[PATCH 5/5] SPARC BSPs: disable interrupts as early as possible
Thu Oct 31 14:23:28 UTC 2013
OK
On Thu, Oct 31, 2013 at 9:58 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> There is no point having interrupts enabled before reaching
> boot_card() that disables interrupt. We better have it off
> all the time.
> It is required to turn off interrupt on secondary CPUs in an
> SMP system.
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/lib/libbsp/sparc/shared/start.S |    4 ++--
>  1 files changed, 2 insertions(+), 2 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/shared/start.S b/c/src/lib/libbsp/sparc/shared/start.S
> index 83cfab4..721336d 100644
> --- a/c/src/lib/libbsp/sparc/shared/start.S
> +++ b/c/src/lib/libbsp/sparc/shared/start.S
> @@ -226,8 +226,8 @@ SYM(hard_reset):
>         sll     %g3, %g2, %g3
>          mov     %g3, %wim
> -       or      %g1, 0x20, %g1
> -        wr      %g1, %psr              ! enable traps
> +       or      %g1, 0xf20, %g1
> +        wr      %g1, %psr              ! enable traps and disable ints
>          nop
>          nop
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
