[PATCH] score: Minor _Thread_Executing() optimization
    Gedare Bloom
    gedare at rtems.org
    Sat Nov 30 01:29:36 UTC 2013
Sure makes sense.
On Fri, Nov 29, 2013 at 5:15 AM, Sebastian Huber
> It is not necessary to load the excecuting thread control again after
> the context switch since it is an invariant of the executing thread.
>  cpukit/score/src/threaddispatch.c |    3 +--
>  1 files changed, 1 insertions(+), 2 deletions(-)
> diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
> index 0c8298f..ecf6810 100644
> --- a/cpukit/score/src/threaddispatch.c
> +++ b/cpukit/score/src/threaddispatch.c
> @@ -156,12 +156,11 @@ void _Thread_Dispatch( void )
>  #endif
> -     * We have to obtain these values again after the context switch since the
> +     * We have to obtain this value again after the context switch since the
>       * heir thread may have migrated from another processor.  Values from the
>       * stack or non-volatile registers reflect the old execution environment.
>      per_cpu = _Per_CPU_Get();
> -    executing = per_cpu->executing;
>  #if !defined( RTEMS_SMP )
>      _ISR_Disable( level );
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
