[PATCH 3/3] score/rbtree: Remove "unprotected" from API
Gedare Bloom
gedare at rtems.org
Tue Nov 19 17:42:53 UTC 2013
This is OK. I have one concern which is that any code that was
developed against the "protected" api will compile. We'll need to make
a note of this change so that users can beware.
On Tue, Nov 19, 2013 at 10:54 AM, Sebastian Huber
> cpukit/posix/src/keyfreememory.c | 10 +-
> cpukit/posix/src/keygetspecific.c | 2 +-
> cpukit/posix/src/keyrundestructors.c | 2 +-
> cpukit/posix/src/keysetspecific.c | 2 +-
> cpukit/sapi/include/rtems/rbtree.h | 60 +++++++----
> cpukit/sapi/src/rbheap.c | 8 +-
> cpukit/score/include/rtems/score/rbtree.h | 28 +++---
> cpukit/score/include/rtems/score/rbtreeimpl.h | 4 +-
> cpukit/score/src/rbtree.c | 2 +-
> cpukit/score/src/rbtreeextract.c | 12 +-
> cpukit/score/src/rbtreefind.c | 2 +-
> cpukit/score/src/rbtreeinsert.c | 6 +-
> cpukit/score/src/rbtreeiterate.c | 6 +-
> cpukit/score/src/rbtreenext.c | 4 +-
> cpukit/score/src/scheduleredfenqueue.c | 2 +-
> cpukit/score/src/scheduleredfextract.c | 2 +-
> cpukit/score/src/scheduleredfyield.c | 4 +-
> testsuites/libtests/rbheap01/init.c | 2 +-
> testsuites/sptests/sprbtree01/init.c | 128 ++++++++++++------------
> 19 files changed, 151 insertions(+), 135 deletions(-)
> diff --git a/cpukit/posix/src/keyfreememory.c b/cpukit/posix/src/keyfreememory.c
> index ff8fc82..71daba4 100644
> --- a/cpukit/posix/src/keyfreememory.c
> +++ b/cpukit/posix/src/keyfreememory.c
> @@ -34,17 +34,17 @@ void _POSIX_Keys_Free_memory(
> key_id = the_key->Object.id;
> search_node.key = key_id;
> search_node.thread_id = 0;
> - iter = _RBTree_Find_unprotected( &_POSIX_Keys_Key_value_lookup_tree, &search_node.Key_value_lookup_node );
> + iter = _RBTree_Find( &_POSIX_Keys_Key_value_lookup_tree, &search_node.Key_value_lookup_node );
> if ( !iter )
> return;
> * find the smallest thread_id node in the rbtree.
> - next = _RBTree_Next_unprotected( iter, RBT_LEFT );
> + next = _RBTree_Next( iter, RBT_LEFT );
> p = _RBTree_Container_of( next, POSIX_Keys_Key_value_pair, Key_value_lookup_node );
> while ( next != NULL && p->key == key_id) {
> iter = next;
> @@ -53,8 +53,8 @@ void _POSIX_Keys_Free_memory(
> p = _RBTree_Container_of( iter, POSIX_Keys_Key_value_pair, Key_value_lookup_node );
> while ( iter != NULL && p->key == key_id ) {
> - next = _RBTree_Next_unprotected( iter, RBT_RIGHT );
> - _RBTree_Extract_unprotected( &_POSIX_Keys_Key_value_lookup_tree, iter );
> + next = _RBTree_Next( iter, RBT_RIGHT );
> + _RBTree_Extract( &_POSIX_Keys_Key_value_lookup_tree, iter );
> _Chain_Extract_unprotected( &p->Key_values_per_thread_node );
> _POSIX_Keys_Key_value_pair_free( p );
> diff --git a/cpukit/posix/src/keygetspecific.c b/cpukit/posix/src/keygetspecific.c
> index 011917b..b1e9717 100644
> --- a/cpukit/posix/src/keygetspecific.c
> +++ b/cpukit/posix/src/keygetspecific.c
> @@ -51,7 +51,7 @@ void *pthread_getspecific(
> case OBJECTS_LOCAL:
> search_node.key = key;
> search_node.thread_id = _Thread_Executing->Object.id;
> - p = _RBTree_Find_unprotected( &_POSIX_Keys_Key_value_lookup_tree,
> + p = _RBTree_Find( &_POSIX_Keys_Key_value_lookup_tree,
> key_data = NULL;
> if ( p ) {
> diff --git a/cpukit/posix/src/keyrundestructors.c b/cpukit/posix/src/keyrundestructors.c
> index 5f0a699..2545486 100644
> --- a/cpukit/posix/src/keyrundestructors.c
> +++ b/cpukit/posix/src/keyrundestructors.c
> @@ -60,7 +60,7 @@ void _POSIX_Keys_Run_destructors(
> * because Chain_Node is the first member of POSIX_Keys_Key_value_pair
> * structure.
