[PATCH 1/2] Filesystem: Add poll() handler
Thu Oct 31 14:49:50 UTC 2013
This handler is necessary to implement the SELECT(2) and POLL(2) system
calls.
Add <sys/poll.h> from FreeBSD 8.3.
 cpukit/Makefile.am                       |    1 +
 cpukit/libcsupport/include/rtems/libio.h |   28 ++++++++
 cpukit/libcsupport/include/sys/poll.h    |  104 ++++++++++++++++++++++++++++++
 cpukit/libfs/Makefile.am                 |    1 +
 cpukit/libfs/src/defaults/default_poll.c |   37 +++++++++++
 cpukit/preinstall.am                     |    4 +
 6 files changed, 175 insertions(+), 0 deletions(-)
 create mode 100644 cpukit/libcsupport/include/sys/poll.h
 create mode 100644 cpukit/libfs/src/defaults/default_poll.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index f22de41..443ed35 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -52,6 +52,7 @@ include_HEADERS += libmd/md5.h
 include_sys_HEADERS += libcsupport/include/sys/ioccom.h
 include_sys_HEADERS += libcsupport/include/sys/filio.h
 include_sys_HEADERS += libcsupport/include/sys/ioctl.h
+include_sys_HEADERS += libcsupport/include/sys/poll.h
 include_sys_HEADERS += libcsupport/include/sys/statvfs.h
 include_sys_HEADERS += libcsupport/include/sys/sockio.h
 include_sys_HEADERS += libcsupport/include/sys/ttycom.h
diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
index aa64ff3..a642062 100644
--- a/cpukit/libcsupport/include/rtems/libio.h
+++ b/cpukit/libcsupport/include/rtems/libio.h
@@ -943,6 +943,21 @@ typedef int (*rtems_filesystem_fcntl_t)(
+ * @brief Poll and select support.
+ * @param[in, out] iop The IO pointer.
+ * @param[in] events The poll events.
+ * @return The poll return events.
+ * @see rtems_filesystem_default_poll().
+typedef int (*rtems_filesystem_poll_t)(
+  rtems_libio_t *iop,
+  int events
  * @brief File system node operations table.
 struct _rtems_filesystem_file_handlers_r {
@@ -957,6 +972,7 @@ struct _rtems_filesystem_file_handlers_r {
   rtems_filesystem_fsync_t fsync_h;
   rtems_filesystem_fdatasync_t fdatasync_h;
   rtems_filesystem_fcntl_t fcntl_h;
+  rtems_filesystem_poll_t poll_h;
@@ -1130,6 +1146,18 @@ int rtems_filesystem_default_fcntl(
   int cmd
+ * @brief Default poll handler.
+ * @retval POLLERR Always.
+ * @see rtems_filesystem_poll_t.
+int rtems_filesystem_default_poll(
+  int events
diff --git a/cpukit/libcsupport/include/sys/poll.h b/cpukit/libcsupport/include/sys/poll.h
new file mode 100644
index 0000000..c955f32
--- /dev/null
+++ b/cpukit/libcsupport/include/sys/poll.h
@@ -0,0 +1,104 @@
+ * Copyright (c) 1997 Peter Wemm <peter at freebsd.org>
+ * All rights reserved.
+ * are met:
+ * 3. The name of the author may not be used to endorse or promote products
+ *    derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _SYS_POLL_H_
+#define	_SYS_POLL_H_
+#include <sys/cdefs.h>
+ * This file is intended to be compatible with the traditional poll.h.
+typedef	unsigned int	nfds_t;
+ * This structure is passed as an array to poll(2).
+struct pollfd {
+	int	fd;		/* which file descriptor to poll */
+	short	events;		/* events we are interested in */
+	short	revents;	/* events found on return */
+ * Requestable events.  If poll(2) finds any of these set, they are
+ * copied to revents on return.
+ * XXX Note that FreeBSD doesn't make much distinction between POLLPRI
+ * and POLLRDBAND since none of the file types have distinct priority
+ * bands - and only some have an urgent "mode".
