1100
> > >> Subject: [PATCH] Update to Mongoose 3.9 at the last point before the MIT ->
> > >> GPL license change
> > >> [See https://groups.google.com/forum/#!topic/mongoose-users/aafbOnHonkI regarding license change]
> > >> The RTEMS patches described in the following emails and made to the previous Mongoose base have been applied:
> > >> - http://www.rtems.org/pipermail/rtems-devel/2012-July/001345.html
> > >> - http://www.rtems.org/pipermail/rtems-devel/2012-July/001343.html
> > >> - http://www.rtems.org/pipermail/rtems-devel/2012-July/001346.html (except to mongoose.1, see below)
> > >> ...as well as a patch very similar to that discussed at http://forums.bannister.org/ubbthreads.php?ubb=showflat&topic=7600&gonew=1 to provide poll() (which might be able to go away soon, with incoming RTEMS poll() support)
> > >> mongoose.1 appears to have been removed from the upstream distribution.
> > >> Note that the short form of options (e.g., "u" instead of "run_as_user") are no longer available (upstream)
> > > (snip)
> > >> ____
> > >> Anyone keen to commit it? Perhaps killing the man page isn't the way to
> > >> go?
> > >> My personal motivation is that I want to use (or at least, investigate)
> > >> WebSockets, which aren't supported by Mongoose 3.2.
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20131128/1238ac52/attachment.bin>