> + _RBTree_Extract(
> &iter->Key_value_lookup_node
> diff --git a/cpukit/posix/src/keysetspecific.c b/cpukit/posix/src/keysetspecific.c
> index 8f5ce72..5cfa90e 100644
> --- a/cpukit/posix/src/keysetspecific.c
> +++ b/cpukit/posix/src/keysetspecific.c
> @@ -54,7 +54,7 @@ int pthread_setspecific(
> value_pair_ptr->key = key;
> value_pair_ptr->thread_id = _Thread_Executing->Object.id;
> value_pair_ptr->value = value;
> - if ( _RBTree_Insert_unprotected( &_POSIX_Keys_Key_value_lookup_tree,
> + if ( _RBTree_Insert( &_POSIX_Keys_Key_value_lookup_tree,
> &(value_pair_ptr->Key_value_lookup_node) ) ) {
> _Freechain_Put( (Freechain_Control *)&_POSIX_Keys_Keypool,
> (void *) value_pair_ptr );
> diff --git a/cpukit/sapi/include/rtems/rbtree.h b/cpukit/sapi/include/rtems/rbtree.h
> index 5cbdab4..b787256 100644
> --- a/cpukit/sapi/include/rtems/rbtree.h
> +++ b/cpukit/sapi/include/rtems/rbtree.h
> @@ -27,6 +27,20 @@ extern "C" {
> #endif
> + * @defgroup ClassicRBTrees Red-Black Trees
> + * @ingroup ClassicRTEMS
> + * @brief A Red-Black Tree container.
> + * The red-black tree container offers no internal protection against
> + * concurrent access. The user must ensure that at most one thread at once can
> + * access a red-black tree instance.
> * @typedef rtems_rbtree_node
> * A node that can be manipulated in the rbtree.
> @@ -299,45 +313,45 @@ RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_root(
> - * @copydoc _RBTree_Find_unprotected()
> + * @copydoc _RBTree_Find()
> -RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_find_unprotected(
> +RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_find(
> const rtems_rbtree_control *the_rbtree,
> const rtems_rbtree_node *the_node
> - return _RBTree_Find_unprotected( the_rbtree, the_node );
> + return _RBTree_Find( the_rbtree, the_node );
> - * @copydoc _RBTree_Predecessor_unprotected()
> + * @copydoc _RBTree_Predecessor()
> -RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_predecessor_unprotected(
> +RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_predecessor(
> const rtems_rbtree_node *node
> - return _RBTree_Predecessor_unprotected( node );
> + return _RBTree_Predecessor( node );
> - * @copydoc _RBTree_Successor_unprotected()
> + * @copydoc _RBTree_Successor()
> -RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_successor_unprotected(
> +RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_successor(
> - return _RBTree_Successor_unprotected( node );
> + return _RBTree_Successor( node );
> - * @copydoc _RBTree_Extract_unprotected()
> + * @copydoc _RBTree_Extract()
> -RTEMS_INLINE_ROUTINE void rtems_rbtree_extract_unprotected(
> +RTEMS_INLINE_ROUTINE void rtems_rbtree_extract(
> - _RBTree_Extract_unprotected( the_rbtree, the_node );
> + _RBTree_Extract( the_rbtree, the_node );
> @@ -347,11 +361,11 @@ RTEMS_INLINE_ROUTINE void rtems_rbtree_extract_unprotected(
> * a pointer to that node. If @a the_rbtree is empty, then NULL is returned.
