cpuset macro /vs/ inline implementation
Fri Oct 25 07:14:42 UTC 2013
On 2013-10-24 22:26, Jennifer Averett wrote:
>   * Copyright (c) 2013 On-Line Applications Research Corporation.
>   * All rights reserved.
>   *  On-Line Applications Research Corporation
>   *  7047 Old Madison Pike Suite 320
>   *  Huntsville Alabama 35806
>   *<info at oarcorp.com>
>   * Redistribution and use in source and binary forms, with or without
>   * modification, are permitted provided that the following conditions
>   * are met:
>   * 1. Redistributions of source code must retain the above copyright
>   *    notice, this list of conditions and the following disclaimer.
>   * 2. Redistributions in binary form must reproduce the above copyright
>   *    notice, this list of conditions and the following disclaimer in the
>   *    documentation and/or other materials provided with the distribution.
>   * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
>   * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>   * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
>   * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
>   * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
>   * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>   * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>   * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
>   * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>   * SUCH DAMAGE.
>   *  This file implements an API compatible with static portion of
>   *  the GNU/Linux cpu_set_t macros but is independently implemented.
>   *  The GNU/Linux manual page and the FreeBSD cpuset_t implementation
>   *  were used as reference material.
>   *  Not implemented:
>   *    + Linux CPU_XXX_S
>   *    + FreeBSD CPU_SUBSET
>   *    + FreeBSD CPU_OVERLAP
> #ifndef_SYS_CPUSET_H_
> #define_SYS_CPUSET_H_
> #include <sys/types.h>
> /* RTEMS supports a maximum of 32 CPU cores */
> #define CPU_SETSIZE 32
Why not use
#ifndef CPU_SETSIZE
#endif
like in FreeBSD?
> /* Number of bits per cpu_set_t element */
> #define _NCPUBITS  (sizeof(long) * NBBY) /* bits per mask */
NBBY is defined in <sys/param.h>.
> /* Number of words in the cpu_set_t array */
> #define _NCPUWORDS howmany(CPU_SETSIZE, _NCPUBITS)
howmany() is defined in <sys/param.h>.
> /* Define the cpu set structure */
> typedef struct _cpuset {
>    long  __bits[_NCPUWORDS];
> } cpu_set_t;
We need statically initialized CPU sets for RTEMS (e.g. for the configuration).
  So we should use this
typedef uint32_t cpu_set_word_t;
typedef struct {
   cpu_set_word_t bits[_NCPUWORDS];
} cpu_set_t;
> /* determine the mask for a particular cpu within the element */
> #define __cpuset_mask(_cpu) ((long)1 << ((_cpu) % _NCPUBITS))
> /* determine the index for this cpu within the cpu set array */
> #define __cpuset_index(_cpu) ((_cpu)/_NCPUBITS)
Why not use an inline function?
> /* zero out set */
> static inline void CPU_ZERO(cpu_set_t *set)
>    size_t i;
>    for (i = 0; i < _NCPUWORDS; i++)
>      set->__bits[i] = 0;
> /* fill set */
> static inline void CPU_FILL(cpu_set_t *set)
>    size_t i;
>      set->__bits[i] = -1;
Why not use a const qualifier if possible?
> /* set cpu within set */
> static inline void CPU_SET(size_t cpu, cpu_set_t *set)
>    set->__bits[__cpuset_index(cpu)] |= __cpuset_mask(cpu);
> /* clear cpu within set */
> static inline void CPU_CLR(size_t cpu, cpu_set_t *set)
>    set->__bits[__cpuset_index(cpu)] &= ~__cpuset_mask(cpu);
> /* Return 1 is cpu is set in set, 0 otherwise */
> static inline int CPU_ISSET(size_t cpu, cpu_set_t *set)
>    return ((set->__bits[__cpuset_index(cpu)] & __cpuset_mask(cpu)) != 0);
> /* copy src set to dest set */
> static inline void CPU_COPY(cpu_set_t *dest, cpu_set_t *src)
>    *dest = *src;
> /* logical and: dest set = src1 set and src2 set */
> static inline void CPU_AND(cpu_set_t *dest,cpu_set_t *src1, cpu_set_t *src2)
>    size_t i;
>      dest->__bits[i] = src1->__bits[i] & src2->__bits[i];
> /* logical or: dest set = src1 set or src2 set */
> static inline void CPU_OR(cpu_set_t *dest,cpu_set_t *src1, cpu_set_t *src2)
>    size_t i;
>       dest->__bits[i] = src1->__bits[i] | src2->__bits[i];
> /* logical xor: dest set = src1 set xor src2 set */
> static inline void CPU_XOR(cpu_set_t *dest,cpu_set_t *src1, cpu_set_t *src2)
>    size_t i;
>     dest->__bits[i] = src1->__bits[i] ^ src2->__bits[i];
> /* logical nand: dest set = src1 set nand src2 set */
> static inline void CPU_NAND(cpu_set_t *dest,cpu_set_t *src1, cpu_set_t *src2)
>    size_t i;
>      dest->__bits[i] = ~(src1->__bits[i] & src2->__bits[i]);
> /* return the number of set cpus in set */
> static inline int CPU_COUNT(cpu_set_t *set)
>    size_t i;
>    int    count = 0;
>    for (i=0; i < _NCPUWORDS; i++)
>      if (CPU_ISSET(i, set) != 0)
>        count++;
>    return count;
> /* return 1 if the sets set1 and set2 are equal, otherwise return 0 */
> static inline int CPU_EQUAL(cpu_set_t *set1, cpu_set_t *set2)
>    size_t i;
>      if (set1->__bits[i] != set2->__bits[i] )
>        return 0;
>    return 1;
Why not use bool as return type?
> static inline int CPU_CMP(cpu_set_t *set1, cpu_set_t *set2)
>    return CPU_EQUAL(set1, set2);
> /* return 1 if the set is empty, otherwise return 0 */
> static inline int CPU_EMPTY(cpu_set_t *set)
>    size_t i;
>      if (set->__bits[i] != 0 )
>        return 0;
>    return 1;
> #endif
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
