powerpc/mpc55xxevb build failure
Mon Nov 25 15:27:15 UTC 2013
On 11/25/2013 8:57 AM, Sebastian Huber wrote:
> On 2013-11-25 15:32, Gedare Bloom wrote:
>> On Mon, Nov 25, 2013 at 2:26 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de>  wrote:
>>>> On 2013-11-23 17:11, Joel Sherrill wrote:
>>>>>> On 11/23/2013 9:20 AM, Gedare Bloom wrote:
>>>>>>>>>> In fsdosfsname01 I get the following failure during linking
>>>>>>>>>> link command:
>>>>>>>>>> powerpc-rtems4.11-gcc -B../../../../../mpc5566evb/lib/   -specs
>>>>>>>>>> bsp_specs -qrtems -mcpu=8540 -meabi -msdata -fno-common -msoft-float
>>>>>>>>>> -D__ppc_generic -mstrict-align -O2 -g -fno-keep-inline-functions -Wall
>>>>>>>>>> -Wmissing-prototypes -Wimplicit-function-declaration
>>>>>>>>>> -Wstrict-prototypes -Wnested-externs    -mcpu=8540 -meabi -msdata
>>>>>>>>>> -fno-common -msoft-float -D__ppc_generic -mstrict-align   -o
>>>>>>>>>> fsdosfsname01.exe init.o ramdisk_support.o
>>>>>>>>>> failure:
>>>>>>>>>> linkcmds.base:344 cannot move location counter backwards (from
>>>>>>>>>> 000000004002c5e4 to 0000000040020000)
>>>>>>>>>> collect2: error: ld returned 1 exit status
>>>>>>>>>> This is with HEAD (with the latest patch applied to this bsp) and
>>>>>>>>>> current RSB-built tool set.
>>>>>> This looks like a memory region is full and this test won't fit.
>>>> Yes, the test is too large.  Maybe guard this test with BSP_SMALL_MEMORY?
>> That will work for compiling. How hard would making a similar test
>> with a smaller image be? So that the functionality could be tested on
>> the board if someone wanted?
> I don't know how hard it is to shrink the image and I don't have time to find
> this out at the moment.
Gedare. are these variants declaring some large RAM area to use as a
RAM disk? Maybe it needs to be shrunk for small memory BSPs.