> -RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min_unprotected(
> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min(
> - return _RBTree_Get_unprotected( the_rbtree, RBT_LEFT );
> + return _RBTree_Get( the_rbtree, RBT_LEFT );
> @@ -361,11 +375,11 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min_unprotected(
> -RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max_unprotected(
> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max(
> - return _RBTree_Get_unprotected( the_rbtree, RBT_RIGHT );
> + return _RBTree_Get( the_rbtree, RBT_RIGHT );
> @@ -397,24 +411,24 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_max(
> - * @copydoc _RBTree_Find_header_unprotected()
> + * @copydoc _RBTree_Find_header()
> -RTEMS_INLINE_ROUTINE rtems_rbtree_control *rtems_rbtree_find_header_unprotected(
> +RTEMS_INLINE_ROUTINE rtems_rbtree_control *rtems_rbtree_find_header(
> - return _RBTree_Find_header_unprotected( the_node );
> + return _RBTree_Find_header( the_node );
> - * @copydoc _RBTree_Insert_unprotected()
> + * @copydoc _RBTree_Insert()
> -RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_insert_unprotected(
> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_insert(
> - return _RBTree_Insert_unprotected( the_rbtree, the_node );
> + return _RBTree_Insert( the_rbtree, the_node );
> @@ -427,6 +441,8 @@ RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_unique(
> return _RBTree_Is_unique(the_rbtree);
> #ifdef __cplusplus
> #endif
> diff --git a/cpukit/sapi/src/rbheap.c b/cpukit/sapi/src/rbheap.c
> index 5233778..a33b980 100644
> --- a/cpukit/sapi/src/rbheap.c
> +++ b/cpukit/sapi/src/rbheap.c
> @@ -80,7 +80,7 @@ static void insert_into_tree(
> rtems_rbheap_chunk *chunk
> - _RBTree_Insert_unprotected(tree, &chunk->tree_node);
> + _RBTree_Insert(tree, &chunk->tree_node);
> rtems_status_code rtems_rbheap_initialize(
> @@ -198,7 +198,7 @@ static rtems_rbheap_chunk *find(rtems_rbtree_control *chunk_tree, uintptr_t key)
> rtems_rbheap_chunk chunk = { .begin = key };
> return rtems_rbheap_chunk_of_node(
> - _RBTree_Find_unprotected(chunk_tree, &chunk.tree_node)
> + _RBTree_Find(chunk_tree, &chunk.tree_node)
> @@ -208,7 +208,7 @@ static rtems_rbheap_chunk *get_next(
> - _RBTree_Next_unprotected(&chunk->tree_node, dir)
> + _RBTree_Next(&chunk->tree_node, dir)
> @@ -230,7 +230,7 @@ static void check_and_merge(
> a->size += b->size;
> rtems_chain_extract_unprotected(&b->chain_node);
> add_to_chain(free_chain, b);
> - _RBTree_Extract_unprotected(chunk_tree, &b->tree_node);
> + _RBTree_Extract(chunk_tree, &b->tree_node);
> diff --git a/cpukit/score/include/rtems/score/rbtree.h b/cpukit/score/include/rtems/score/rbtree.h
> index a3744e5..b9a172c 100644
> --- a/cpukit/score/include/rtems/score/rbtree.h
> +++ b/cpukit/score/include/rtems/score/rbtree.h
> @@ -216,13 +216,13 @@ void _RBTree_Initialize(
> * and contains duplicate keys, the set of duplicate keys acts as FIFO.
> * @retval NULL No node exists in the tree for the key.
> -RBTree_Node *_RBTree_Find_unprotected(
> +RBTree_Node *_RBTree_Find(
> const RBTree_Control *the_rbtree,
> const RBTree_Node *the_node
> - * @brief Insert @a the_node on the Red-Black Tree @a the_rbtree (unprotected).
> + * @brief Insert @a the_node on the Red-Black Tree @a the_rbtree.
> * This routine inserts @a the_node on the Red-Black Tree @a the_rbtree.
> @@ -231,17 +231,17 @@ RBTree_Node *_RBTree_Find_unprotected(
> * @retval RBTree_Node* if one with equal value to @a the_node 's key exists
> * in an unique @a the_rbtree.
> -RBTree_Node *_RBTree_Insert_unprotected(
> +RBTree_Node *_RBTree_Insert(
> - * @brief Extracts (removes) @a the_node from @a the_rbtree (unprotected).
> + * @brief Extracts (removes) @a the_node from @a the_rbtree.
> * This routine extracts (removes) @a the_node from @a the_rbtree.
> -void _RBTree_Extract_unprotected(
> +void _RBTree_Extract(
> @@ -255,7 +255,7 @@ void _RBTree_Extract_unprotected(
> * @retval NULL The in-order next node does not exist.
> * @retval otherwise The next node.
> -RBTree_Node *_RBTree_Next_unprotected(
> +RBTree_Node *_RBTree_Next(
> const RBTree_Node *node,
> RBTree_Direction dir
> @@ -471,7 +471,7 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_root(
> * This function returns a pointer to the header of the Red Black
> * Tree containing @a the_node if it exists, and NULL if not.
