[PATCH 2/3] score/rbtree: Delete protected operations
Sebastian Huber
Tue Nov 19 15:54:08 UTC 2013
The user of the red-black tree container must now ensure that at most
one thread at once can access an instance.
cpukit/sapi/include/rtems/rbtree.h | 112 -----------------------
cpukit/score/Makefile.am | 4 +-
cpukit/score/include/rtems/score/rbtree.h | 141 ++---------------------------
cpukit/score/src/rbtreeextract.c | 27 ------
cpukit/score/src/rbtreefind.c | 15 ---
cpukit/score/src/rbtreefindheader.c | 38 --------
cpukit/score/src/rbtreeget.c | 37 --------
cpukit/score/src/rbtreeinsert.c | 31 -------
cpukit/score/src/rbtreenext.c | 15 ---
testsuites/sptests/sprbtree01/init.c | 128 +++++++++++++-------------
10 files changed, 73 insertions(+), 475 deletions(-)
delete mode 100644 cpukit/score/src/rbtreefindheader.c
delete mode 100644 cpukit/score/src/rbtreeget.c
diff --git a/cpukit/sapi/include/rtems/rbtree.h b/cpukit/sapi/include/rtems/rbtree.h
index bce7013..5cbdab4 100644
--- a/cpukit/sapi/include/rtems/rbtree.h
+++ b/cpukit/sapi/include/rtems/rbtree.h
@@ -309,23 +309,6 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_find_unprotected(
return _RBTree_Find_unprotected( the_rbtree, the_node );
-/** @brief Find the node with given key in the tree.
- * This function returns a pointer to the node having key equal to the key
- * of @a the_node if it exists within @a the_rbtree, and NULL if not.
- * @a the_node has to be made up before a search.
- * @note If the tree is not unique and contains duplicate keys, the set
- * of duplicate keys acts as FIFO.
-RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_find(
- const rtems_rbtree_control *the_rbtree,
- const rtems_rbtree_node *the_node
- return _RBTree_Find( the_rbtree, the_node );
* @copydoc _RBTree_Predecessor_unprotected()
@@ -337,16 +320,6 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_predecessor_unprotected(
- * @copydoc _RBTree_Predecessor()
-RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_predecessor(
- const rtems_rbtree_node *node
- return _RBTree_Predecessor( node );
* @copydoc _RBTree_Successor_unprotected()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_successor_unprotected(
@@ -357,16 +330,6 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_successor_unprotected(
- * @copydoc _RBTree_Successor()
-RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_successor(
- return _RBTree_Successor( node );
* @copydoc _RBTree_Extract_unprotected()
RTEMS_INLINE_ROUTINE void rtems_rbtree_extract_unprotected(
@@ -378,20 +341,6 @@ RTEMS_INLINE_ROUTINE void rtems_rbtree_extract_unprotected(
- * @brief Extract the specified node from a rbtree.
- * This routine extracts @a the_node from @a the_rbtree on which it resides.
- * It disables interrupts to ensure the atomicity of the extract operation.
-RTEMS_INLINE_ROUTINE void rtems_rbtree_extract(
- rtems_rbtree_control *the_rbtree,
- rtems_rbtree_node *the_node
- _RBTree_Extract( the_rbtree, the_node );
* @brief Obtain the min node on a rbtree.
* This function removes the min node from @a the_rbtree and returns
@@ -406,20 +355,6 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min_unprotected(
- * @brief Obtain the min node on a rbtree.
- * This function removes the min node from @a the_rbtree and returns
- * a pointer to that node. If @a the_rbtree is empty, then NULL is returned.
- * It disables interrupts to ensure the atomicity of the get operation.
-RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min(
- return _RBTree_Get( the_rbtree, RBT_LEFT );
* @brief Obtain the max node on a rbtree.
* This function removes the max node from @a the_rbtree and returns
@@ -434,20 +369,6 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max_unprotected(
- * @brief Obtain the max node on a rbtree.
- * This function removes the max node from @a the_rbtree and returns
-RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max(
- return _RBTree_Get( the_rbtree, RBT_RIGHT );
* @brief Peek at the min node on a rbtree.
* This function returns a pointer to the min node from @a the_rbtree
@@ -486,20 +407,6 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_control *rtems_rbtree_find_header_unprotected(
- * @brief Find the control header of the tree containing a given node.
- * This routine finds the rtems_rbtree_control structure of the tree
- * containing @a the_node.
- * It disables interrupts to ensure the atomicity of the find operation.
