Original cpuset.h for review
Tue Oct 15 01:40:40 UTC 2013
Pretty reasonable at first skimming. You could use the _NCPUWORDS
macro in the definition of __bits[] array in cpu_set_t. Not sure where
the NBBY value comes from, is there an implicit dependency header file
missing?
-Gedare
On Mon, Oct 14, 2013 at 2:47 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> This has had limited review but should close if you ignore
> that I need to add some comments.
> This will go into the RTEMS specific subdirectory of
> newlib and be accompanied by prototypes of various
> pthread methods that use this. This is just the
> first step.
> Comments.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> rtems-devel mailing list
> rtems-devel at rtems.org
