[rtems commit] delete smpatomic0-7 test cases
Deng Hengyi wei.a.yang at gmail.com
Tue Oct 8 14:56:17 UTC 2013
There should be anther two patches which merge the smpatomic0-7 into one test case.
在 2013-10-8,下午10:48,Joel Sherrill <joel.sherrill at oarcorp.com> 写道:
> On 10/8/2013 9:34 AM, Deng Hengyi wrote:
>> Yeah, merge all the smpatomic01-07 test cases into one test case and simplify the test case.
> OK. That was far from clear with the patch that just deleted all the
> tests. :)
> --joel
>> 在 2013-10-8,下午10:28,Joel Sherrill <joel.sherrill at oarcorp.com> 写道:
>>> Can you clarify why you deleted these?
>>> Are you adding replacement tests for this code?
>>> On 10/8/2013 9:01 AM, Sebastian Huber wrote:
>>>> Module:    rtems
>>>> Branch:    master
>>>> Commit:    27a034ef13e70493eb8457821b87346ee96ee4f8
>>>> Changeset: http://git.rtems.org/rtems/commit/?id=27a034ef13e70493eb8457821b87346ee96ee4f8
>>>> Author:    WeiY <wei.a.yang at gmail.com>
>>>> Date:      Sat Sep 28 14:54:37 2013 +0800
>>>> testsuites/smptests/Makefile.am                 |    7 --
>>>> testsuites/smptests/configure.ac                |    7 --
>>>> testsuites/smptests/smpatomic01/Makefile.am     |   20 -----
>>>> testsuites/smptests/smpatomic01/init.c          |   72 -----------------
>>>> testsuites/smptests/smpatomic01/smpatomic01.doc |   23 ------
>>>> testsuites/smptests/smpatomic01/smpatomic01.scn |   28 -------
>>>> testsuites/smptests/smpatomic01/system.h        |   50 ------------
>>>> testsuites/smptests/smpatomic01/tasks.c         |   73 -----------------
>>>> testsuites/smptests/smpatomic02/Makefile.am     |   20 -----
>>>> testsuites/smptests/smpatomic02/init.c          |   72 -----------------
>>>> testsuites/smptests/smpatomic02/smpatomic02.doc |   23 ------
>>>> testsuites/smptests/smpatomic02/smpatomic02.scn |   28 -------
>>>> testsuites/smptests/smpatomic02/system.h        |   50 ------------
>>>> testsuites/smptests/smpatomic02/tasks.c         |   73 -----------------
>>>> testsuites/smptests/smpatomic03/Makefile.am     |   20 -----
>>>> testsuites/smptests/smpatomic03/init.c          |   72 -----------------
>>>> testsuites/smptests/smpatomic03/smpatomic03.doc |   23 ------
>>>> testsuites/smptests/smpatomic03/smpatomic03.scn |   29 -------
>>>> testsuites/smptests/smpatomic03/system.h        |   50 ------------
>>>> testsuites/smptests/smpatomic03/tasks.c         |   81 -------------------
>>>> testsuites/smptests/smpatomic04/Makefile.am     |   20 -----
>>>> testsuites/smptests/smpatomic04/init.c          |   72 -----------------
>>>> testsuites/smptests/smpatomic04/smpatomic04.doc |   23 ------
>>>> testsuites/smptests/smpatomic04/smpatomic04.scn |   29 -------
>>>> testsuites/smptests/smpatomic04/system.h        |   50 ------------
>>>> testsuites/smptests/smpatomic04/tasks.c         |   81 -------------------
>>>> testsuites/smptests/smpatomic05/Makefile.am     |   20 -----
>>>> testsuites/smptests/smpatomic05/init.c          |   72 -----------------
>>>> testsuites/smptests/smpatomic05/smpatomic05.doc |   23 ------
>>>> testsuites/smptests/smpatomic05/smpatomic05.scn |   29 -------
>>>> testsuites/smptests/smpatomic05/system.h        |   50 ------------
>>>> testsuites/smptests/smpatomic05/tasks.c         |   81 -------------------
>>>> testsuites/smptests/smpatomic06/Makefile.am     |   20 -----
>>>> testsuites/smptests/smpatomic06/init.c          |   72 -----------------
>>>> testsuites/smptests/smpatomic06/smpatomic06.doc |   23 ------
>>>> testsuites/smptests/smpatomic06/smpatomic06.scn |   29 -------
>>>> testsuites/smptests/smpatomic06/system.h        |   50 ------------
>>>> testsuites/smptests/smpatomic06/tasks.c         |   81 -------------------
>>>> testsuites/smptests/smpatomic07/Makefile.am     |   20 -----
>>>> testsuites/smptests/smpatomic07/init.c          |   72 -----------------
>>>> testsuites/smptests/smpatomic07/smpatomic07.doc |   24 ------
>>>> testsuites/smptests/smpatomic07/smpatomic07.scn |   29 -------
>>>> testsuites/smptests/smpatomic07/system.h        |   50 ------------
>>>> testsuites/smptests/smpatomic07/tasks.c         |   97 -----------------------
>>>> 44 files changed, 0 insertions(+), 1938 deletions(-)
>>>> diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
>>>> index 55d612f..d8b5a3e 100644
>>>> --- a/testsuites/smptests/Makefile.am
>>>> +++ b/testsuites/smptests/Makefile.am
>>>> @@ -12,13 +12,6 @@ SUBDIRS += smp07
>>>> SUBDIRS += smp08
>>>> SUBDIRS += smp09
>>>> if ATOMIC
>>>> -SUBDIRS += smpatomic01
>>>> -SUBDIRS += smpatomic02
>>>> -SUBDIRS += smpatomic03
>>>> -SUBDIRS += smpatomic04
>>>> -SUBDIRS += smpatomic05
>>>> -SUBDIRS += smpatomic06
>>>> -SUBDIRS += smpatomic07
>>>> SUBDIRS += smpatomic08
>>>> endif
>>>> SUBDIRS += smplock01
>>>> diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
>>>> index 05b9056..35f704d 100644
>>>> --- a/testsuites/smptests/configure.ac
>>>> +++ b/testsuites/smptests/configure.ac
>>>> @@ -46,13 +46,6 @@ smp06/Makefile
>>>> smp07/Makefile
>>>> smp08/Makefile
>>>> smp09/Makefile
>>>> -smpatomic01/Makefile
>>>> -smpatomic02/Makefile
>>>> -smpatomic03/Makefile
>>>> -smpatomic04/Makefile
>>>> -smpatomic05/Makefile
>>>> -smpatomic06/Makefile
>>>> -smpatomic07/Makefile
>>>> smpatomic08/Makefile
>>>> smplock01/Makefile
>>>> smpmigration01/Makefile
>>>> diff --git a/testsuites/smptests/smpatomic01/Makefile.am b/testsuites/smptests/smpatomic01/Makefile.am
>>>> deleted file mode 100644
>>>> index 7bd5502..0000000
>>>> --- a/testsuites/smptests/smpatomic01/Makefile.am
>>>> +++ /dev/null
>>>> @@ -1,20 +0,0 @@
>>>> -rtems_tests_PROGRAMS = smpatomic01
>>>> -smpatomic01_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>>> -dist_rtems_tests_DATA = smpatomic01.scn
>>>> -dist_rtems_tests_DATA += smpatomic01.doc
>>>> -include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
>>>> -include $(top_srcdir)/../automake/compile.am
>>>> -include $(top_srcdir)/../automake/leaf.am
>>>> -AM_CPPFLAGS += -I$(top_srcdir)/../support/include
>>>> -LINK_OBJS = $(smpatomic01_OBJECTS)
>>>> -LINK_LIBS = $(smpatomic01_LDLIBS)
>>>> -smpatomic01$(EXEEXT): $(smpatomic01_OBJECTS) $(smpatomic01_DEPENDENCIES)
>>>> -       @rm -f smpatomic01$(EXEEXT)
>>>> -       $(make-exe)
>>>> -include $(top_srcdir)/../automake/local.am
>>>> diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
>>>> index f7dfa11..0000000
>>>> --- a/testsuites/smptests/smpatomic01/init.c
>>>> +++ /dev/null
>>>> @@ -1,72 +0,0 @@
>>>> - * Copyright (c) 2012 Deng Hengyi.