-RTEMS_INLINE_ROUTINE rtems_rbtree_control *rtems_rbtree_find_header(
- return _RBTree_Find_header( the_node );
* @copydoc _RBTree_Insert_unprotected()
RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_insert_unprotected(
@@ -510,25 +417,6 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_insert_unprotected(
return _RBTree_Insert_unprotected( the_rbtree, the_node );
- * @brief Insert a node on a rbtree.
- * This routine inserts @a the_node on @a the_rbtree.
- * It disables interrupts to ensure the atomicity of the insert operation.
- * @retval 0 Successfully inserted.
- * @retval -1 NULL @a the_node.
- * @retval RBTree_Node* if one with equal key to the key of @a the_node exists
- * in an unique @a the_rbtree.
-RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_insert(
- return _RBTree_Insert( the_rbtree, the_node );
* @brief Determines whether the tree is unique.
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index c9d2d47..4570ffd 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -260,8 +260,8 @@ libscore_a_SOURCES += src/freechain.c
## RBTREE_C_FILES
libscore_a_SOURCES += src/rbtree.c \
- src/rbtreeextract.c src/rbtreefind.c src/rbtreefindheader.c \
- src/rbtreeget.c src/rbtreeinsert.c src/rbtreeiterate.c src/rbtreenext.c
+ src/rbtreeextract.c src/rbtreefind.c \
+ src/rbtreeinsert.c src/rbtreeiterate.c src/rbtreenext.c
## THREAD_C_FILES
libscore_a_SOURCES += src/thread.c src/threadchangepriority.c \
diff --git a/cpukit/score/include/rtems/score/rbtree.h b/cpukit/score/include/rtems/score/rbtree.h
index 1414bdf..a3744e5 100644
--- a/cpukit/score/include/rtems/score/rbtree.h
+++ b/cpukit/score/include/rtems/score/rbtree.h
@@ -207,31 +207,14 @@ void _RBTree_Initialize(
- * @brief Obtain the min or max node of a rbtree.
+ * @brief Tries to find a node for the specified key in the tree.
- * This function removes the min or max node from @a the_rbtree and returns
- * @a dir specifies whether to return the min (0) or max (1).
+ * @param[in] the_rbtree The red-black tree control.
+ * @param[in] the_node A node specifying the key.
- * @retval This method returns a pointer to a node. If a node was removed,
- * then a pointer to that node is returned. If @a the_rbtree was
- * empty, then NULL is returned.
- * @note It disables interrupts to ensure the atomicity of the get operation.
-RBTree_Node *_RBTree_Get(
- RBTree_Control *the_rbtree,
- RBTree_Direction dir
- * This function returns a pointer to the node in @a the_rbtree
- * having key equal to key of @a the_node if it exists,
- * and NULL if not. @a the_node has to be made up before a search.
+ * @retval node A node corresponding to the key. If the tree is not unique
+ * and contains duplicate keys, the set of duplicate keys acts as FIFO.
+ * @retval NULL No node exists in the tree for the key.
RBTree_Node *_RBTree_Find_unprotected(
const RBTree_Control *the_rbtree,
@@ -239,43 +222,6 @@ RBTree_Node *_RBTree_Find_unprotected(
- * @brief Find the node with given key in the tree.
- * This function returns a pointer to the node with key equal to a key
- * of @a the_node if it exists in the Red-Black Tree @a the_rbtree,
- * @param[in] the_rbtree pointer to rbtree control
- * @param[in] the_node node with the key to search for
- * @retval This method returns pointer to control header of rbtree. *
- * If there is no control header available (the node is not part
- * of a tree), then NULL is returned. *
- * - INTERRUPT LATENCY:
- * + single case
-RBTree_Node *_RBTree_Find(
- const RBTree_Control *the_rbtree,
- const RBTree_Node *the_node
- * @brief Find the control structure of the tree containing the given node.
- * This function returns a pointer called @a return_header to the
- * control structure of the tree containing @a the_node, if it exists,
- * and @a NULL if not.
- * @param[in] the_node is the pointer to the rbtree node.
- * -INTERRUPT LATENCY:
- * + single case
-RBTree_Control *_RBTree_Find_header(
- RBTree_Node *the_node
* @brief Insert @a the_node on the Red-Black Tree @a the_rbtree (unprotected).
* This routine inserts @a the_node on the Red-Black Tree @a the_rbtree.
