[PATCH 4/5] SMP01: possible CPU race when using byte arrays
Thu Oct 31 14:42:32 UTC 2013
On 2013-10-31 15:37, Gedare Bloom wrote:
> On Thu, Oct 31, 2013 at 10:24 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> >On 2013-10-31 15:18, Daniel Hellstrom wrote:
>>> >>Bool is char, a 4 CPU 8-bit variable array will crate a race, where CPU1
>>> >>might
>>> >>over write CPU2 and CPU3 task execution status. There is no atomic locking
>>> >>of
>>> >>the TaskRan array.
>> >In case they write to different memory locations, there is no data race
>> >under the C11 memory model.
For reference "5.1.2.4 Multi-threaded executions and data races" paragraph 2.
> Yes this is what I thought too. I assume the LEON uses an 8-bit store
> (stb) for the variables. Maybe the problem comes from the cache? If
> the cache line size is 32 bits then conflicting 8-bit stores to the
> same cache line could cause a problem.
In this case the cache coherency protocol is broken.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