+ * XXX Note POLLIN isn't really supported in true SVSV terms.  Under SYSV
+ * POLLIN includes all of normal, band and urgent data.  Most poll handlers
+ * on FreeBSD only treat it as "normal" data.
+#define	POLLIN		0x0001		/* any readable data available */
+#define	POLLPRI		0x0002		/* OOB/Urgent readable data */
+#define	POLLOUT		0x0004		/* file descriptor is writeable */
+#define	POLLRDNORM	0x0040		/* non-OOB/URG data available */
+#define	POLLWRNORM	POLLOUT		/* no write type differentiation */
+#define	POLLRDBAND	0x0080		/* OOB/Urgent readable data */
+#define	POLLWRBAND	0x0100		/* OOB/Urgent data can be written */
+#if __BSD_VISIBLE
+/* General FreeBSD extension (currently only supported for sockets): */
+#define	POLLINIGNEOF	0x2000		/* like POLLIN, except ignore EOF */
+#endif
+ * These events are set if they occur regardless of whether they were
+ * requested.
+#define	POLLERR		0x0008		/* some poll error occurred */
+#define	POLLHUP		0x0010		/* file descriptor was "hung up" */
+#define	POLLNVAL	0x0020		/* requested events "invalid" */
+#if __BSD_VISIBLE
+#define	POLLSTANDARD	(POLLIN|POLLPRI|POLLOUT|POLLRDNORM|POLLRDBAND|\
+			 POLLWRBAND|POLLERR|POLLHUP|POLLNVAL)
+ * Request that poll() wait forever.
+ * XXX in SYSV, this is defined in stropts.h, which is not included
+ * by poll.h.
+#define	INFTIM		(-1)
+#endif
+#ifndef _KERNEL
+__BEGIN_DECLS
+int	poll(struct pollfd _pfd[], nfds_t _nfds, int _timeout);
+__END_DECLS
+#endif /* !_KERNEL */
+#endif /* !_SYS_POLL_H_ */
diff --git a/cpukit/libfs/Makefile.am b/cpukit/libfs/Makefile.am
index c9f14b5..b8496d5 100644
--- a/cpukit/libfs/Makefile.am
+++ b/cpukit/libfs/Makefile.am
@@ -33,6 +33,7 @@ libdefaultfs_a_SOURCES = \
     src/defaults/default_node_type.c \
     src/defaults/default_ftruncate_directory.c \
     src/defaults/default_handlers.c src/defaults/default_ops.c
+libdefaultfs_a_SOURCES += src/defaults/default_poll.c
 noinst_LIBRARIES += libimfs.a
 libimfs_a_SOURCES =
diff --git a/cpukit/libfs/src/defaults/default_poll.c b/cpukit/libfs/src/defaults/default_poll.c
index 0000000..7540390
--- /dev/null
+++ b/cpukit/libfs/src/defaults/default_poll.c
@@ -0,0 +1,37 @@
+ * @file
+ * @brief Default Poll Handler
+ * @ingroup LibIOFSHandler
+ * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/libio_.h>
+#include <sys/poll.h>
+  int events
+  return POLLERR;
diff --git a/cpukit/preinstall.am b/cpukit/preinstall.am
index 315ab3e..bdcc359 100644
--- a/cpukit/preinstall.am
+++ b/cpukit/preinstall.am
@@ -76,6 +76,10 @@ $(PROJECT_INCLUDE)/sys/ioctl.h: libcsupport/include/sys/ioctl.h $(PROJECT_INCLUD
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/ioctl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/ioctl.h
+$(PROJECT_INCLUDE)/sys/poll.h: libcsupport/include/sys/poll.h $(PROJECT_INCLUDE)/sys/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/poll.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/poll.h
 $(PROJECT_INCLUDE)/sys/statvfs.h: libcsupport/include/sys/statvfs.h $(PROJECT_INCLUDE)/sys/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/statvfs.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/statvfs.h
1.7.7