> -RTEMS_INLINE_ROUTINE RBTree_Control *_RBTree_Find_header_unprotected(
> +RTEMS_INLINE_ROUTINE RBTree_Control *_RBTree_Find_header(
> @@ -508,11 +508,11 @@ RTEMS_INLINE_ROUTINE void _RBTree_Initialize_empty(
> * @retval NULL The predecessor does not exist. Otherwise it returns
> * the predecessor node.
> -RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Predecessor_unprotected(
> +RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Predecessor(
> - return _RBTree_Next_unprotected( node, RBT_LEFT );
> + return _RBTree_Next( node, RBT_LEFT );
> @@ -522,15 +522,15 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Predecessor_unprotected(
> * @retval NULL The successor does not exist. Otherwise the successor node.
> -RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Successor_unprotected(
> +RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Successor(
> - return _RBTree_Next_unprotected( node, RBT_RIGHT );
> + return _RBTree_Next( node, RBT_RIGHT );
> - * @brief Get the first node (unprotected).
> + * @brief Get the first node.
> * This function removes the minimum or maximum node from the_rbtree and
> * returns a pointer to that node.
> @@ -542,13 +542,13 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Successor_unprotected(
> * @note This routine may return NULL if the RBTree is empty.
> -RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Get_unprotected(
> +RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Get(
> RBTree_Node *the_node = the_rbtree->first[dir];
> - _RBTree_Extract_unprotected(the_rbtree, the_node);
> + _RBTree_Extract(the_rbtree, the_node);
> return the_node;
> diff --git a/cpukit/score/include/rtems/score/rbtreeimpl.h b/cpukit/score/include/rtems/score/rbtreeimpl.h
> index 30d55d2..0a3a883 100644
> --- a/cpukit/score/include/rtems/score/rbtreeimpl.h
> +++ b/cpukit/score/include/rtems/score/rbtreeimpl.h
> @@ -43,7 +43,7 @@ extern "C" {
> * @retval true Stop the iteration.
> * @retval false Continue the iteration.
> - * @see _RBTree_Iterate_unprotected().
> + * @see _RBTree_Iterate().
> typedef bool (*RBTree_Visitor)(
> @@ -59,7 +59,7 @@ typedef bool (*RBTree_Visitor)(
> * @param[in] visitor The visitor.
> * @param[in] visitor_arg The visitor argument.
> -void _RBTree_Iterate_unprotected(
> +void _RBTree_Iterate(
> const RBTree_Control *rbtree,
> RBTree_Direction dir,
> RBTree_Visitor visitor,
> diff --git a/cpukit/score/src/rbtree.c b/cpukit/score/src/rbtree.c
> index 59dfd76..4ec0ad6 100644
> --- a/cpukit/score/src/rbtree.c
> +++ b/cpukit/score/src/rbtree.c
> @@ -43,7 +43,7 @@ void _RBTree_Initialize(
> count = number_nodes;
> next = starting_address;
> while ( count-- ) {
> - _RBTree_Insert_unprotected(the_rbtree, next);
> + _RBTree_Insert(the_rbtree, next);
> next = (RBTree_Node *)
> _Addresses_Add_offset( (void *) next, node_size );
> diff --git a/cpukit/score/src/rbtreeextract.c b/cpukit/score/src/rbtreeextract.c
> index 8dafe3b..730d3f8 100644
> --- a/cpukit/score/src/rbtreeextract.c
> +++ b/cpukit/score/src/rbtreeextract.c
> @@ -21,7 +21,7 @@
> * @note It does NOT disable interrupts to ensure the atomicity
> * of the extract operation.