@@ -284,9 +230,6 @@ RBTree_Control *_RBTree_Find_header(
* @retval RBTree_Node* if one with equal value to @a the_node 's key exists
- * @note It does NOT disable interrupts to ensure the atomicity
- * of the extract operation.
RBTree_Node *_RBTree_Insert_unprotected(
@@ -294,31 +237,9 @@ RBTree_Node *_RBTree_Insert_unprotected(
- * This routine inserts @a the_node on the tree @a the_rbtree.
- * @retval RBTree_Node* if one with equal value to @a the_node 's key exists
-RBTree_Node *_RBTree_Insert(
* @brief Extracts (removes) @a the_node from @a the_rbtree (unprotected).
* This routine extracts (removes) @a the_node from @a the_rbtree.
void _RBTree_Extract_unprotected(
@@ -326,19 +247,6 @@ void _RBTree_Extract_unprotected(
- * @brief Delete a node from the rbtree.
- * This routine deletes @a the_node from @a the_rbtree.
- * append operation.
-void _RBTree_Extract(
* @brief Returns the in-order next node of a node.
* @param[in] node The node.
@@ -353,16 +261,6 @@ RBTree_Node *_RBTree_Next_unprotected(
- * @copydoc _RBTree_Next_unprotected()
- * The function disables the interrupts protect the operation.
-RBTree_Node *_RBTree_Next(
- const RBTree_Node *node,
* @brief Set off RBtree.
* This function sets the parent and child fields of the @a node to NULL
@@ -618,18 +516,6 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Predecessor_unprotected(
- * @copydoc _RBTree_Predecessor_unprotected()
-RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Predecessor(
- return _RBTree_Next( node, RBT_LEFT );
* @brief Returns the successor of a node.
* @param[in] node is the node.
@@ -644,23 +530,10 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Successor_unprotected(
- * @copydoc _RBTree_Successor_unprotected()
-RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Successor(
- return _RBTree_Next( node, RBT_RIGHT );
* @brief Get the first node (unprotected).
* This function removes the minimum or maximum node from the_rbtree and
- * returns a pointer to that node. It does NOT disable interrupts to ensure
- * the atomicity of the get operation.
+ * returns a pointer to that node.
* @param[in] the_rbtree is the rbtree to attempt to get the min node from.
* @param[in] dir specifies whether to get minimum (0) or maximum (1)
diff --git a/cpukit/score/src/rbtreeextract.c b/cpukit/score/src/rbtreeextract.c
index 0f38fbc..8dafe3b 100644
--- a/cpukit/score/src/rbtreeextract.c
+++ b/cpukit/score/src/rbtreeextract.c
@@ -202,30 +202,3 @@ void _RBTree_Extract_unprotected(
/* set root to black, if it exists */
if (the_rbtree->root) the_rbtree->root->color = RBT_BLACK;
- * _RBTree_Extract
- * This kernel routine deletes the given node from a rbtree.
- * Input parameters:
- * node - pointer to node in rbtree to be deleted
- * Output parameters: NONE
- * INTERRUPT LATENCY:
- * only case
- ISR_Level level;
- _ISR_Disable( level );
- _RBTree_Extract_unprotected( the_rbtree, the_node );
- _ISR_Enable( level );
diff --git a/cpukit/score/src/rbtreefind.c b/cpukit/score/src/rbtreefind.c
index b485845..9b2663d 100644
--- a/cpukit/score/src/rbtreefind.c
+++ b/cpukit/score/src/rbtreefind.c
@@ -20,21 +20,6 @@
#include <rtems/score/rbtreeimpl.h>
#include <rtems/score/isr.h>
- const RBTree_Node *search_node
- ISR_Level level;
- RBTree_Node *return_node;
- return_node = NULL;
- return_node = _RBTree_Find_unprotected( the_rbtree, search_node );
- return return_node;
diff --git a/cpukit/score/src/rbtreefindheader.c b/cpukit/score/src/rbtreefindheader.c
deleted file mode 100644
index 2368a11..0000000
--- a/cpukit/score/src/rbtreefindheader.c
+++ /dev/null
@@ -1,38 +0,0 @@
- * @file
- * @brief Finds the Header of a Tree if it Exists
- * @ingroup ScoreRBTree
- * Copyright (c) 2010 Gedare Bloom.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/system.h>
-#include <rtems/score/address.h>
-#include <rtems/score/rbtree.h>
-#include <rtems/score/isr.h>
- ISR_Level level;
- RBTree_Control *return_header;
- return_header = NULL;
- return_header = _RBTree_Find_header_unprotected( the_node );
- return return_header;
diff --git a/cpukit/score/src/rbtreeget.c b/cpukit/score/src/rbtreeget.c
index a805a40..0000000
--- a/cpukit/score/src/rbtreeget.c
+++ /dev/null
@@ -1,37 +0,0 @@
- * @file
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/score/rbtreeimpl.h>
- ISR_Level level;
- return_node = _RBTree_Get_unprotected( the_rbtree, dir );
diff --git a/cpukit/score/src/rbtreeinsert.c b/cpukit/score/src/rbtreeinsert.c
index 0d8e4a6..a2f6f09 100644
--- a/cpukit/score/src/rbtreeinsert.c
+++ b/cpukit/score/src/rbtreeinsert.c
@@ -122,34 +122,3 @@ RBTree_Node *_RBTree_Insert_unprotected(
return (RBTree_Node*)0;
- * _RBTree_Insert
- * This kernel routine inserts a given node after a specified node
- * a requested rbtree.
