[PATCH 4/5] SMP01: possible CPU race when using byte arrays
Thu Oct 31 14:17:50 UTC 2013
I don't understand the problem being solved here / the reason for this
change from bool to int.
On Thu, Oct 31, 2013 at 9:58 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> Switch to using 32-bit variable that works better on a
> 32-bit CPU. This does not solve the general SMP case
> though, would perhaps better to use an atomic set
> here.
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  testsuites/smptests/smp01/init.c   |    6 +++---
>  testsuites/smptests/smp01/system.h |    2 +-
>  testsuites/smptests/smp01/tasks.c  |    2 +-
>  3 files changed, 5 insertions(+), 5 deletions(-)
> diff --git a/testsuites/smptests/smp01/init.c b/testsuites/smptests/smp01/init.c
> index 3e12726..eadb26a 100644
> --- a/testsuites/smptests/smp01/init.c
> +++ b/testsuites/smptests/smp01/init.c
> @@ -43,11 +43,11 @@ rtems_task Init(
>    locked_print_initialize();
>    /* Put start of test message */
> -  locked_printf( "\n\n***  SMP01 TEST ***\n" );
> +  locked_printf( "\n\n***  SMP01 TEST %d ***\n", cpu_self );
>    /* Initialize the TaskRan array */
>    for ( i=0; i<rtems_smp_get_processor_count() ; i++ ) {
> -    TaskRan[i] = false;
> +    TaskRan[i] = 0;
>    /* Create and start tasks for each processor */
> @@ -77,7 +77,7 @@ rtems_task Init(
>    while (1) {
>      allDone = true;
> -      if ( i != cpu_self && TaskRan[i] == false)
> +      if ( i != cpu_self && TaskRan[i] == 0)
>          allDone = false;
>      if (allDone) {
> diff --git a/testsuites/smptests/smp01/system.h b/testsuites/smptests/smp01/system.h
> index e360e37..5f2d5b7 100644
> --- a/testsuites/smptests/smp01/system.h
> +++ b/testsuites/smptests/smp01/system.h
> @@ -42,7 +42,7 @@ rtems_task Test_task(
>   *  Keep the names and IDs in global variables so another task can use them.
> -TEST_EXTERN volatile bool TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS ];
> +TEST_EXTERN volatile int TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS ];
>  void Loop( void );
> diff --git a/testsuites/smptests/smp01/tasks.c b/testsuites/smptests/smp01/tasks.c
> index 4eb81f1..7bd7cc4 100644
> --- a/testsuites/smptests/smp01/tasks.c
> +++ b/testsuites/smptests/smp01/tasks.c
> @@ -35,7 +35,7 @@ rtems_task Test_task(
>    locked_printf(" CPU %" PRIu32 " running Task %s\n", cpu_num, name);
>    /* Set the flag that the task is up and running */
> -  TaskRan[cpu_num] = true;
> +  TaskRan[cpu_num] = 1;
>    /* Drop into a loop which will keep this task on
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