>>>> - *  This test case is to test atomic load operation.
>>>> - *  The license and distribution terms for this file may be
>>>> - *  found in the file LICENSE in this distribution or at
>>>> - *  http://www.rtems.com/license/LICENSE.
>>>> -#ifdef HAVE_CONFIG_H
>>>> -#include "config.h"
>>>> -#endif
>>>> -#define CONFIGURE_INIT
>>>> -#include "system.h"
>>>> -rtems_task Init(
>>>> -  rtems_task_argument argument
>>>> -  int                i;
>>>> -  char               ch;
>>>> -  rtems_id           id;
>>>> -  rtems_status_code  status;
>>>> -  bool               allDone;
>>>> -  /* XXX - Delay a bit to allow debug messages from
>>>> -   * startup to print.  This may need to go away when
>>>> -   * debug messages go away.
>>>> -  locked_print_initialize();
>>>> -  /* Put start of test message */
>>>> -  locked_printf( "\n\n***  SMPatomic01 TEST ***\n" );
>>>> -  /* Initialize the TaskRan array */
>>>> -  for ( i=0; i<rtems_smp_get_processor_count() ; i++ ) {
>>>> -    TaskRan[i] = false;
>>>> -  /* Create and start tasks for each processor */
>>>> -  for ( i=1; i< rtems_smp_get_processor_count() ; i++ ) {
>>>> -    ch = '0' + i;
>>>> -    status = rtems_task_create(
>>>> -      rtems_build_name( 'T', 'A', ch, ' ' ),
>>>> -      1,
>>>> -      RTEMS_MINIMUM_STACK_SIZE,
>>>> -      RTEMS_DEFAULT_MODES,
>>>> -      RTEMS_DEFAULT_ATTRIBUTES,
>>>> -      &id
>>>> -    directive_failed( status, "task create" );
>>>> -    status = rtems_task_start( id, Test_task, i+1 );
>>>> -    directive_failed( status, "task start" );
>>>> -  /* Wait on the all tasks to run */
>>>> -  while (1) {
>>>> -    allDone = true;
>>>> -    for ( i=1; i<rtems_smp_get_processor_count() ; i++ ) {
>>>> -      if (TaskRan[i] == false)
>>>> -        allDone = false;
>>>> -    if (allDone) {
>>>> -      locked_printf( "\n\n*** END OF TEST SMPatomic01 ***\n" );
>>>> -      rtems_test_exit( 0 );
>>>> diff --git a/testsuites/smptests/smpatomic01/smpatomic01.doc b/testsuites/smptests/smpatomic01/smpatomic01.doc
>>>> index 3d83245..0000000
>>>> --- a/testsuites/smptests/smpatomic01/smpatomic01.doc
>>>> +++ /dev/null
>>>> @@ -1,23 +0,0 @@
>>>> -#  COPYRIGHT (c) 1989-2012.
>>>> -#  On-Line Applications Research Corporation (OAR).
>>>> -#  The license and distribution terms for this file may be
>>>> -#  found in the file LICENSE in this distribution or at
>>>> -#  http://www.rtems.com/license/LICENSE.
>>>> -This file describes the directives and concepts tested by this test set.
>>>> -test set name:  smpatomic01
>>>> -directives:
>>>> -  _Atomic_Load_int
>>>> -  _Atomic_Load_long
>>>> -  _Atomic_Load_ptr
>>>> -  _Atomic_Load_32
>>>> -  _Atomic_Load_64
>>>> -concepts:
>>>> -+ Ensure that the atomic load operations listed above behave as defined.
>>>> diff --git a/testsuites/smptests/smpatomic01/smpatomic01.scn b/testsuites/smptests/smpatomic01/smpatomic01.scn
>>>> index dba0d5c..0000000
>>>> --- a/testsuites/smptests/smpatomic01/smpatomic01.scn
>>>> +++ /dev/null
>>>> @@ -1,28 +0,0 @@
>>>> -***  SMPatomic01 TEST ***
>>>> -CPU1 _Atomic_Load_int: SUCCESS
>>>> -CPU2 _Atomic_Load_int: SUCCESS
>>>> -CPU3 _Atomic_Load_int: SUCCESS
>>>> -CPU1 _Atomic_Load_long: SUCCESS
>>>> -CPU2 _Atomic_Load_long: SUCCESS
>>>> -CPU3 _Atomic_Load_long: SUCCESS
>>>> -CPU1 _Atomic_Load_ptr: SUCCESS
>>>> -CPU3 _Atomic_Load_ptr: SUCCESS
>>>> -CPU2 _Atomic_Load_ptr: SUCCESS
>>>> -CPU1 _Atomic_Load_32: SUCCESS
>>>> -CPU2 _Atomic_Load_32: SUCCESS
>>>> -CPU3 _Atomic_Load_32: SUCCESS
>>>> -*** END OF TEST SMPatomic01 ***
>>>> diff --git a/testsuites/smptests/smpatomic01/system.h b/testsuites/smptests/smpatomic01/system.h
>>>> index da314a2..0000000
>>>> --- a/testsuites/smptests/smpatomic01/system.h
>>>> +++ /dev/null
>>>> @@ -1,50 +0,0 @@
>>>> - *  COPYRIGHT (c) 1989-2011.