- * tree - pointer to RBTree Control for tree to insert to
- * node - pointer to node to be inserted
- * only case
- RBTree_Control *tree,
- RBTree_Node *node
- ISR_Level level;
- return_node = _RBTree_Insert_unprotected( tree, node );
diff --git a/cpukit/score/src/rbtreenext.c b/cpukit/score/src/rbtreenext.c
index 7dd305a..f3268d2 100644
--- a/cpukit/score/src/rbtreenext.c
+++ b/cpukit/score/src/rbtreenext.c
@@ -60,18 +60,3 @@ RBTree_Node *_RBTree_Next_unprotected(
return next;
- RBTree_Node *next;
- ISR_Level level;
- next = _RBTree_Next_unprotected( node, dir );
- return next;
diff --git a/testsuites/sptests/sprbtree01/init.c b/testsuites/sptests/sprbtree01/init.c
index df2a947..a0dd9b9 100644
--- a/testsuites/sptests/sprbtree01/init.c
+++ b/testsuites/sptests/sprbtree01/init.c
@@ -117,10 +117,10 @@ rtems_task Init(
node1.key = 1;
node2.id = 2;
node2.key = 2;
- rtems_rbtree_insert( &rbtree1, &node1.Node );
- rtems_rbtree_insert( &rbtree1, &node2.Node );
+ rtems_rbtree_insert_unprotected( &rbtree1, &node1.Node );
+ rtems_rbtree_insert_unprotected( &rbtree1, &node2.Node );
- p = rtems_rbtree_insert( &rbtree1, NULL );
+ p = rtems_rbtree_insert_unprotected( &rbtree1, NULL );
if (p != (void *)(-1))
puts( "INIT - FAILED NULL NODE INSERT" );
@@ -135,8 +135,8 @@ rtems_task Init(
if (!rb_assert(rbtree1.root) )
puts( "INIT - FAILED TREE CHECK" );
- for ( p = rtems_rbtree_get_min(&rbtree1), id = 1 ; p ;
- p = rtems_rbtree_get_min(&rbtree1) , id++ ) {
+ for ( p = rtems_rbtree_get_min_unprotected(&rbtree1), id = 1 ; p ;
+ p = rtems_rbtree_get_min_unprotected(&rbtree1) , id++ ) {
test_node *t = rtems_rbtree_container_of(p,test_node,Node);
if ( id > 2 ) {
puts( "INIT - TOO MANY NODES ON RBTREE" );
@@ -157,14 +157,14 @@ rtems_task Init(
puts("INIT - Verify rtems_rbtree_insert with the same value twice");
node2.key = node1.key;
- rtems_rbtree_insert(&rbtree1, &node1.Node);
- p = rtems_rbtree_insert(&rbtree1, &node2.Node);
+ rtems_rbtree_insert_unprotected(&rbtree1, &node1.Node);
+ p = rtems_rbtree_insert_unprotected(&rbtree1, &node2.Node);
if (p != &node1.Node)
puts( "INIT - FAILED DUPLICATE INSERT" );
if ( id > 1 ) {
@@ -192,11 +192,11 @@ rtems_task Init(
puts( "INIT - Verify rtems_XXX on an empty tree" );
- if(rtems_rbtree_get_min(&rbtree1)) {
+ if(rtems_rbtree_get_min_unprotected(&rbtree1)) {
puts("INIT - get_min on empty returned non-NULL");
rtems_test_exit(0);
- if(rtems_rbtree_get_max(&rbtree1)) {
+ if(rtems_rbtree_get_max_unprotected(&rbtree1)) {
puts("INIT - get_max on empty returned non-NULL");
rtems_test_exit(0);
@@ -216,8 +216,8 @@ rtems_task Init(
node1.key = 2;
node2.id = 1;
node2.key = 1;
puts( "INIT - Verify rtems_rbtree_peek_max/min, rtems_rbtree_extract" );
test_node *t1 = rtems_rbtree_container_of(rtems_rbtree_peek_max(&rbtree1),
@@ -229,16 +229,16 @@ rtems_task Init(
rtems_test_exit(0);
