[PATCH 2/2] Shared MMU initialization for ARM BSPs and RaspberryPi MMU support
Alan Cudmore alan.cudmore at gmail.com
Tue Oct 1 12:46:08 UTC 2013
I will check this out today. I'm in the process of updating my tools and
rtems source.
( suddenly my calendar is clear today.. )
Alan
On 9/28/2013 12:07 PM, Gedare Bloom wrote:
> Looks good on my end. Alan or Sebastian have any comments?
> -Gedare
> On Sat, Sep 28, 2013 at 4:08 AM, Hesham AL-Matary
> <heshamelmatary at gmail.com> wrote:
>> The newly added ORed flag: ARM_CP15_CTRL_XP is vital to get RaspberryPi
>> MMU working properly and to share the container function between various
>> ARM BSPs. The new ORed flags do not affect the current BSPs that make use
>> of arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache function.
>> The rest is of the patch targets MMU initialization for ARM architectures,
>> desgined to be shared. Later patches make use of shared mminit implementation.
>>   c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |  9 ++-
>>   c/src/lib/libbsp/arm/raspberrypi/preinstall.am     |  8 +++
>>   .../libbsp/arm/raspberrypi/startup/bspstarthooks.c | 22 +------
>>   c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds  |  4 +-
>>   .../arm/raspberrypi/startup/mm_config_table.c      | 70 ++++++++++++++++++++++
>>   .../lib/libbsp/arm/shared/include/arm-cp15-start.h | 15 +++--
>>   c/src/lib/libbsp/arm/shared/mminit.c               | 24 ++++++++
>>   c/src/lib/libbsp/shared/include/mm.h               | 25 ++++++++
>>   8 files changed, 151 insertions(+), 26 deletions(-)
>>   create mode 100644 c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>   create mode 100644 c/src/lib/libbsp/arm/shared/mminit.c
>>   create mode 100644 c/src/lib/libbsp/shared/include/mm.h
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> index 24d396c..a06979a 100644
>> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> @@ -27,6 +27,7 @@ nodist_include_HEADERS = ../../shared/include/coverhd.h \
>>   nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
>> +include_bsp_HEADERS += ../../../libbsp/shared/include/mm.h
>>   include_bsp_HEADERS += ../../shared/include/utility.h
>>   include_bsp_HEADERS += ../../shared/include/irq-generic.h
>>   include_bsp_HEADERS += ../../shared/include/irq-info.h
>> @@ -35,6 +36,7 @@ include_bsp_HEADERS += ../../shared/include/uart-output-char.h
>>   include_bsp_HEADERS += ../../shared/tod.h
>>   include_bsp_HEADERS += ../shared/include/linker-symbols.h
>>   include_bsp_HEADERS += ../shared/include/start.h
>> +include_bsp_HEADERS += ../shared/include/arm-cp15-start.h
>>   include_bsp_HEADERS += ../shared/lpc/include/lpc-timer.h
>>   include_bsp_HEADERS += ../shared/lpc/include/lpc-dma.h
>>   include_bsp_HEADERS += include/irq.h
>> @@ -83,7 +85,7 @@ libbsp_a_SOURCES += ../../shared/sbrk.c
>>   libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>>   libbsp_a_SOURCES += ../shared/abort/simple_abort.c
>>   libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
>> +libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
>>   # Startup
>>   libbsp_a_SOURCES += startup/bspreset.c
>> @@ -91,6 +93,7 @@ libbsp_a_SOURCES += startup/bspstart.c
>>   # IRQ
>>   libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
>> +libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
>>   libbsp_a_SOURCES += ../../shared/src/irq-generic.c
>>   libbsp_a_SOURCES += ../../shared/src/irq-info.c
>>   libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
>> @@ -127,6 +130,10 @@ libbsp_a_CPPFLAGS += -I$(srcdir)/../../../libcpu/arm/shared/include
>>   # Start hooks
>>   libbsp_a_SOURCES += startup/bspstarthooks.c
>> +# LIBMM
