Partitioned/clustered scheduling
Fri Nov 22 11:00:01 UTC 2013
On Fri, Nov 22, 2013 at 4:29 AM, Sebastian Huber
> On 2013-11-22 10:23, Sebastian Huber wrote:
>> In the scheduler configuration the user should give a name for the
>> scheduler.
>> The question is should we use a string or a rtems_name?
> A string has the benefit that the scheduler instance define macro can build
> this name from the structure designator name and this ensures that the names
> are unique.  For example
> #define RTEMS_SCHED_DEFINE_FP_SMP(_name) \
> static struct X _name = { \
>         .name = # _name, \
And the cost is some (negligible?) storage and processing overhead?
> rtems-devel mailing list
> rtems-devel at rtems.org