p = rtems_rbtree_peek_max(&rbtree1);
- rtems_rbtree_extract(&rbtree1, p);
+ rtems_rbtree_extract_unprotected(&rbtree1, p);
t1 = rtems_rbtree_container_of(p,test_node,Node);
if (t1->key != 2) {
puts( "INIT - rtems_rbtree_extract failed");
rtems_test_exit(0);
- rtems_rbtree_insert(&rbtree1, p);
+ rtems_rbtree_insert_unprotected(&rbtree1, p);
if ( id > 2 ) {
@@ -254,7 +254,7 @@ rtems_task Init(
for (i = 0; i < 100; i++) {
node_array[i].id = i;
node_array[i].key = i;
- rtems_rbtree_insert( &rbtree1, &node_array[i].Node );
+ rtems_rbtree_insert_unprotected( &rbtree1, &node_array[i].Node );
@@ -262,8 +262,8 @@ rtems_task Init(
puts( "INIT - Removing 100 nodes" );
- for ( p = rtems_rbtree_get_min(&rbtree1), id = 0 ; p ;
+ for ( p = rtems_rbtree_get_min_unprotected(&rbtree1), id = 0 ; p ;
if ( id > 99 ) {
@@ -287,7 +287,7 @@ rtems_task Init(
node_array[i].id = 99-i;
node_array[i].key = 99-i;
@@ -295,8 +295,8 @@ rtems_task Init(
if ( id > 99 ) {
@@ -322,7 +322,7 @@ rtems_task Init(
@@ -332,15 +332,15 @@ rtems_task Init(
for (i = 0; i < 20; i++) {
id = numbers[i];
- rtems_rbtree_extract( &rbtree1, &node_array[id].Node );
+ rtems_rbtree_extract_unprotected( &rbtree1, &node_array[id].Node );
puts( "INIT - Removing 80 nodes" );
- for ( p = rtems_rbtree_get_min(&rbtree1), id = 0, i = 0 ; p ;
+ for ( p = rtems_rbtree_get_min_unprotected(&rbtree1), id = 0, i = 0 ; p ;
test_node *t = rtems_rbtree_container_of(p, test_node, Node);
while ( id == numbers_sorted[i] ) {
@@ -374,26 +374,26 @@ rtems_task Init(
- rtems_rbtree_insert( &rbtree1, &node_array[3].Node );
- rtems_rbtree_insert( &rbtree1, &node_array[1].Node );
- rtems_rbtree_insert( &rbtree1, &node_array[5].Node );
- rtems_rbtree_insert( &rbtree1, &node_array[0].Node );
- rtems_rbtree_insert( &rbtree1, &node_array[2].Node );
- rtems_rbtree_insert( &rbtree1, &node_array[4].Node );
- rtems_rbtree_insert( &rbtree1, &node_array[6].Node );
- rtems_rbtree_extract( &rbtree1, &node_array[2].Node );
+ rtems_rbtree_insert_unprotected( &rbtree1, &node_array[3].Node );
+ rtems_rbtree_insert_unprotected( &rbtree1, &node_array[1].Node );
+ rtems_rbtree_insert_unprotected( &rbtree1, &node_array[5].Node );
+ rtems_rbtree_insert_unprotected( &rbtree1, &node_array[0].Node );
+ rtems_rbtree_insert_unprotected( &rbtree1, &node_array[2].Node );
+ rtems_rbtree_insert_unprotected( &rbtree1, &node_array[4].Node );
+ rtems_rbtree_insert_unprotected( &rbtree1, &node_array[6].Node );
+ rtems_rbtree_extract_unprotected( &rbtree1, &node_array[2].Node );
/* node_array[1] has now only a left child. */
if ( !node_array[1].Node.child[RBT_LEFT] ||
node_array[1].Node.child[RBT_RIGHT] )
puts( "INIT - LEFT CHILD ONLY NOT FOUND" );
- rtems_rbtree_extract( &rbtree1, &node_array[3].Node );
- while( (p = rtems_rbtree_get_max(&rbtree1)) );
+ rtems_rbtree_extract_unprotected( &rbtree1, &node_array[3].Node );