>>>> - *  On-Line Applications Research Corporation (OAR).
>>>> -#include "tmacros.h"
>>>> -#include "test_support.h"
>>>> -/* functions */
>>>> -rtems_task Init(
>>>> -rtems_task Test_task(
>>>> -/* configuration information */
>>>> -#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>>>> -#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>> -#define CONFIGURE_SMP_APPLICATION
>>>> -#define CONFIGURE_SMP_MAXIMUM_PROCESSORS   4
>>>> -#define CONFIGURE_MAXIMUM_TASKS            \
>>>> -    (1 + CONFIGURE_SMP_MAXIMUM_PROCESSORS)
>>>> -#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>> -#include <rtems/confdefs.h>
>>>> -/* global variables */
>>>> - *  Keep the names and IDs in global variables so another task can use them.
>>>> -TEST_EXTERN volatile bool TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS ];
>>>> - *  Handy macros and static inline functions
>>>> -/* end of include file */
>>>> diff --git a/testsuites/smptests/smpatomic01/tasks.c b/testsuites/smptests/smpatomic01/tasks.c
>>>> index 4dd2ff6..0000000
>>>> --- a/testsuites/smptests/smpatomic01/tasks.c
>>>> +++ /dev/null
>>>> @@ -1,73 +0,0 @@
>>>> -#endif
>>>> -#include <stdlib.h>
>>>> -#include <rtems/rtems/atomic.h>
>>>> -#define TEST_REPEAT 1000
>>>> -#define ATOMIC_LOAD_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)     \
>>>> -  Atomic_##TYPE t;                                       \
>>>> -  R_TYPE a;                                              \
>>>> -  R_TYPE b;                                              \
>>>> -  unsigned int i;                                        \
>>>> -  for (i = 0; i < TEST_REPEAT; i++){                     \
>>>> -    b = (R_TYPE)rand();                                  \
>>>> -    atomic_init(&t, b);                                  \
>>>> -    a = _Atomic_Load_##NAME(&t, mem_bar);                \
>>>> -    rtems_test_assert(a == b);                           \
>>>> -  locked_printf("\nCPU%d Atomic_Load_" #NAME ": SUCCESS\n", cpuid); \
>>>> -  uint32_t          cpu_num;
>>>> -  char              name[5];
>>>> -  char             *p;
>>>> -  /* Get the task name */
>>>> -  p = rtems_object_get_name( RTEMS_SELF, 5, name );
>>>> -  rtems_test_assert( p != NULL );
>>>> -   /* Get the CPU Number */
>>>> -  cpu_num = rtems_smp_get_current_processor();
>>>> -  /* Print that the task is up and running. */
>>>> -  /* test relaxed barrier */
>>>> -  ATOMIC_LOAD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  /* test acquire barrier */
>>>> -  ATOMIC_LOAD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -//  ATOMIC_LOAD_NO_BARRIER(64, cpu_num);
>>>> -  /* Set the flag that the task is up and running */
>>>> -  TaskRan[cpu_num] = true;
>>>> -  /* Drop into a loop which will keep this task on
>>>> -   * running on the cpu.
>>>> -  while(1);
>>>> diff --git a/testsuites/smptests/smpatomic02/Makefile.am b/testsuites/smptests/smpatomic02/Makefile.am
>>>> index 04fc5e4..0000000
>>>> --- a/testsuites/smptests/smpatomic02/Makefile.am
>>>> +++ /dev/null
>>>> @@ -1,20 +0,0 @@
>>>> -rtems_tests_PROGRAMS = smpatomic02
>>>> -smpatomic02_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>>> -dist_rtems_tests_DATA = smpatomic02.scn
>>>> -dist_rtems_tests_DATA += smpatomic02.doc
>>>> -LINK_OBJS = $(smpatomic02_OBJECTS)
>>>> -LINK_LIBS = $(smpatomic02_LDLIBS)
>>>> -smpatomic02$(EXEEXT): $(smpatomic02_OBJECTS) $(smpatomic02_DEPENDENCIES)
>>>> -       $(make-exe)
>>>> diff --git a/testsuites/smptests/smpatomic02/init.c b/testsuites/smptests/smpatomic02/init.c
>>>> index 9e0da4b..0000000
>>>> --- a/testsuites/smptests/smpatomic02/init.c
>>>> +++ /dev/null
>>>> @@ -1,72 +0,0 @@
>>>> - *  This test case is to test atomic store operation.
>>>> -#endif
>>>> -rtems_task Init(
>>>> -  int                i;
>>>> -  char               ch;
>>>> -  rtems_id           id;
>>>> -  bool               allDone;
>>>> -  locked_printf( "\n\n***  SMPatomic02 TEST ***\n" );
>>>> -    ch = '0' + i;
>>>> -      1,
>>>> -      &id
>>>> -  while (1) {
>>>> -    allDone = true;
>>>> -        allDone = false;
>>>> -    if (allDone) {
>>>> -      locked_printf( "\n\n*** END OF TEST SMPatomic02 ***\n" );
>>>> diff --git a/testsuites/smptests/smpatomic02/smpatomic02.doc b/testsuites/smptests/smpatomic02/smpatomic02.doc
>>>> index d1ab4f5..0000000
>>>> --- a/testsuites/smptests/smpatomic02/smpatomic02.doc
>>>> +++ /dev/null
>>>> @@ -1,23 +0,0 @@
>>>> -test set name:  smpatomic02
>>>> -directives:
>>>> -  _Atomic_Store_int
>>>> -  _Atomic_Store_long
>>>> -  _Atomic_Store_ptr
>>>> -  _Atomic_Store_32
>>>> -  _Atomic_Store_64
>>>> -concepts:
>>>> -+ Ensure that the atomic store operations listed above behave as defined.