> -static void _RBTree_Extract_validate_unprotected(
> +static void _RBTree_Extract_validate(
> @@ -91,7 +91,7 @@ static void _RBTree_Extract_validate_unprotected(
> @@ -105,7 +105,7 @@ void _RBTree_Extract_unprotected(
> /* check if min needs to be updated */
> if (the_node == the_rbtree->first[RBT_LEFT]) {
> RBTree_Node *next;
> - next = _RBTree_Successor_unprotected(the_node);
> + next = _RBTree_Successor(the_node);
> the_rbtree->first[RBT_LEFT] = next;
> @@ -113,7 +113,7 @@ void _RBTree_Extract_unprotected(
> * do not use else if here. */
> if (the_node == the_rbtree->first[RBT_RIGHT]) {
> RBTree_Node *previous;
> - previous = _RBTree_Predecessor_unprotected(the_node);
> + previous = _RBTree_Predecessor(the_node);
> the_rbtree->first[RBT_RIGHT] = previous;
> @@ -139,7 +139,7 @@ void _RBTree_Extract_unprotected(
> leaf->parent = target->parent;
> } else {
> /* fix the tree here if the child is a null leaf. */
> - _RBTree_Extract_validate_unprotected(target);
> + _RBTree_Extract_validate(target);
> victim_color = target->color;
> dir = target != target->parent->child[0];
> @@ -176,7 +176,7 @@ void _RBTree_Extract_unprotected(
> leaf->parent = the_node->parent;
> } else {
> - _RBTree_Extract_validate_unprotected(the_node);
> + _RBTree_Extract_validate(the_node);
> victim_color = the_node->color;
> diff --git a/cpukit/score/src/rbtreefind.c b/cpukit/score/src/rbtreefind.c
> index 9b2663d..7aa0b35 100644
> --- a/cpukit/score/src/rbtreefind.c
> +++ b/cpukit/score/src/rbtreefind.c
> @@ -20,7 +20,7 @@
> #include <rtems/score/rbtreeimpl.h>
> #include <rtems/score/isr.h>
> diff --git a/cpukit/score/src/rbtreeinsert.c b/cpukit/score/src/rbtreeinsert.c
> index a2f6f09..c39249f 100644
> --- a/cpukit/score/src/rbtreeinsert.c
> +++ b/cpukit/score/src/rbtreeinsert.c
> @@ -21,7 +21,7 @@
> * @note It does NOT disable interrupts to ensure the atomicity of the
> * append operation.
> -static void _RBTree_Validate_insert_unprotected(
> +static void _RBTree_Validate_insert(
> @@ -73,7 +73,7 @@ static void _RBTree_Validate_insert_unprotected(
> @@ -118,7 +118,7 @@ RBTree_Node *_RBTree_Insert_unprotected(
> } /* while(iter_node) */
> /* verify red-black properties */
> - _RBTree_Validate_insert_unprotected(the_node);
> + _RBTree_Validate_insert(the_node);
> return (RBTree_Node*)0;
> diff --git a/cpukit/score/src/rbtreeiterate.c b/cpukit/score/src/rbtreeiterate.c
> index 880fa2b..629b69f 100644
> --- a/cpukit/score/src/rbtreeiterate.c
> +++ b/cpukit/score/src/rbtreeiterate.c
> @@ -3,7 +3,7 @@
> * @ingroup ScoreRBTree
> - * @brief _RBTree_Iterate_unprotected() implementation.
> + * @brief _RBTree_Iterate() implementation.
> @@ -26,7 +26,7 @@
> @@ -40,6 +40,6 @@ void _RBTree_Iterate_unprotected(
> while ( !stop && current != NULL ) {
> stop = (*visitor)( current, dir, visitor_arg );
> - current = _RBTree_Next_unprotected( current, dir );
> + current = _RBTree_Next( current, dir );
> diff --git a/cpukit/score/src/rbtreenext.c b/cpukit/score/src/rbtreenext.c
> index f3268d2..5b3d7cb 100644
> --- a/cpukit/score/src/rbtreenext.c
> +++ b/cpukit/score/src/rbtreenext.c
> @@ -3,7 +3,7 @@
> - * @brief _RBTree_Next_unprotected() and _RBTree_Next() implementation.
> + * @brief _RBTree_Next() and _RBTree_Next() implementation.
> @@ -27,7 +27,7 @@
> diff --git a/cpukit/score/src/scheduleredfenqueue.c b/cpukit/score/src/scheduleredfenqueue.c
> index 9a9b906..921721f 100644
> --- a/cpukit/score/src/scheduleredfenqueue.c
> +++ b/cpukit/score/src/scheduleredfenqueue.c
> @@ -31,6 +31,6 @@ void _Scheduler_EDF_Enqueue(
> (Scheduler_EDF_Per_thread*) the_thread->scheduler_info;
> RBTree_Node *node = &(sched_info->Node);
> - _RBTree_Insert_unprotected( &_Scheduler_EDF_Ready_queue, node );
> + _RBTree_Insert( &_Scheduler_EDF_Ready_queue, node );
> sched_info->queue_state = SCHEDULER_EDF_QUEUE_STATE_YES;
> diff --git a/cpukit/score/src/scheduleredfextract.c b/cpukit/score/src/scheduleredfextract.c
> index b2f91cc..7547caf 100644
> --- a/cpukit/score/src/scheduleredfextract.c
> +++ b/cpukit/score/src/scheduleredfextract.c
> @@ -31,6 +31,6 @@ void _Scheduler_EDF_Extract(
> - _RBTree_Extract_unprotected( &_Scheduler_EDF_Ready_queue, node );
> + _RBTree_Extract( &_Scheduler_EDF_Ready_queue, node );
> sched_info->queue_state = SCHEDULER_EDF_QUEUE_STATE_NOT_PRESENTLY;
> diff --git a/cpukit/score/src/scheduleredfyield.c b/cpukit/score/src/scheduleredfyield.c
> index 4a80168..fc5b13a 100644
> --- a/cpukit/score/src/scheduleredfyield.c
> +++ b/cpukit/score/src/scheduleredfyield.c
> @@ -35,8 +35,8 @@ void _Scheduler_EDF_Yield( Thread_Control *thread )
> * The RBTree has more than one node, enqueue behind the tasks
> * with the same priority in case there are such ones.
