Partitioned/clustered scheduling
Sebastian Huber
Wed Nov 20 08:33:50 UTC 2013
On 2013-11-19 22:22, Chris Johns wrote:
> On 20/11/2013 12:39 am, Sebastian Huber wrote:
>> Hello,
>> we would like to implement partitioned/clustered scheduling for SMP
>> RTEMS. The reasons for this are highlighted in
> What time frame are you looking at for this ?
It has a high priority, so Q1 2014.
>> Björn B. Brandenburg, Scheduling and Locking in Multiprocessor Real-Time
>> Operating Systems, 2011
> http://www.cs.unc.edu/~bbb/diss/brandenburg-diss.pdf ?
Yes, also interesting:
A. Burns and A.J. Wellings, A Schedulability Compatible Multiprocessor Resource
Sharing Protocol - MrsP, Proceedings of the 25th Euromicro Conference on
Real-Time Systems (ECRTS 2013), July 2013
>> Partitioned/clustered scheduling means that the set of processors of a
>> system can be partitioned into pairwise disjoint subsets. Each subset
>> of processors will be owned by one scheduler instance.
> Nice.
>> The following proposal covers the processor configuration, high-level
>> scheduler implementation and RTEMS API changes.
>> ==== Scheduler Configuration ====
>> There are two options for the scheduler instance configuration
>> # static configuration by means of global data structures, and
>> # configuration at run-time via function calls.
>> For a configuration at run-time the system must start with a default
>> scheduler.
>> The global constructors are called in this environment. The order of
>> global
>> constructor invocation is unpredictable so it is difficult to create
>> threads in
>> this context since the run-time scheduler configuration may not exist yet.
>> Since scheduler data structures are allocated from the workspace the
>> configuration must take a later run-time setup of schedulers into
>> account for
>> the workspace size estimate. In case the default scheduler is not
>> appropriate
>> it must be replaced which gives raise to some implementation difficulties.
> I am not sure static constructors is a good example. If a user is wanting
> runtime configuration and is doing this inside static constructors they need to
> manage the dependences. A C++ programmer needs to know this.
Yes, but I think it is desirable to have a working scheduler setup once
multi-threading started.
>> Since the processor availability is determined by hardware constraints
>> it is
>> unclear which benefits a run-time configuration has. For now run-time
>> configuration of scheduler instances will be not implemented.
> It may not be clear at this point in time and concentrating on a static
> configuration may be ok however I would hope the design is such it could be
> possible if a suitable use case appears. Will this be possible ?
I have no budget or customer demand to implement dynamic run-time scheduler
re-configuration explicitly, but I have it in mind and will do nothing which
prevents it in the future. I also think it will be very easy to implement if
needed. The blocking point for this is currently that we don't know when a
thread stops execution on a particular processor, but this issue has to be
solved for other purposes as well.
>> The focus is now on static configuration. Every scheduler needs a control
>> context. The scheduler API must provide a macro which creates a global
>> scheduler instance specific data structure with a designator name as a
>> mandatory parameter. The scheduler instance creation macro may require
>> additional scheduler specific configuration options. For example a
>> fixed-priority scheduler instance must know the maximum priority level to
>> allocate the ready chain control table.
>> Once the scheduler instances are configured it must be specified for each
>> processor in the system which scheduler instance owns this processor.
>> For each processor except the initialization processor a scheduler
>> instance is
>> optional so that other operating systems can run independent of this RTEMS
>> system on this processor.
> I am not sure I follow. You say a scheduler instance must be specified for each
> processor then you say for each processor a scheduler instance is optional.
Ok, I will clarify this. It is important that RTEMS doesn't claim all
processors in the system automatically.
> What other operating systems are you referring to ?
You may use for example an RTEMS instance on two processors and Linux on
another 22 of a 24 processor chip.
>> It is a fatal error to omit a scheduler
>> instance for
>> the initialization processor. The initialization processor is the
>> processor
>> which executes the boot_card() function.
> Will RTEMS manage the starting of other cores ? At the moment this is not the
> way it works and it places an unneeded dependency on the boot monitor. I would
> like to see code in RTEMS to manage this and plan to add Zynq support to do this.
The low-level start is a different issue. I have no plans to change something
here at the moment.
>> * @brief Processor configuration.
>> * Use RTEMS_CPU_CONFIG_INIT() to initialize this structure.
>> typedef struct {
>> * @brief Scheduler instance for this processor.
>> * It is possible to omit a scheduler instance for this processor by
>> using
>> * the @c NULL pointer. In this case RTEMS will not use this
>> processor and
>> * other operating systems may claim it.
>> Scheduler_Control *scheduler;
>> } rtems_cpu_config;
>> * @brief Processor configuration initializer.
>> * @param scheduler The reference to a scheduler instance or @c NULL.
>> * @see rtems_cpu_config.
>> #define RTEMS_CPU_CONFIG_INIT(scheduler) \
>> { ( scheduler ) }
>> Scheduler and processor configuration example:
>> RTEMS_SCHED_DEFINE_FP_SMP(sched_fp0, 256);
>> RTEMS_SCHED_DEFINE_FP_SMP(sched_fp1, 64);
>> RTEMS_SCHED_DEFINE_EDF_SMP(sched_edf0);
>> const rtems_cpu_config rtems_cpu_config_table[] = {
>> RTEMS_CPU_CONFIG_INIT(RTEMS_SCHED_REF_FP_SMP(sched_fp0)),
>> RTEMS_CPU_CONFIG_INIT(RTEMS_SCHED_REF_FP_SMP(sched_fp1)),
>> RTEMS_CPU_CONFIG_INIT(NULL),
>> RTEMS_CPU_CONFIG_INIT(RTEMS_SCHED_REF_EDF_SMP(sched_edf0)),
>> const size_t rtems_cpu_config_count =
>> RTEMS_ARRAY_SIZE(rtems_cpu_config_table);
>> An alternative to the processor configuration table would be to specify
>> in the
>> scheduler instance which processors are owned by the instance. This would
>> require a static initialization of CPU sets which is difficult. Also the
>> schedulers have to be registered somewhere, so some sort of table is needed
>> anyway. Since a processor can be owned by at most one scheduler
>> instance this
>> configuration approach enables an additional error source which is
>> avoided by
>> the processor configuration table.
> Is there support to add and remove processors and provide any form of dynamic
> control ?
Currently no, but I don't see any problems for adding this later.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