>>>> diff --git a/testsuites/smptests/smpatomic02/smpatomic02.scn b/testsuites/smptests/smpatomic02/smpatomic02.scn
>>>> index de8fe2c..0000000
>>>> --- a/testsuites/smptests/smpatomic02/smpatomic02.scn
>>>> +++ /dev/null
>>>> @@ -1,28 +0,0 @@
>>>> -***  SMPatomic02 TEST ***
>>>> -CPU1 _Atomic_Store_int: SUCCESS
>>>> -CPU2 _Atomic_Store_int: SUCCESS
>>>> -CPU3 _Atomic_Store_int: SUCCESS
>>>> -CPU1 _Atomic_Store_long: SUCCESS
>>>> -CPU2 _Atomic_Store_long: SUCCESS
>>>> -CPU3 _Atomic_Store_long: SUCCESS
>>>> -CPU1 _Atomic_Store_ptr: SUCCESS
>>>> -CPU3 _Atomic_Store_ptr: SUCCESS
>>>> -CPU2 _Atomic_Store_ptr: SUCCESS
>>>> -CPU1 _Atomic_Store_32: SUCCESS
>>>> -CPU2 _Atomic_Store_32: SUCCESS
>>>> -CPU3 _Atomic_Store_32: SUCCESS
>>>> -*** END OF TEST SMPatomic02 ***
>>>> diff --git a/testsuites/smptests/smpatomic02/system.h b/testsuites/smptests/smpatomic02/system.h
>>>> --- a/testsuites/smptests/smpatomic02/system.h
>>>> +++ /dev/null
>>>> @@ -1,50 +0,0 @@
>>>> -/* functions */
>>>> -rtems_task Init(
>>>> diff --git a/testsuites/smptests/smpatomic02/tasks.c b/testsuites/smptests/smpatomic02/tasks.c
>>>> index c5c9ba5..0000000
>>>> --- a/testsuites/smptests/smpatomic02/tasks.c
>>>> +++ /dev/null
>>>> @@ -1,73 +0,0 @@
>>>> -#endif
>>>> -#define ATOMIC_STORE_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)    \
>>>> -  R_TYPE a;                                              \
>>>> -  R_TYPE b;                                              \
>>>> -  unsigned int i;                                        \
>>>> -    _Atomic_Store_##NAME(&t, b, mem_bar);                \
>>>> -    a = _Atomic_Load_##NAME(&t, ATOMIC_ORDER_ACQUIRE);   \
>>>> -  locked_printf("\nCPU%d Atomic_Store_" #NAME ": SUCCESS\n", cpuid); \
>>>> -  uint32_t          cpu_num;
>>>> -  char              name[5];
>>>> -  char             *p;
>>>> -  ATOMIC_STORE_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_STORE_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  /* test release barrier */
>>>> -  ATOMIC_STORE_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -  ATOMIC_STORE_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -//  ATOMIC_STORE_NO_BARRIER(64, cpu_num);
>>>> -  while(1);
>>>> diff --git a/testsuites/smptests/smpatomic03/Makefile.am b/testsuites/smptests/smpatomic03/Makefile.am
>>>> index cebd323..0000000
>>>> --- a/testsuites/smptests/smpatomic03/Makefile.am
>>>> +++ /dev/null
>>>> @@ -1,20 +0,0 @@
>>>> -rtems_tests_PROGRAMS = smpatomic03
>>>> -smpatomic03_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>>> -dist_rtems_tests_DATA = smpatomic03.scn
>>>> -dist_rtems_tests_DATA += smpatomic03.doc
>>>> -LINK_OBJS = $(smpatomic03_OBJECTS)
>>>> -LINK_LIBS = $(smpatomic03_LDLIBS)
>>>> -smpatomic03$(EXEEXT): $(smpatomic03_OBJECTS) $(smpatomic03_DEPENDENCIES)
>>>> -       @rm -f smpatomic03$(EXEEXT)
>>>> -       $(make-exe)
>>>> diff --git a/testsuites/smptests/smpatomic03/init.c b/testsuites/smptests/smpatomic03/init.c
>>>> index bf5b2a0..0000000
>>>> --- a/testsuites/smptests/smpatomic03/init.c
>>>> +++ /dev/null
>>>> @@ -1,72 +0,0 @@
>>>> - *  This test case is to test atomic add operation.
>>>> -#endif
>>>> -rtems_task Init(
>>>> -  int                i;
>>>> -  char               ch;
>>>> -  rtems_id           id;
>>>> -  bool               allDone;
>>>> -  locked_printf( "\n\n***  SMPatomic03 TEST ***\n" );
>>>> -    ch = '0' + i;
>>>> -      1,
>>>> -      &id
>>>> -  while (1) {
>>>> -    allDone = true;
>>>> -        allDone = false;
>>>> -    if (allDone) {
>>>> -      locked_printf( "\n\n*** END OF TEST SMPatomic03 ***\n" );
>>>> diff --git a/testsuites/smptests/smpatomic03/smpatomic03.doc b/testsuites/smptests/smpatomic03/smpatomic03.doc
>>>> index d70a37c..0000000
>>>> --- a/testsuites/smptests/smpatomic03/smpatomic03.doc
>>>> +++ /dev/null
>>>> @@ -1,23 +0,0 @@
>>>> -test set name:  smpatomic03
>>>> -directives:
>>>> -  _Atomic_Fetch_add_int
>>>> -  _Atomic_Fetch_add_long
>>>> -  _Atomic_Fetch_add_ptr
>>>> -  _Atomic_Fetch_add_32
>>>> -  _Atomic_Fetch_add_64
>>>> -concepts:
>>>> -+ Ensure that the atomic add operations listed above behave as defined.