> - _RBTree_Extract_unprotected( &_Scheduler_EDF_Ready_queue, thread_node );
> - _RBTree_Insert_unprotected( &_Scheduler_EDF_Ready_queue, thread_node );
> + _RBTree_Extract( &_Scheduler_EDF_Ready_queue, thread_node );
> + _RBTree_Insert( &_Scheduler_EDF_Ready_queue, thread_node );
> _ISR_Flash( level );
> diff --git a/testsuites/libtests/rbheap01/init.c b/testsuites/libtests/rbheap01/init.c
> index d00eefe..bf4ef6d 100644
> --- a/testsuites/libtests/rbheap01/init.c
> +++ b/testsuites/libtests/rbheap01/init.c
> @@ -187,7 +187,7 @@ static void test_chunk_tree(
> .free_end = free_end
> - _RBTree_Iterate_unprotected(
> + _RBTree_Iterate(
> &control->chunk_tree,
> RBT_RIGHT,
> chunk_visitor,
> diff --git a/testsuites/sptests/sprbtree01/init.c b/testsuites/sptests/sprbtree01/init.c
> index a0dd9b9..df2a947 100644
> --- a/testsuites/sptests/sprbtree01/init.c
> +++ b/testsuites/sptests/sprbtree01/init.c
> @@ -117,10 +117,10 @@ rtems_task Init(
> node1.key = 1;
> node2.id = 2;
> node2.key = 2;
> - rtems_rbtree_insert_unprotected( &rbtree1, &node1.Node );
> - rtems_rbtree_insert_unprotected( &rbtree1, &node2.Node );
> + rtems_rbtree_insert( &rbtree1, &node1.Node );
> + rtems_rbtree_insert( &rbtree1, &node2.Node );
> - p = rtems_rbtree_insert_unprotected( &rbtree1, NULL );
> + p = rtems_rbtree_insert( &rbtree1, NULL );
> if (p != (void *)(-1))
> puts( "INIT - FAILED NULL NODE INSERT" );
> @@ -135,8 +135,8 @@ rtems_task Init(
> if (!rb_assert(rbtree1.root) )
> puts( "INIT - FAILED TREE CHECK" );
> - for ( p = rtems_rbtree_get_min_unprotected(&rbtree1), id = 1 ; p ;
> - p = rtems_rbtree_get_min_unprotected(&rbtree1) , id++ ) {
> + for ( p = rtems_rbtree_get_min(&rbtree1), id = 1 ; p ;
> + p = rtems_rbtree_get_min(&rbtree1) , id++ ) {
> test_node *t = rtems_rbtree_container_of(p,test_node,Node);
> if ( id > 2 ) {
> puts( "INIT - TOO MANY NODES ON RBTREE" );
> @@ -157,14 +157,14 @@ rtems_task Init(
> puts("INIT - Verify rtems_rbtree_insert with the same value twice");
> node2.key = node1.key;
> - rtems_rbtree_insert_unprotected(&rbtree1, &node1.Node);
> - p = rtems_rbtree_insert_unprotected(&rbtree1, &node2.Node);
> + rtems_rbtree_insert(&rbtree1, &node1.Node);
> + p = rtems_rbtree_insert(&rbtree1, &node2.Node);
> if (p != &node1.Node)
> puts( "INIT - FAILED DUPLICATE INSERT" );
> if ( id > 1 ) {
> @@ -192,11 +192,11 @@ rtems_task Init(
> puts( "INIT - Verify rtems_XXX on an empty tree" );
> - if(rtems_rbtree_get_min_unprotected(&rbtree1)) {
> + if(rtems_rbtree_get_min(&rbtree1)) {
> puts("INIT - get_min on empty returned non-NULL");
> rtems_test_exit(0);
> - if(rtems_rbtree_get_max_unprotected(&rbtree1)) {
> + if(rtems_rbtree_get_max(&rbtree1)) {
> puts("INIT - get_max on empty returned non-NULL");
> rtems_test_exit(0);
> @@ -216,8 +216,8 @@ rtems_task Init(
> node1.key = 2;
> node2.id = 1;
> node2.key = 1;
> puts( "INIT - Verify rtems_rbtree_peek_max/min, rtems_rbtree_extract" );
> test_node *t1 = rtems_rbtree_container_of(rtems_rbtree_peek_max(&rbtree1),
> @@ -229,16 +229,16 @@ rtems_task Init(
