[PATCH] Modify raspberrypi mm_config_table to map GPIO and registers.
Mon Oct 14 16:04:46 UTC 2013
On Mon, Oct 14, 2013 at 11:54 AM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> On Mon, Oct 14, 2013 at 4:02 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 2013-10-14 15:34, Hesham AL-Matary wrote:
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> index 5436a76..2b748b2 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> @@ -42,7 +42,7 @@ bsp_mm_config_table[] = {
>>>       .begin = (uint32_t) bsp_section_text_begin,
>>>       .end = (uint32_t) bsp_section_text_end,
>>> -    .flags = ARMV7_MMU_CODE_CACHED
>>> +    .flags = ARMV7_MMU_READ_WRITE
>> What is the problem with the cache?  Did the cache previously work?
> There is a problem with applying a Read-Only permissions in general to this
> area for RaspberryPi BSP.
>>>       .begin = (uint32_t) bsp_section_rodata_begin,
>>>       .end = (uint32_t) bsp_section_rodata_end,
>>> @@ -63,8 +63,12 @@ bsp_mm_config_table[] = {
>>>       .begin = (uint32_t) bsp_section_stack_begin,
>>>       .end = (uint32_t) bsp_section_stack_end,
>>>       .flags = MMU_DATA_READ_WRITE
>>> +    .begin = 0x20000000,
>>> +    .end = 0x20FFFFFF,
>>> +    .flags = ARMV7_MMU_DATA_READ_WRITE
>> What is this for an area?
> It's for Raspberry GPIO pins and other registers (defined at
> raspbberrypi.h).
Please provide names for the begin and end of the region as the others do.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