>>>> diff --git a/testsuites/smptests/smpatomic03/smpatomic03.scn b/testsuites/smptests/smpatomic03/smpatomic03.scn
>>>> index 92d3846..0000000
>>>> --- a/testsuites/smptests/smpatomic03/smpatomic03.scn
>>>> +++ /dev/null
>>>> @@ -1,29 +0,0 @@
>>>> -***  SMPatomic03 TEST ***
>>>> -CPU2 _Atomic_Fetch_add_int: SUCCESS
>>>> -CPU1 _Atomic_Fetch_add_int: SUCCESS
>>>> -CPU3 _Atomic_Fetch_add_int: SUCCESS
>>>> -CPU2 _Atomic_Fetch_add_long: SUCCESS
>>>> -CPU2 _Atomic_Fetch_add_ptr: SUCCESS
>>>> -CPU3 _Atomic_Fetch_add_long: SUCCESS
>>>> -CPU1 _Atomic_Fetch_add_long: SUCCESS
>>>> -CPU1 _Atomic_Fetch_add_ptr: SUCCESS
>>>> -CPU2 _Atomic_Fetch_add_32: SUCCESS
>>>> -CPU3 _Atomic_Fetch_add_ptr: SUCCESS
>>>> -CPU1 _Atomic_Fetch_add_32: SUCCESS
>>>> -CPU3 _Atomic_Fetch_add_32: SUCCESS
>>>> -*** END OF TEST SMPatomic03 ***
>>>> diff --git a/testsuites/smptests/smpatomic03/system.h b/testsuites/smptests/smpatomic03/system.h
>>>> --- a/testsuites/smptests/smpatomic03/system.h
>>>> +++ /dev/null
>>>> @@ -1,50 +0,0 @@
>>>> -/* functions */
>>>> -rtems_task Init(
>>>> diff --git a/testsuites/smptests/smpatomic03/tasks.c b/testsuites/smptests/smpatomic03/tasks.c
>>>> index 5010549..0000000
>>>> --- a/testsuites/smptests/smpatomic03/tasks.c
>>>> +++ /dev/null
>>>> @@ -1,81 +0,0 @@
>>>> -#endif
>>>> -#define ATOMIC_FETCH_ADD_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)\
>>>> -  R_TYPE a;                                              \
>>>> -  R_TYPE b;                                              \
>>>> -  R_TYPE c;                                              \
>>>> -  unsigned int i;                                        \
>>>> -    a = (R_TYPE)(rand() % ((R_TYPE)-1 / 2));             \
>>>> -    b = (R_TYPE)(rand() % ((R_TYPE)-1 / 2));             \
>>>> -    _Atomic_Store_##NAME(&t, a, ATOMIC_ORDER_RELEASE);   \
>>>> -    _Atomic_Fetch_add_##NAME(&t, b, mem_bar);            \
>>>> -    c = _Atomic_Load_##NAME(&t, ATOMIC_ORDER_ACQUIRE);   \
>>>> -    rtems_test_assert(c == (R_TYPE)(a + b));             \
>>>> -  locked_printf("\nCPU%d Atomic_Fetch_add_" #NAME ": SUCCESS\n", cpuid); \
>>>> -  uint32_t          cpu_num;
>>>> -  char              name[5];
>>>> -  char             *p;
>>>> -  ATOMIC_FETCH_ADD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_FETCH_ADD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_FETCH_ADD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -  ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -//  ATOMIC_FETCH_ADD_NO_BARRIER(64, cpu_num);
>>>> -  while(1);
>>>> diff --git a/testsuites/smptests/smpatomic04/Makefile.am b/testsuites/smptests/smpatomic04/Makefile.am
>>>> index 6b71e10..0000000
>>>> --- a/testsuites/smptests/smpatomic04/Makefile.am
>>>> +++ /dev/null
>>>> @@ -1,20 +0,0 @@
>>>> -rtems_tests_PROGRAMS = smpatomic04
>>>> -smpatomic04_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>>> -dist_rtems_tests_DATA = smpatomic04.scn
>>>> -dist_rtems_tests_DATA += smpatomic04.doc
>>>> -LINK_OBJS = $(smpatomic04_OBJECTS)
>>>> -LINK_LIBS = $(smpatomic04_LDLIBS)
>>>> -smpatomic04$(EXEEXT): $(smpatomic04_OBJECTS) $(smpatomic04_DEPENDENCIES)
>>>> -       @rm -f smpatomic04$(EXEEXT)
>>>> -       $(make-exe)
>>>> diff --git a/testsuites/smptests/smpatomic04/init.c b/testsuites/smptests/smpatomic04/init.c
>>>> index 8398515..0000000
>>>> --- a/testsuites/smptests/smpatomic04/init.c
>>>> +++ /dev/null
>>>> @@ -1,72 +0,0 @@
>>>> - *  This test case is to test atomic sub operation.
>>>> -#endif
>>>> -rtems_task Init(
>>>> -  int                i;
>>>> -  char               ch;
>>>> -  rtems_id           id;
>>>> -  bool               allDone;
>>>> -  locked_printf( "\n\n***  SMPatomic04 TEST ***\n" );
>>>> -    ch = '0' + i;
>>>> -      1,
>>>> -      &id
>>>> -  while (1) {
>>>> -    allDone = true;
>>>> -        allDone = false;
>>>> -    if (allDone) {
>>>> -      locked_printf( "\n\n*** END OF TEST SMPatomic04 ***\n" );
>>>> diff --git a/testsuites/smptests/smpatomic04/smpatomic04.doc b/testsuites/smptests/smpatomic04/smpatomic04.doc
>>>> index afa91ba..0000000
>>>> --- a/testsuites/smptests/smpatomic04/smpatomic04.doc
>>>> +++ /dev/null
>>>> @@ -1,23 +0,0 @@
>>>> -test set name:  smpatomic04
>>>> -directives:
>>>> -  _Atomic_Fetch_sub_int
>>>> -  _Atomic_Fetch_sub_long
>>>> -  _Atomic_Fetch_sub_ptr
>>>> -  _Atomic_Fetch_sub_32
>>>> -  _Atomic_Fetch_sub_64
>>>> -concepts:
>>>> -+ Ensure that the atomic sub operations listed above behave as defined.