>> +libbsp_a_SOURCES += startup/mm_config_table.c
>> +libbsp_a_SOURCES += ../shared/mminit.c
>>   # Network                                                    #
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>> index 056c5f1..a638e64 100644
>> --- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>> @@ -62,6 +62,10 @@ $(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INC
>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
>> +$(PROJECT_INCLUDE)/bsp/mm.h: ../../../libbsp/shared/include/mm.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mm.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mm.h
>>   $(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
>> @@ -94,6 +98,10 @@ $(PROJECT_INCLUDE)/bsp/start.h: ../shared/include/start.h $(PROJECT_INCLUDE)/bsp
>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/start.h
>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/start.h
>> +$(PROJECT_INCLUDE)/bsp/arm-cp15-start.h: ../shared/include/arm-cp15-start.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h
>>   $(PROJECT_INCLUDE)/bsp/lpc-timer.h: ../shared/lpc/include/lpc-timer.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lpc-timer.h
>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lpc-timer.h
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
>> index a224168..71b2ff1 100644
>> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
>> @@ -7,6 +7,7 @@
>> + * Copyright (c) 2013. Hesham AL-Matary
>>    * Copyright (c) 2013 by Alan Cudmore
>>    * based on work by:
>>    * Copyright (c) 2009
>> @@ -24,33 +25,16 @@
>>   #include <bspopts.h>
>>   #include <bsp/start.h>
>>   #include <bsp/raspberrypi.h>
>> -#include <bsp/mmu.h>
>> -static void BSP_START_TEXT_SECTION raspberrypi_cache_setup(void)
>> -  uint32_t ctrl = 0;
>> -  /* Disable MMU and cache, basic settings */
>> -  ctrl = arm_cp15_get_control();
>> -  ctrl &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_R | ARM_CP15_CTRL_C
>> -    | ARM_CP15_CTRL_V | ARM_CP15_CTRL_M);
>> -  ctrl |= ARM_CP15_CTRL_S;
>> -  arm_cp15_set_control(ctrl);
>> -  arm_cp15_cache_invalidate();
>> -  arm_cp15_tlb_invalidate();
>> +#include <bsp/mm.h>
>>   void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
>> -  raspberrypi_cache_setup();
>>   void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
>>     bsp_start_copy_sections();
>> +  bsp_memory_management_initialize();
>>     bsp_start_clear_bss();
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
>> index b9a0dd8..c12b348 100644
>> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
>> @@ -35,7 +35,8 @@
>>   MEMORY {
>>           VECTOR_RAM     (AIW) : ORIGIN = 0x0       , LENGTH = 0x8000
>> -        RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M - 0x8000
>> +        RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M - 48K
>> +       RAM_MMU        (AIW) : ORIGIN = 128M - 16k, LENGTH = 16k
>>   REGION_ALIAS ("REGION_START", RAM);
>> @@ -58,5 +59,6 @@ bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size : 4096;
>>   bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
>>   bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1M;
>> +bsp_translation_table_base = ORIGIN (RAM_MMU);
>>   INCLUDE linkcmds.armv4
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>> new file mode 100644
>> index 0000000..fd85513
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>> @@ -0,0 +1,70 @@
>> + * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
>> + *  embedded brains GmbH
>> + *  Dornierstr. 4
>> + *  82178 Puchheim
>> + *  Germany
>> + *  <info at embedded-brains.de>
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + * http://www.rtems.com/license/LICENSE.
