Red-Black-Tree for Priority Queues
Sebastian Huber
Mon Nov 18 08:18:41 UTC 2013
On 2013-11-15 21:54, Chris Johns wrote:
> On 16/11/2013 4:00 am, Sebastian Huber wrote:
>> _Thread_queue_Enqueue_priority() which use _ISR_Flash(). Usage of
>> _ISR_Flash() will be highly problematic in case we introduce fine
>> grained locking for SMP.
> Could you please explain the issue the _ISR_Flash has in a little more detail ?
> chris at huia cpukit $ grep -r _ISR_Flash $(find . -name \*.[chsS]) | wc -l
> 48
> Why only this routine ?
Yeah, these are 48 problem areas. If we want to get rid of the Giant lock,
then all the ISR disable/enable/flash places must be replaced with spin locks.
A direct translation of ISR flash into spin lock release/obtain is not an
option since this can lead to performance problems.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
