[PATCH] Modify raspberrypi mm_config_table to map GPIO and registers.
Hesham Moustafa
heshamelmatary at gmail.com
Mon Oct 14 15:54:53 UTC 2013
On Mon, Oct 14, 2013 at 4:02 PM, Sebastian Huber <
> On 2013-10-14 15:34, Hesham AL-Matary wrote:
>> diff --git a/c/src/lib/libbsp/arm/**raspberrypi/startup/mm_config_**table.c
>> b/c/src/lib/libbsp/arm/**raspberrypi/startup/mm_config_**table.c
>> index 5436a76..2b748b2 100644
>> --- a/c/src/lib/libbsp/arm/**raspberrypi/startup/mm_config_**table.c
>> +++ b/c/src/lib/libbsp/arm/**raspberrypi/startup/mm_config_**table.c
>> @@ -42,7 +42,7 @@ bsp_mm_config_table[] = {
>> .begin = (uint32_t) bsp_section_text_begin,
>> .end = (uint32_t) bsp_section_text_end,
>> - .flags = ARMV7_MMU_CODE_CACHED
>> + .flags = ARMV7_MMU_READ_WRITE
> What is the problem with the cache? Did the cache previously work?
There is a problem with applying a Read-Only permissions in general to this
area for RaspberryPi BSP.
>> .begin = (uint32_t) bsp_section_rodata_begin,
>> .end = (uint32_t) bsp_section_rodata_end,
>> @@ -63,8 +63,12 @@ bsp_mm_config_table[] = {
>> .begin = (uint32_t) bsp_section_stack_begin,
>> .end = (uint32_t) bsp_section_stack_end,
>> .flags = MMU_DATA_READ_WRITE
>> + .begin = 0x20000000,
>> + .end = 0x20FFFFFF,
>> + .flags = ARMV7_MMU_DATA_READ_WRITE
> What is this for an area?
It's for Raspberry GPIO pins and other registers (defined at
raspbberrypi.h).
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20131014/a0674ca4/attachment.html>
