[PATCH] Mongoose HTTPd from 3.2 to 3.9 (last commit before MIT -> GPL)
Fri Nov 29 12:00:42 UTC 2013
Hello Nick,
it seems that there was again an API change.  Can you please build with
"--enable-tests" and fix the errors below.  Can you please also run this test
and make sure it passes.
Making all in mghttpd01
gmake[6]: Entering directory
`/scratch/git-rtems-testing/rtems/build-sparc-leon3_qemu-rtems/sparc-rtems4.11/c/leon3_qemu/testsuites/libtests/mghttpd01'
../../../../../../tools/build/rtems-bin2c -C
../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01/init_fs.tar init_fs
../../../../../../tools/build/rtems-bin2c -H
gmake  all-am
gmake[7]: Entering directory
sparc-rtems4.11-gcc -B../../../../../leon3_qemu/lib/ -specs bsp_specs -qrtems
-DHAVE_CONFIG_H -I.
-I../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01 -I..
-I../../../../../../../rtems/c/src/../../testsuites/libtests/../support/include
   -mcpu=leon3 -msoft-float -O0 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT init.o
-MD -MP -MF .deps/init.Tpo -c -o init.o
../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01/init.c
-DHAVE_CONFIG_H -I.
init_fs.o -MD -MP -MF .deps/init_fs.Tpo -c -o init_fs.o init_fs.c
-DHAVE_CONFIG_H -I.
test-http-client.o -MD -MP -MF .deps/test-http-client.Tpo -c -o
test-http-client.o
../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01/test-http-client.c
mv -f .deps/init_fs.Tpo .deps/init_fs.Po
../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01/init.c:90:18:
warning: 'enum mg_event' declared inside parameter list [enabled by default]
      const struct mg_request_info *request_info)
warning: its scope is only this definition or declaration, which is probably
not what you want [enabled by default]
../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01/init.c:88:37:
error: parameter 1 ('event') has incomplete type
  static void *callback(enum mg_event event,
../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01/init.c:88:14:
warning: function declaration isn't a prototype [-Wstrict-prototypes]
../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01/init.c: In
function 'callback':
../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01/init.c:92:16:
error: 'MG_NEW_REQUEST' undeclared (first use in this function)
    if (event == MG_NEW_REQUEST) {
note: each undeclared identifier is reported only once for each function it
appears in
mv -f .deps/test-http-client.Tpo .deps/test-http-client.Po
function 'test_mongoose':
../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01/init.c:192:10:
warning: passing argument 1 of 'mg_start' from incompatible pointer type
    struct mg_context *mg1 = mg_start(&callback, NULL, options);
In file included from
../../../../../../../rtems/c/src/../../testsuites/libtests/mghttpd01/init.c:26:0:
../../../../../leon3_qemu/lib/include/mghttpd/mongoose.h:154:20: note: expected
'const struct mg_callbacks *' but argument is of type 'void * (*)()'
  struct mg_context *mg_start(const struct mg_callbacks *callbacks,
gmake[7]: *** [init.o] Error 1
gmake[7]: Leaving directory
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