>> +#include <bsp/start.h>
>> +#include <bsp/arm-cp15-start.h>
>> +#ifdef RTEMS_SMP
>> +  #define MMU_DATA_READ_WRITE ARMV7_MMU_DATA_READ_WRITE_SHAREABLE
>> +#else
>> +  #define MMU_DATA_READ_WRITE ARMV7_MMU_DATA_READ_WRITE_CACHED
>> +#endif
>> +BSP_START_DATA_SECTION const arm_cp15_start_section_config
>> +bsp_mm_config_table[] = {
>> +    .begin = (uint32_t) bsp_section_fast_text_begin,
>> +    .end = (uint32_t) bsp_section_fast_text_end,
>> +    .flags = ARMV7_MMU_CODE_CACHED
>> +    .begin = (uint32_t) bsp_section_fast_data_begin,
>> +    .end = (uint32_t) bsp_section_fast_data_end,
>> +    .flags = MMU_DATA_READ_WRITE
>> +    .begin = (uint32_t) bsp_section_start_begin,
>> +    .end = (uint32_t) bsp_section_start_end,
>> +    .begin = (uint32_t) bsp_section_vector_begin,
>> +    .end = (uint32_t) bsp_section_vector_end,
>> +    .begin = (uint32_t) bsp_section_text_begin,
>> +    .end = (uint32_t) bsp_section_text_end,
>> +    .begin = (uint32_t) bsp_section_rodata_begin,
>> +    .end = (uint32_t) bsp_section_rodata_end,
>> +    .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
>> +    .begin = (uint32_t) bsp_section_data_begin,
>> +    .end = (uint32_t) bsp_section_data_end,
>> +    .begin = (uint32_t) bsp_section_bss_begin,
>> +    .end = (uint32_t) bsp_section_bss_end,
>> +    .begin = (uint32_t) bsp_section_work_begin,
>> +    .end = (uint32_t) bsp_section_work_end,
>> +    .begin = (uint32_t) bsp_section_stack_begin,
>> +    .end = (uint32_t) bsp_section_stack_end,
>> +BSP_START_DATA_SECTION const size_t bsp_mm_config_table_size =
>> +RTEMS_ARRAY_SIZE(&bsp_mm_config_table);
>> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>> index 01f3104..6a2598b 100644
>> --- a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>> +++ b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>> @@ -1,4 +1,5 @@
>> + * Copyright (c) 2013 Hesham AL-Matary.
>>    * Copyright (c) 2009-2013 embedded brains GmbH.  All rights reserved.
>> @@ -16,13 +17,15 @@
>>   #define LIBBSP_ARM_SHARED_ARM_CP15_START_H
>>   #include <libcpu/arm-cp15.h>
>>   #ifdef __cplusplus
>>   extern "C" {
>>   #endif /* __cplusplus */
>> +extern const arm_cp15_start_section_config bsp_mm_config_table[];
>> +extern const size_t bsp_mm_config_table_size;
>>   BSP_START_TEXT_SECTION static inline void
>>   arm_cp15_set_domain_access_control(uint32_t val);
>> @@ -87,9 +90,9 @@ arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>>     arm_cp15_set_domain_access_control(dac);
>>     arm_cp15_set_translation_table_base(ttb);
>> -  /* Initialize translation table with invalid entries */
>> +  /* Initialize translation table with fixed-map read-write entries */
>>     for (i = 0; i < ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT; ++i) {
>> -    ttb [i] = 0;
>> +    ttb [i] = (i << ARM_MMU_SECT_BASE_SHIFT) | ARMV7_MMU_DATA_READ_WRITE;
>>     for (i = 0; i < config_count; ++i) {
>> @@ -97,7 +100,9 @@ arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>>     /* Enable MMU and cache */
>> -  ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
>> +  ctrl |= ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_S | ARM_CP15_CTRL_I |
>> +          ARM_CP15_CTRL_C | ARM_CP15_CTRL_M  | ARM_CP15_CTRL_XP;
>> diff --git a/c/src/lib/libbsp/arm/shared/mminit.c b/c/src/lib/libbsp/arm/shared/mminit.c
>> index 0000000..0ea9805
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/arm/shared/mminit.c
>> @@ -0,0 +1,24 @@
>> +#include <bsp/linker-symbols.h>
>> +BSP_START_TEXT_SECTION void bsp_memory_management_initialize(void)
>> +  uint32_t ctrl = arm_cp15_get_control();
>> +  arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>> +    ctrl,
>> +    (uint32_t *) bsp_translation_table_base,
>> +    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
>> +    &bsp_mm_config_table[0],
>> +    bsp_mm_config_table_size
>> diff --git a/c/src/lib/libbsp/shared/include/mm.h b/c/src/lib/libbsp/shared/include/mm.h
>> index 0000000..1a1eb7f
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/shared/include/mm.h
>> @@ -0,0 +1,25 @@
>> + * Copyright (c) 2013 Gedare Bloom.
>> +#ifndef __LIBBSP_MM_H
>> +#define __LIBBSP_MM_H
>> +#include <stdint.h>
>> +#include <stdlib.h>
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif
>> +void bsp_memory_management_initialize(void);
>> +#ifdef __cplusplus
>> +#endif
>> +#endif
>> 1.8.3.1
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