>>>> diff --git a/testsuites/smptests/smpatomic04/smpatomic04.scn b/testsuites/smptests/smpatomic04/smpatomic04.scn
>>>> index a47d27d..0000000
>>>> --- a/testsuites/smptests/smpatomic04/smpatomic04.scn
>>>> +++ /dev/null
>>>> @@ -1,29 +0,0 @@
>>>> -***  SMPatomic04 TEST ***
>>>> -CPU2 _Atomic_Fetch_sub_int: SUCCESS
>>>> -CPU1 _Atomic_Fetch_sub_int: SUCCESS
>>>> -CPU3 _Atomic_Fetch_sub_int: SUCCESS
>>>> -CPU2 _Atomic_Fetch_sub_long: SUCCESS
>>>> -CPU3 _Atomic_Fetch_sub_long: SUCCESS
>>>> -CPU1 _Atomic_Fetch_sub_long: SUCCESS
>>>> -CPU3 _Atomic_Fetch_sub_ptr: SUCCESS
>>>> -CPU1 _Atomic_Fetch_sub_ptr: SUCCESS
>>>> -CPU2 _Atomic_Fetch_sub_ptr: SUCCESS
>>>> -CPU3 _Atomic_Fetch_sub_32: SUCCESS
>>>> -CPU1 _Atomic_Fetch_sub_32: SUCCESS
>>>> -CPU2 _Atomic_Fetch_sub_32: SUCCESS
>>>> -*** END OF TEST SMPatomic04 ***
>>>> diff --git a/testsuites/smptests/smpatomic04/system.h b/testsuites/smptests/smpatomic04/system.h
>>>> --- a/testsuites/smptests/smpatomic04/system.h
>>>> +++ /dev/null
>>>> @@ -1,50 +0,0 @@
>>>> -/* functions */
>>>> -rtems_task Init(
>>>> diff --git a/testsuites/smptests/smpatomic04/tasks.c b/testsuites/smptests/smpatomic04/tasks.c
>>>> index 18632cd..0000000
>>>> --- a/testsuites/smptests/smpatomic04/tasks.c
>>>> +++ /dev/null
>>>> @@ -1,81 +0,0 @@
>>>> -#endif
>>>> -#define ATOMIC_FETCH_SUB_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)\
>>>> -  R_TYPE a;                                              \
>>>> -  R_TYPE b;                                              \
>>>> -  R_TYPE c;                                              \
>>>> -  unsigned int i;                                        \
>>>> -    _Atomic_Fetch_sub_##NAME(&t, b, mem_bar);            \
>>>> -    rtems_test_assert(c == (R_TYPE)(a - b));             \
>>>> -  locked_printf("\nCPU%d Atomic_Fetch_sub_" #NAME ": SUCCESS\n", cpuid); \
>>>> -  uint32_t          cpu_num;
>>>> -  char              name[5];
>>>> -  char             *p;
>>>> -  ATOMIC_FETCH_SUB_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_FETCH_SUB_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_FETCH_SUB_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -  ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -//  ATOMIC_FETCH_SUB_NO_BARRIER(64, cpu_num);
>>>> -  while(1);
>>>> diff --git a/testsuites/smptests/smpatomic05/Makefile.am b/testsuites/smptests/smpatomic05/Makefile.am
>>>> index 0d4489d..0000000
>>>> --- a/testsuites/smptests/smpatomic05/Makefile.am
>>>> +++ /dev/null
>>>> @@ -1,20 +0,0 @@
>>>> -rtems_tests_PROGRAMS = smpatomic05
>>>> -smpatomic05_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>>> -dist_rtems_tests_DATA = smpatomic05.scn
>>>> -dist_rtems_tests_DATA += smpatomic05.doc
>>>> -LINK_OBJS = $(smpatomic05_OBJECTS)
>>>> -LINK_LIBS = $(smpatomic05_LDLIBS)
>>>> -smpatomic05$(EXEEXT): $(smpatomic05_OBJECTS) $(smpatomic05_DEPENDENCIES)
>>>> -       @rm -f smpatomic05$(EXEEXT)
>>>> -       $(make-exe)
>>>> diff --git a/testsuites/smptests/smpatomic05/init.c b/testsuites/smptests/smpatomic05/init.c
>>>> index 9a1947e..0000000
>>>> --- a/testsuites/smptests/smpatomic05/init.c
>>>> +++ /dev/null
>>>> @@ -1,72 +0,0 @@
>>>> - *  This test case is to test atomic and operation.
>>>> -#endif
>>>> -rtems_task Init(
>>>> -  int                i;
>>>> -  char               ch;
>>>> -  rtems_id           id;
>>>> -  bool               allDone;
>>>> -  locked_printf( "\n\n***  SMPatomic05 TEST ***\n" );
>>>> -    ch = '0' + i;
>>>> -      1,
>>>> -      &id
>>>> -  while (1) {
>>>> -    allDone = true;
>>>> -        allDone = false;
>>>> -    if (allDone) {
>>>> -      locked_printf( "\n\n*** END OF TEST SMPatomic05 ***\n" );
>>>> diff --git a/testsuites/smptests/smpatomic05/smpatomic05.doc b/testsuites/smptests/smpatomic05/smpatomic05.doc
>>>> index 9ef47b1..0000000
>>>> --- a/testsuites/smptests/smpatomic05/smpatomic05.doc
>>>> +++ /dev/null
>>>> @@ -1,23 +0,0 @@
>>>> -test set name:  smpatomic05
>>>> -directives:
>>>> -  _Atomic_Fetch_and_int
>>>> -  _Atomic_Fetch_and_long
>>>> -  _Atomic_Fetch_and_ptr
>>>> -  _Atomic_Fetch_and_32
>>>> -  _Atomic_Fetch_and_64
>>>> -concepts:
>>>> -+ Ensure that the atomic and operations listed above behave as defined.
>>>> diff --git a/testsuites/smptests/smpatomic05/smpatomic05.scn b/testsuites/smptests/smpatomic05/smpatomic05.scn
>>>> index f297e3c..0000000
>>>> --- a/testsuites/smptests/smpatomic05/smpatomic05.scn
>>>> +++ /dev/null
>>>> @@ -1,29 +0,0 @@
>>>> -***  SMPatomic05 TEST ***
>>>> -CPU2 _Atomic_Fetch_and_int: SUCCESS
>>>> -CPU3 _Atomic_Fetch_and_int: SUCCESS
>>>> -CPU1 _Atomic_Fetch_and_int: SUCCESS
>>>> -CPU2 _Atomic_Fetch_and_long: SUCCESS
>>>> -CPU2 _Atomic_Fetch_and_ptr: SUCCESS
>>>> -CPU3 _Atomic_Fetch_and_long: SUCCESS
>>>> -CPU1 _Atomic_Fetch_and_long: SUCCESS
>>>> -CPU2 _Atomic_Fetch_and_32: SUCCESS
>>>> -CPU3 _Atomic_Fetch_and_ptr: SUCCESS
>>>> -CPU1 _Atomic_Fetch_and_ptr: SUCCESS
>>>> -CPU3 _Atomic_Fetch_and_32: SUCCESS
>>>> -CPU1 _Atomic_Fetch_and_32: SUCCESS
>>>> -*** END OF TEST SMPatomic05 ***
>>>> diff --git a/testsuites/smptests/smpatomic05/system.h b/testsuites/smptests/smpatomic05/system.h
>>>> --- a/testsuites/smptests/smpatomic05/system.h
>>>> +++ /dev/null
>>>> @@ -1,50 +0,0 @@
>>>> -/* functions */
>>>> -rtems_task Init(
>>>> diff --git a/testsuites/smptests/smpatomic05/tasks.c b/testsuites/smptests/smpatomic05/tasks.c
>>>> index cf41cc1..0000000
>>>> --- a/testsuites/smptests/smpatomic05/tasks.c
>>>> +++ /dev/null
>>>> @@ -1,81 +0,0 @@
>>>> -#endif
>>>> -#define ATOMIC_FETCH_AND_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)\
>>>> -  R_TYPE a;                                              \
>>>> -  R_TYPE b;                                              \
>>>> -  R_TYPE c;                                              \
>>>> -  unsigned int i;                                        \
>>>> -    _Atomic_Fetch_and_##NAME(&t, b, mem_bar);            \
>>>> -    rtems_test_assert(c == (R_TYPE)(a & b));             \
>>>> -  locked_printf("\nCPU%d Atomic_Fetch_and_" #NAME ": SUCCESS\n", cpuid); \
>>>> -  uint32_t          cpu_num;
>>>> -  char              name[5];
>>>> -  char             *p;
>>>> -  ATOMIC_FETCH_AND_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_FETCH_AND_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_FETCH_AND_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -  ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -//  ATOMIC_FETCH_AND_NO_BARRIER(64, cpu_num);
>>>> -  while(1);
>>>> diff --git a/testsuites/smptests/smpatomic06/Makefile.am b/testsuites/smptests/smpatomic06/Makefile.am
>>>> index c3a0645..0000000
>>>> --- a/testsuites/smptests/smpatomic06/Makefile.am
>>>> +++ /dev/null
>>>> @@ -1,20 +0,0 @@
>>>> -rtems_tests_PROGRAMS = smpatomic06
>>>> -smpatomic06_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>>> -dist_rtems_tests_DATA = smpatomic06.scn
>>>> -dist_rtems_tests_DATA += smpatomic06.doc
>>>> -LINK_OBJS = $(smpatomic06_OBJECTS)
>>>> -LINK_LIBS = $(smpatomic06_LDLIBS)
>>>> -smpatomic06$(EXEEXT): $(smpatomic06_OBJECTS) $(smpatomic06_DEPENDENCIES)
>>>> -       @rm -f smpatomic06$(EXEEXT)
>>>> -       $(make-exe)
>>>> diff --git a/testsuites/smptests/smpatomic06/init.c b/testsuites/smptests/smpatomic06/init.c
>>>> index 06f1f61..0000000
>>>> --- a/testsuites/smptests/smpatomic06/init.c
>>>> +++ /dev/null
>>>> @@ -1,72 +0,0 @@
>>>> - *  This test case is to test atomic or operation.
