C++ static constructors and SMP
Joel Sherrill Joel.Sherrill at OARcorp.com
Wed Oct 23 11:31:53 UTC 2013
Is this a case of two threads running the init table or an application thread running and using a global object before running the init table is complete?
Constructor order is another problem but I didn't think that had anything to do with this case.
--Joel
Stephen Tether <tether at slac.stanford.edu> wrote:
On 10/22/13 5:36 PM, Ralf Corsepius wrote:
> Are sure not to be hit by
> http://www.parashift.com/c++-faq/static-init-order.html ?
An infamous C++ gotcha! No, it's clearly a case of the wrong ordering of
constructor vs. member function calls for the *same* object instance. We
recorded the value of the global timer, the object address and sundry
other info for both constructor and member function calls.
Thanks, guys, for your responses.
- Steve
rtems-devel mailing list
rtems-devel at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-devel
