[PATCH 1/2] fsdosfsformat01: Add test for re-mount of a filesystem
Ralf Kirchner ralf.kirchner at embedded-brains.de
Fri Oct 18 07:37:25 UTC 2013
 testsuites/fstests/fsdosfsformat01/init.c |   11 +++++++++++
 1 Datei geändert, 11 Zeilen hinzugefügt(+)
diff --git a/testsuites/fstests/fsdosfsformat01/init.c b/testsuites/fstests/fsdosfsformat01/init.c
index 6299c9b..3026dbb 100644
--- a/testsuites/fstests/fsdosfsformat01/init.c
+++ b/testsuites/fstests/fsdosfsformat01/init.c
@@ -83,6 +83,17 @@ static void test_disk_params(
   rv = unmount( mount_dir );
   rtems_test_assert( 0 == rv );
+  /* See if we can re-mount the file system */
+  rv = mount( dev_name,
+              mount_dir,
+              RTEMS_FILESYSTEM_TYPE_DOSFS,
+              RTEMS_FILESYSTEM_READ_WRITE,
+              NULL );
+  rtems_test_assert( 0 == rv );
+  rv = unmount( mount_dir );
 static void test_create_file(
1.7.10.4