>>>> -#endif
>>>> -rtems_task Init(
>>>> -  int                i;
>>>> -  char               ch;
>>>> -  rtems_id           id;
>>>> -  bool               allDone;
>>>> -  locked_printf( "\n\n***  SMPatomic06 TEST ***\n" );
>>>> -    ch = '0' + i;
>>>> -      1,
>>>> -      &id
>>>> -  while (1) {
>>>> -    allDone = true;
>>>> -        allDone = false;
>>>> -    if (allDone) {
>>>> -      locked_printf( "\n\n*** END OF TEST SMPatomic06 ***\n" );
>>>> diff --git a/testsuites/smptests/smpatomic06/smpatomic06.doc b/testsuites/smptests/smpatomic06/smpatomic06.doc
>>>> index 8c9e85f..0000000
>>>> --- a/testsuites/smptests/smpatomic06/smpatomic06.doc
>>>> +++ /dev/null
>>>> @@ -1,23 +0,0 @@
>>>> -test set name:  smpatomic06
>>>> -directives:
>>>> -  _Atomic_Fetch_or_int
>>>> -  _Atomic_Fetch_or_long
>>>> -  _Atomic_Fetch_or_ptr
>>>> -  _Atomic_Fetch_or_32
>>>> -  _Atomic_Fetch_or_64
>>>> -concepts:
>>>> -+ Ensure that the atomic or operations listed above behave as defined.
>>>> diff --git a/testsuites/smptests/smpatomic06/smpatomic06.scn b/testsuites/smptests/smpatomic06/smpatomic06.scn
>>>> index 70a606e..0000000
>>>> --- a/testsuites/smptests/smpatomic06/smpatomic06.scn
>>>> +++ /dev/null
>>>> @@ -1,29 +0,0 @@
>>>> -***  SMPatomic06 TEST ***
>>>> -CPU2 _Atomic_Fetch_or_int: SUCCESS
>>>> -CPU2 _Atomic_Fetch_or_long: SUCCESS
>>>> -CPU3 _Atomic_Fetch_or_int: SUCCESS
>>>> -CPU1 _Atomic_Fetch_or_int: SUCCESS
>>>> -CPU2 _Atomic_Fetch_or_ptr: SUCCESS
>>>> -CPU3 _Atomic_Fetch_or_long: SUCCESS
>>>> -CPU2 _Atomic_Fetch_or_32: SUCCESS
>>>> -CPU1 _Atomic_Fetch_or_long: SUCCESS
>>>> -CPU3 _Atomic_Fetch_or_ptr: SUCCESS
>>>> -CPU1 _Atomic_Fetch_or_ptr: SUCCESS
>>>> -CPU3 _Atomic_Fetch_or_32: SUCCESS
>>>> -CPU1 _Atomic_Fetch_or_32: SUCCESS
>>>> -*** END OF TEST SMPatomic06 ***
>>>> diff --git a/testsuites/smptests/smpatomic06/system.h b/testsuites/smptests/smpatomic06/system.h
>>>> --- a/testsuites/smptests/smpatomic06/system.h
>>>> +++ /dev/null
>>>> @@ -1,50 +0,0 @@
>>>> -/* functions */
>>>> -rtems_task Init(
>>>> diff --git a/testsuites/smptests/smpatomic06/tasks.c b/testsuites/smptests/smpatomic06/tasks.c
>>>> index a0409c7..0000000
>>>> --- a/testsuites/smptests/smpatomic06/tasks.c
>>>> +++ /dev/null
>>>> @@ -1,81 +0,0 @@
>>>> -#endif
>>>> -#define ATOMIC_FETCH_OR_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar) \
>>>> -  R_TYPE a;                                              \
>>>> -  R_TYPE b;                                              \
>>>> -  R_TYPE c;                                              \
>>>> -  unsigned int i;                                        \
>>>> -    _Atomic_Fetch_or_##NAME(&t, b, mem_bar);             \
>>>> -    rtems_test_assert(c == (R_TYPE)(a | b));             \
>>>> -  locked_printf("\nCPU%d Atomic_Fetch_or_" #NAME ": SUCCESS\n", cpuid); \
>>>> -  uint32_t          cpu_num;
>>>> -  char              name[5];
>>>> -  char             *p;
>>>> -  ATOMIC_FETCH_OR_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_FETCH_OR_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_FETCH_OR_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -  ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -//  ATOMIC_FETCH_OR_NO_BARRIER(64, cpu_num);
>>>> -  while(1);
>>>> diff --git a/testsuites/smptests/smpatomic07/Makefile.am b/testsuites/smptests/smpatomic07/Makefile.am
>>>> index 5e623ea..0000000
>>>> --- a/testsuites/smptests/smpatomic07/Makefile.am
>>>> +++ /dev/null
>>>> @@ -1,20 +0,0 @@
>>>> -rtems_tests_PROGRAMS = smpatomic07
>>>> -smpatomic07_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>>> -dist_rtems_tests_DATA = smpatomic07.scn
>>>> -dist_rtems_tests_DATA += smpatomic07.doc
>>>> -LINK_OBJS = $(smpatomic07_OBJECTS)
>>>> -LINK_LIBS = $(smpatomic07_LDLIBS)
>>>> -smpatomic07$(EXEEXT): $(smpatomic07_OBJECTS) $(smpatomic07_DEPENDENCIES)
>>>> -       @rm -f smpatomic07$(EXEEXT)
>>>> -       $(make-exe)
>>>> diff --git a/testsuites/smptests/smpatomic07/init.c b/testsuites/smptests/smpatomic07/init.c
>>>> index be9c216..0000000
>>>> --- a/testsuites/smptests/smpatomic07/init.c
>>>> +++ /dev/null
>>>> @@ -1,72 +0,0 @@
>>>> - *  This test case is to test atomic compare and exchange operation.