> rtems_test_exit(0);
> p = rtems_rbtree_peek_max(&rbtree1);
> - rtems_rbtree_extract_unprotected(&rbtree1, p);
> + rtems_rbtree_extract(&rbtree1, p);
> t1 = rtems_rbtree_container_of(p,test_node,Node);
> if (t1->key != 2) {
> puts( "INIT - rtems_rbtree_extract failed");
> rtems_test_exit(0);
> - rtems_rbtree_insert_unprotected(&rbtree1, p);
> + rtems_rbtree_insert(&rbtree1, p);
> if ( id > 2 ) {
> @@ -254,7 +254,7 @@ rtems_task Init(
> for (i = 0; i < 100; i++) {
> node_array[i].id = i;
> node_array[i].key = i;
> - rtems_rbtree_insert_unprotected( &rbtree1, &node_array[i].Node );
> + rtems_rbtree_insert( &rbtree1, &node_array[i].Node );
> @@ -262,8 +262,8 @@ rtems_task Init(
> puts( "INIT - Removing 100 nodes" );
> - for ( p = rtems_rbtree_get_min_unprotected(&rbtree1), id = 0 ; p ;
> + for ( p = rtems_rbtree_get_min(&rbtree1), id = 0 ; p ;
> if ( id > 99 ) {
> @@ -287,7 +287,7 @@ rtems_task Init(
> node_array[i].id = 99-i;
> node_array[i].key = 99-i;
> @@ -295,8 +295,8 @@ rtems_task Init(
> if ( id > 99 ) {
> @@ -322,7 +322,7 @@ rtems_task Init(
> @@ -332,15 +332,15 @@ rtems_task Init(
> for (i = 0; i < 20; i++) {
> id = numbers[i];
> - rtems_rbtree_extract_unprotected( &rbtree1, &node_array[id].Node );
> + rtems_rbtree_extract( &rbtree1, &node_array[id].Node );
> puts( "INIT - Removing 80 nodes" );
> - for ( p = rtems_rbtree_get_min_unprotected(&rbtree1), id = 0, i = 0 ; p ;
> + for ( p = rtems_rbtree_get_min(&rbtree1), id = 0, i = 0 ; p ;
> test_node *t = rtems_rbtree_container_of(p, test_node, Node);
> while ( id == numbers_sorted[i] ) {
> @@ -374,26 +374,26 @@ rtems_task Init(
> - rtems_rbtree_insert_unprotected( &rbtree1, &node_array[3].Node );
> - rtems_rbtree_insert_unprotected( &rbtree1, &node_array[1].Node );
> - rtems_rbtree_insert_unprotected( &rbtree1, &node_array[5].Node );
> - rtems_rbtree_insert_unprotected( &rbtree1, &node_array[0].Node );
> - rtems_rbtree_insert_unprotected( &rbtree1, &node_array[2].Node );
> - rtems_rbtree_insert_unprotected( &rbtree1, &node_array[4].Node );
> - rtems_rbtree_insert_unprotected( &rbtree1, &node_array[6].Node );
> - rtems_rbtree_extract_unprotected( &rbtree1, &node_array[2].Node );
> + rtems_rbtree_insert( &rbtree1, &node_array[3].Node );
> + rtems_rbtree_insert( &rbtree1, &node_array[1].Node );
> + rtems_rbtree_insert( &rbtree1, &node_array[5].Node );
> + rtems_rbtree_insert( &rbtree1, &node_array[0].Node );
> + rtems_rbtree_insert( &rbtree1, &node_array[2].Node );
> + rtems_rbtree_insert( &rbtree1, &node_array[4].Node );
> + rtems_rbtree_insert( &rbtree1, &node_array[6].Node );
> + rtems_rbtree_extract( &rbtree1, &node_array[2].Node );
> /* node_array[1] has now only a left child. */
> if ( !node_array[1].Node.child[RBT_LEFT] ||
> node_array[1].Node.child[RBT_RIGHT] )
> puts( "INIT - LEFT CHILD ONLY NOT FOUND" );
> - rtems_rbtree_extract_unprotected( &rbtree1, &node_array[3].Node );
> - while( (p = rtems_rbtree_get_max_unprotected(&rbtree1)) );
> + rtems_rbtree_extract( &rbtree1, &node_array[3].Node );
