[PATCH 2/3] bsp/leon3: Avoid copy and paste in console driver
Sebastian Huber
Tue Nov 26 08:19:35 UTC 2013
c/src/lib/libbsp/sparc/leon3/console/console.c | 62 +++++++++---------------
1 files changed, 23 insertions(+), 39 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
index 0b30369..1860e5c 100644
--- a/c/src/lib/libbsp/sparc/leon3/console/console.c
+++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
@@ -82,6 +82,18 @@ struct apbuart_priv {
static struct apbuart_priv apbuarts[BSP_NUMBER_OF_TERMIOS_PORTS];
static int uarts = 0;
+static struct apbuart_priv *leon3_console_get_uart(int minor)
+ struct apbuart_priv *uart;
+ if (minor == 0)
+ uart = &apbuarts[syscon_uart_index];
+ else
+ uart = &apbuarts[minor - 1];
+ return uart;
#if CONSOLE_USE_INTERRUPTS
/* Handle UART interrupts */
@@ -115,14 +127,9 @@ static void leon3_console_isr(void *arg)
static int leon3_console_write_support(int minor, const char *buf, size_t len)
- struct apbuart_priv *uart;
+ struct apbuart_priv *uart = leon3_console_get_uart(minor);
int sending;
- if (minor == 0)
- uart = &apbuarts[syscon_uart_index];
- else
- uart = &apbuarts[minor - 1];
if (len > 0) {
/* Enable TX interrupt (interrupt is edge-triggered) */
uart->regs->ctrl |= LEON_REG_UART_CTRL_TI;
@@ -157,15 +164,11 @@ int console_pollRead(int minor);
ssize_t console_write_polled(int minor, const char *buf, size_t len)
- int nwrite = 0, port;
- if (minor == 0)
- port = syscon_uart_index;
- else
- port = minor - 1;
+ int nwrite = 0;
while (nwrite < len) {
- apbuart_outbyte_polled(apbuarts[port].regs, *buf++, 1, 0);
+ apbuart_outbyte_polled(uart->regs, *buf++, 1, 0);
nwrite++;
return nwrite;
@@ -173,14 +176,9 @@ ssize_t console_write_polled(int minor, const char *buf, size_t len)
- int port;
- if (minor == 0)
- else
- port = minor - 1;
- return apbuart_inbyte_nonblocking(apbuarts[port].regs);
+ return apbuart_inbyte_nonblocking(uart->regs);
#endif
@@ -195,10 +193,10 @@ int console_scan_uarts(void);
int console_set_attributes(int minor, const struct termios *t)
unsigned int scaler;
unsigned int ctrl;
int baud;
switch (t->c_cflag & CSIZE) {
default:
@@ -211,11 +209,6 @@ int console_set_attributes(int minor, const struct termios *t)
break;
- if (minor == 0)
- else
* FIXME: This read-modify-write sequence is broken since interrupts may
* interfere.
@@ -371,15 +364,11 @@ static struct rtems_termios_tty *leon3_console_get_tty(
static int leon3_console_first_open(int major, int minor, void *arg)
- rtems_status_code sc;
- if (minor == 0)
- else
+ rtems_status_code sc;
uart->cookie = leon3_console_get_tty(arg);
/* Register Interrupt handler */
@@ -407,14 +396,9 @@ static int leon3_console_first_open(int major, int minor, void *arg)
static int leon3_console_last_close(int major, int minor, void *arg)
struct rtems_termios_tty *tty = leon3_console_get_tty(arg);
rtems_interrupt_level level;
- if (minor == 0)
- else
/* Turn off RX interrupts */
rtems_termios_interrupt_lock_acquire(tty, level);
uart->regs->ctrl &= ~(LEON_REG_UART_CTRL_RI);
1.7.7