>>>> -#endif
>>>> -rtems_task Init(
>>>> -  int                i;
>>>> -  char               ch;
>>>> -  rtems_id           id;
>>>> -  bool               allDone;
>>>> -  locked_printf( "\n\n***  SMPatomic07 TEST ***\n" );
>>>> -    ch = '0' + i;
>>>> -      1,
>>>> -      &id
>>>> -  while (1) {
>>>> -    allDone = true;
>>>> -        allDone = false;
>>>> -    if (allDone) {
>>>> -      locked_printf( "\n\n*** END OF TEST SMPatomic07 ***\n" );
>>>> diff --git a/testsuites/smptests/smpatomic07/smpatomic07.doc b/testsuites/smptests/smpatomic07/smpatomic07.doc
>>>> index a931ad5..0000000
>>>> --- a/testsuites/smptests/smpatomic07/smpatomic07.doc
>>>> +++ /dev/null
>>>> @@ -1,24 +0,0 @@
>>>> -test set name:  smpatomic07
>>>> -directives:
>>>> -  _Atomic_Compare_exchange_int
>>>> -  _Atomic_Compare_exchange_long
>>>> -  _Atomic_Compare_exchange_ptr
>>>> -  _Atomic_Compare_exchange_32
>>>> -  _Atomic_Compare_exchange_64
>>>> -concepts:
>>>> -+ Ensure that the atomic compare and exchange operations listed above behave
>>>> -  as defined.
>>>> diff --git a/testsuites/smptests/smpatomic07/smpatomic07.scn b/testsuites/smptests/smpatomic07/smpatomic07.scn
>>>> index 800c4c5..0000000
>>>> --- a/testsuites/smptests/smpatomic07/smpatomic07.scn
>>>> +++ /dev/null
>>>> @@ -1,29 +0,0 @@
>>>> -***  SMPatomic07 TEST ***
>>>> -CPU1 _Atomic_Compare_exchange_int: SUCCESS
>>>> -CPU3 _Atomic_Compare_exchange_int: SUCCESS
>>>> -CPU2 _Atomic_Compare_exchange_int: SUCCESS
>>>> -CPU2 _Atomic_Compare_exchange_long: SUCCESS
>>>> -CPU2 _Atomic_Compare_exchange_ptr: SUCCESS
>>>> -CPU2 _Atomic_Compare_exchange_32: SUCCESS
>>>> -CPU3 _Atomic_Compare_exchange_long: SUCCESS
>>>> -CPU1 _Atomic_Compare_exchange_long: SUCCESS
>>>> -CPU1 _Atomic_Compare_exchange_ptr: SUCCESS
>>>> -CPU3 _Atomic_Compare_exchange_ptr: SUCCESS
>>>> -CPU1 _Atomic_Compare_exchange_32: SUCCESS
>>>> -CPU3 _Atomic_Compare_exchange_32: SUCCESS
>>>> -*** END OF TEST SMPatomic07 ***
>>>> diff --git a/testsuites/smptests/smpatomic07/system.h b/testsuites/smptests/smpatomic07/system.h
>>>> --- a/testsuites/smptests/smpatomic07/system.h
>>>> +++ /dev/null
>>>> @@ -1,50 +0,0 @@
>>>> -/* functions */
>>>> -rtems_task Init(
>>>> diff --git a/testsuites/smptests/smpatomic07/tasks.c b/testsuites/smptests/smpatomic07/tasks.c
>>>> index 345439b..0000000
>>>> --- a/testsuites/smptests/smpatomic07/tasks.c
>>>> +++ /dev/null
>>>> @@ -1,97 +0,0 @@
>>>> -#endif
>>>> -#define ATOMIC_CAS_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)     \
>>>> -  R_TYPE a;                                             \
>>>> -  R_TYPE b;                                             \
>>>> -  unsigned int i;                                       \
>>>> -  int r;                                                \
>>>> -    a = rand() % (R_TYPE)-1;                            \
>>>> -    b = a + 1;                                                           \
>>>> -    r = _Atomic_Compare_exchange_##NAME(&t, &b, a - 1, mem_bar, memory_order_relaxed);\
>>>> -    if(r != 0){                                                          \
>>>> -      locked_printf("\ntask%d: Atomic_Compare_exchange_" #NAME ": FAILED\n", (unsigned int)cpuid); \
>>>> -      rtems_test_exit( 0 );                                              \
>>>> -    r = _Atomic_Compare_exchange_##NAME(&t, &a, a - 1, mem_bar, memory_order_relaxed);\
>>>> -    b = _Atomic_Load_##NAME(&t, ATOMIC_ORDER_ACQUIRE);                   \
>>>> -    if((r == 0) ||((r != 0) && ((a - 1) != b))){                         \
>>>> -    b = a + 1;                                                           \
>>>> -    r = _Atomic_Compare_exchange_##NAME(&t, &b, a, mem_bar, memory_order_relaxed); \
>>>> -    if(r != 0){                                                          \
>>>> -  locked_printf("\nCPU%d Atomic_Compare_exchange_" #NAME ": SUCCESS\n", cpuid);    \
>>>> -  uint32_t          cpu_num;
>>>> -  char              name[5];
>>>> -  char             *p;
>>>> -  ATOMIC_CAS_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>>> -  ATOMIC_CAS_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>>> -  ATOMIC_CAS_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -  ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>>> -//  ATOMIC_CAS_NO_BARRIER(64, cpu_num);
>>>> -  while(1);
>>>> _______________________________________________
>>>> rtems-vc mailing list
>>>> rtems-vc at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-vc
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