> + while( (p = rtems_rbtree_get_max(&rbtree1)) );
> puts( "INIT - Verify rtems_rbtree_get_max with 100 nodes value [99,0]" );
> @@ -401,8 +401,8 @@ rtems_task Init(
> - for ( p = rtems_rbtree_get_max_unprotected(&rbtree1), id = 0 ; p ;
> - p = rtems_rbtree_get_max_unprotected(&rbtree1) , id++ ) {
> + for ( p = rtems_rbtree_get_max(&rbtree1), id = 0 ; p ;
> + p = rtems_rbtree_get_max(&rbtree1) , id++ ) {
> if ( id > 99 ) {
> @@ -426,7 +426,7 @@ rtems_task Init(
> @@ -434,28 +434,28 @@ rtems_task Init(
> puts( "INIT - Verify rtems_rbtree_find" );
> search_node.key = 30;
> - p = rtems_rbtree_find_unprotected(&rbtree1, &search_node.Node);
> + p = rtems_rbtree_find(&rbtree1, &search_node.Node);
> if(rtems_rbtree_container_of(p,test_node,Node)->id != 30) {
> puts ("INIT - ERROR ON RBTREE ID MISMATCH");
> rtems_test_exit(0);
> puts( "INIT - Verify rtems_rbtree_predecessor/successor");
> - p = rtems_rbtree_predecessor_unprotected(p);
> + p = rtems_rbtree_predecessor(p);
> if(p && rtems_rbtree_container_of(p,test_node,Node)->id != 29) {
> rtems_test_exit(0);
> - p = rtems_rbtree_successor_unprotected(p);
> + p = rtems_rbtree_successor(p);
> if(p && rtems_rbtree_container_of(p,test_node,Node)->id != 31) {
> rtems_test_exit(0);
> puts( "INIT - Verify rtems_rbtree_find_header" );
> - if (rtems_rbtree_find_header_unprotected(p) != &rbtree1) {
> + if (rtems_rbtree_find_header(p) != &rbtree1) {
> puts ("INIT - ERROR ON RBTREE HEADER MISMATCH");
> rtems_test_exit(0);
> @@ -473,8 +473,8 @@ rtems_task Init(
> - for ( p = rtems_rbtree_get_max_unprotected(&rbtree1), id = 99 ; p ;
> - p = rtems_rbtree_get_max_unprotected(&rbtree1) , id-- ) {
> + for ( p = rtems_rbtree_get_max(&rbtree1), id = 99 ; p ;
> + p = rtems_rbtree_get_max(&rbtree1) , id-- ) {
> if ( id < 0 ) {
> @@ -494,11 +494,11 @@ rtems_task Init(
> rtems_test_exit(0);
> - if (rtems_rbtree_find_header_unprotected(&node_array[0].Node) != NULL) {
> + if (rtems_rbtree_find_header(&node_array[0].Node) != NULL) {
> rtems_test_exit(0);
> - if (rtems_rbtree_find_header_unprotected(NULL) != NULL) {
> + if (rtems_rbtree_find_header(NULL) != NULL) {
> rtems_test_exit(0);
> @@ -507,7 +507,7 @@ rtems_task Init(
> node_array[i].id = numbers[i];
> node_array[i].key = numbers[i];
> @@ -515,8 +515,8 @@ rtems_task Init(
> puts( "INIT - Removing 20 nodes" );
> if ( id > 19 ) {
> @@ -547,8 +547,8 @@ rtems_task Init(
> if ( id > 99 ) {
> @@ -582,7 +582,7 @@ rtems_task Init(
> node_array[i].key = i%5;
> @@ -590,7 +590,7 @@ rtems_task Init(
> puts( "INIT - Verify rtems_rbtree_find in a duplicate tree" );
> search_node.key = 2;
> if(rtems_rbtree_container_of(p,test_node,Node)->id != 2) {
> rtems_test_exit(0);
> @@ -598,8 +598,8 @@ rtems_task Init(
> if ( id > 99 ) {
> @@ -623,7 +623,7 @@ rtems_task Init(
> node_array[i].key = (99-i)%5;
> @@ -631,7 +631,7 @@ rtems_task Init(
> if(rtems_rbtree_container_of(p,test_node,Node)->id != 97) {
> rtems_test_exit(0);
> @@ -639,8 +639,8 @@ rtems_task Init(
> if ( id > 99 ) {
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
