SPARC linker command files
Sat Nov 30 01:31:50 UTC 2013
Does the NGMP allow for variant sizes of ROM and RAM? If so will we
provide separate BSP variants for all possibilities, or how does the
user select the right size for their board?
On Fri, Nov 29, 2013 at 8:20 AM, Sebastian Huber
> Hello,
> most SPARC BSPs use current the following linker provided symbols to specify
> the memory layout:
> _PROM_SIZE = DEFINED (_PROM_SIZE) ? _PROM_SIZE : 2M;
> _PROM_START = DEFINED (_PROM_START) ? _PROM_START : 0x00000000;
> _RAM_SIZE = DEFINED (_RAM_SIZE) ? _RAM_SIZE : 4M;
> _RAM_START = DEFINED (_RAM_START) ? _RAM_START : 0x40000000;
> So it is possible to define them as command line parameters.  There are two
> problems with this approach.
> Firstly start address must be consistent with the memory area definition.
> Due to this reason the NGMP linker command file looks like this:
> _PROM_SIZE = DEFINED (_PROM_SIZE) ? _PROM_SIZE : 0;
> _RAM_SIZE = DEFINED (_RAM_SIZE) ? _RAM_SIZE : 64M;
> MEMORY {
>   rom     : ORIGIN = 0xC0000000, LENGTH = 256M
>   ram     : ORIGIN = 0x00000000, LENGTH = 2048M
>   sram    : ORIGIN = 0xD0000000, LENGTH = 256M
> _PROM_START = ORIGIN (rom);
> _RAM_START = ORIGIN (ram);
> INCLUDE linkcmds.base
> Secondly the size symbols don't allow region overflow checks by the linker.
> A better approach would be to remove the ability to define these symbols on
> the command line and use a memory map definition via memory regions only.
> For the NGMP as an example this would look like:
> MEMORY {
>   rom     : ORIGIN = 0xC0000000, LENGTH = 8M
>   ram     : ORIGIN = 0x00000000, LENGTH = 64M
> This change makes it necessary to adopt user Makefiles to this new approach.
> rtems-devel mailing list
> rtems-devel at rtems.org