+ while( (p = rtems_rbtree_get_max_unprotected(&rbtree1)) );
puts( "INIT - Verify rtems_rbtree_get_max with 100 nodes value [99,0]" );
@@ -401,8 +401,8 @@ rtems_task Init(
- for ( p = rtems_rbtree_get_max(&rbtree1), id = 0 ; p ;
- p = rtems_rbtree_get_max(&rbtree1) , id++ ) {
+ for ( p = rtems_rbtree_get_max_unprotected(&rbtree1), id = 0 ; p ;
+ p = rtems_rbtree_get_max_unprotected(&rbtree1) , id++ ) {
if ( id > 99 ) {
@@ -426,7 +426,7 @@ rtems_task Init(
@@ -434,28 +434,28 @@ rtems_task Init(
puts( "INIT - Verify rtems_rbtree_find" );
search_node.key = 30;
- p = rtems_rbtree_find(&rbtree1, &search_node.Node);
+ p = rtems_rbtree_find_unprotected(&rbtree1, &search_node.Node);
if(rtems_rbtree_container_of(p,test_node,Node)->id != 30) {
puts ("INIT - ERROR ON RBTREE ID MISMATCH");
rtems_test_exit(0);
puts( "INIT - Verify rtems_rbtree_predecessor/successor");
- p = rtems_rbtree_predecessor(p);
+ p = rtems_rbtree_predecessor_unprotected(p);
if(p && rtems_rbtree_container_of(p,test_node,Node)->id != 29) {
rtems_test_exit(0);
- p = rtems_rbtree_successor(p);
+ p = rtems_rbtree_successor_unprotected(p);
if(p && rtems_rbtree_container_of(p,test_node,Node)->id != 31) {
rtems_test_exit(0);
puts( "INIT - Verify rtems_rbtree_find_header" );
- if (rtems_rbtree_find_header(p) != &rbtree1) {
+ if (rtems_rbtree_find_header_unprotected(p) != &rbtree1) {
puts ("INIT - ERROR ON RBTREE HEADER MISMATCH");
rtems_test_exit(0);
@@ -473,8 +473,8 @@ rtems_task Init(
- for ( p = rtems_rbtree_get_max(&rbtree1), id = 99 ; p ;
- p = rtems_rbtree_get_max(&rbtree1) , id-- ) {
+ for ( p = rtems_rbtree_get_max_unprotected(&rbtree1), id = 99 ; p ;
+ p = rtems_rbtree_get_max_unprotected(&rbtree1) , id-- ) {
if ( id < 0 ) {
@@ -494,11 +494,11 @@ rtems_task Init(
rtems_test_exit(0);
- if (rtems_rbtree_find_header(&node_array[0].Node) != NULL) {
+ if (rtems_rbtree_find_header_unprotected(&node_array[0].Node) != NULL) {
rtems_test_exit(0);
- if (rtems_rbtree_find_header(NULL) != NULL) {
+ if (rtems_rbtree_find_header_unprotected(NULL) != NULL) {
rtems_test_exit(0);
@@ -507,7 +507,7 @@ rtems_task Init(
node_array[i].id = numbers[i];
node_array[i].key = numbers[i];
@@ -515,8 +515,8 @@ rtems_task Init(
puts( "INIT - Removing 20 nodes" );
if ( id > 19 ) {
@@ -547,8 +547,8 @@ rtems_task Init(
if ( id > 99 ) {
@@ -582,7 +582,7 @@ rtems_task Init(
node_array[i].key = i%5;
@@ -590,7 +590,7 @@ rtems_task Init(
puts( "INIT - Verify rtems_rbtree_find in a duplicate tree" );
search_node.key = 2;
if(rtems_rbtree_container_of(p,test_node,Node)->id != 2) {
rtems_test_exit(0);
@@ -598,8 +598,8 @@ rtems_task Init(
if ( id > 99 ) {
@@ -623,7 +623,7 @@ rtems_task Init(
node_array[i].key = (99-i)%5;
@@ -631,7 +631,7 @@ rtems_task Init(
if(rtems_rbtree_container_of(p,test_node,Node)->id != 97) {
rtems_test_exit(0);
@@ -639,8 +639,8 @@ rtems_task Init(
if ( id > 99 ) {
1.7.7
