[rtems commit] Shared MMU initialization for ARM BSPs and RaspberryPi MMU support
    Gedare Bloom
    gedare at rtems.org
    Fri Oct  4 12:57:44 UTC 2013
On Fri, Oct 4, 2013 at 5:58 AM, Sebastian Huber
> On 2013-10-04 11:07, Hesham Moustafa wrote:
>> On Fri, Oct 4, 2013 at 9:50 AM, Sebastian Huber
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>     On 2013-10-03 14:49, Gedare Bloom wrote:
>>         @@ -87,9 +90,9 @@
>> arm_cp15_start_setup___translation_table_and_enable___mmu_and_cache(
>>              arm_cp15_set_domain_access___control(dac);
>>              arm_cp15_set_translation___table_base(ttb);
>>         -  /* Initialize translation table with invalid entries */
>>         +  /* Initialize translation table with fixed-map read-write
>> entries */
>>              for (i = 0; i < ARM_MMU_TRANSLATION_TABLE___ENTRY_COUNT; ++i)
>>         -    ttb [i] = 0;
>>         +    ttb [i] = (i << ARM_MMU_SECT_BASE_SHIFT) |
>> ARMV7_MMU_DATA_READ_WRITE;
>>     What is the reason for this change?  I don't think that unconditional
>>     read-write access is a good idea.
>> I made this change when I was trying to get RaspberryPi MMU initialization
>> to
>> work.
> Then it is probably better to fix the memory map description of this
> particular BSP.
>> Also I thought
>> the default behavior for RTEMS is the unprotected mode, and the new
>> protection
>> (limitation) attributes
>> are new and should be applied when needed (by configuration table at
>> startup or
>> dynamically).
> Allow everything with explicit deny is very bad design.  It should be always
> deny everything with explicit allow.
Thanks Sebastian, I agree with everything you say here Hesham, please
revert this to initializing to 0 attributes and fix the raspberrypi
BSP accordingly.
-Gedare
> rtems-devel mailing list
> rtems-devel at rtems.org
