Unexplained behavior of arm_cp15_mmu_disable()
Mon Nov 18 07:57:59 UTC 2013
On 2013-11-17 01:15, Stephen Tether wrote:
> Why does arm_cp15_mmu_disable() clean and invalidate cache lines around
> the position of the stack pointer?
Suppose you have optimization disabled and the MMU and data cache is on.  Now
you call this function.  The return address will be stored on the stack (in the
cache).  Now MMU/cache is disabled.  Now the return address is retrieved from
the stack (from memory) on return.  Now everything is pretty unpredictable.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
