[PATCH 1/2] Filesystem: Add poll() handler
Thu Oct 31 14:56:10 UTC 2013
On Thu, Oct 31, 2013 at 10:49 AM, Sebastian Huber
> This handler is necessary to implement the SELECT(2) and POLL(2) system
> calls.
> Add <sys/poll.h> from FreeBSD 8.3.
>  cpukit/Makefile.am                       |    1 +
>  cpukit/libcsupport/include/rtems/libio.h |   28 ++++++++
>  cpukit/libcsupport/include/sys/poll.h    |  104 ++++++++++++++++++++++++++++++
>  cpukit/libfs/Makefile.am                 |    1 +
>  cpukit/libfs/src/defaults/default_poll.c |   37 +++++++++++
>  cpukit/preinstall.am                     |    4 +
>  6 files changed, 175 insertions(+), 0 deletions(-)
>  create mode 100644 cpukit/libcsupport/include/sys/poll.h
>  create mode 100644 cpukit/libfs/src/defaults/default_poll.c
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index f22de41..443ed35 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -52,6 +52,7 @@ include_HEADERS += libmd/md5.h
>  include_sys_HEADERS += libcsupport/include/sys/ioccom.h
>  include_sys_HEADERS += libcsupport/include/sys/filio.h
>  include_sys_HEADERS += libcsupport/include/sys/ioctl.h
> +include_sys_HEADERS += libcsupport/include/sys/poll.h
>  include_sys_HEADERS += libcsupport/include/sys/statvfs.h
>  include_sys_HEADERS += libcsupport/include/sys/sockio.h
>  include_sys_HEADERS += libcsupport/include/sys/ttycom.h
> diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
> index aa64ff3..a642062 100644
> --- a/cpukit/libcsupport/include/rtems/libio.h
> +++ b/cpukit/libcsupport/include/rtems/libio.h
> @@ -943,6 +943,21 @@ typedef int (*rtems_filesystem_fcntl_t)(
> + * @brief Poll and select support.
> + * @param[in, out] iop The IO pointer.
> + * @param[in] events The poll events.
> + * @return The poll return events.
> + * @see rtems_filesystem_default_poll().
> +typedef int (*rtems_filesystem_poll_t)(
> +  rtems_libio_t *iop,
> +  int events
>   * @brief File system node operations table.
>  struct _rtems_filesystem_file_handlers_r {
> @@ -957,6 +972,7 @@ struct _rtems_filesystem_file_handlers_r {
>    rtems_filesystem_fsync_t fsync_h;
>    rtems_filesystem_fdatasync_t fdatasync_h;
>    rtems_filesystem_fcntl_t fcntl_h;
> +  rtems_filesystem_poll_t poll_h;
> @@ -1130,6 +1146,18 @@ int rtems_filesystem_default_fcntl(
>    int cmd
> + * @brief Default poll handler.
> + * @retval POLLERR Always.
> + * @see rtems_filesystem_poll_t.
> +int rtems_filesystem_default_poll(
> +  int events
> diff --git a/cpukit/libcsupport/include/sys/poll.h b/cpukit/libcsupport/include/sys/poll.h
> new file mode 100644
> index 0000000..c955f32
> --- /dev/null
> +++ b/cpukit/libcsupport/include/sys/poll.h
> @@ -0,0 +1,104 @@
> + * Copyright (c) 1997 Peter Wemm <peter at freebsd.org>
> + * All rights reserved.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * 3. The name of the author may not be used to endorse or promote products
> + *    derived from this software without specific prior written permission.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> + * $FreeBSD$
Should we include the checkout version information for future
reference? I don't know if we have taken any approach to this yet for
other freebsd included files.
I assume this file is verbatim from the freebsd source?
> +#ifndef _SYS_POLL_H_
> +#define        _SYS_POLL_H_
> +#include <sys/cdefs.h>
> + * This file is intended to be compatible with the traditional poll.h.
> +typedef        unsigned int    nfds_t;
> + * This structure is passed as an array to poll(2).
> +struct pollfd {
> +       int     fd;             /* which file descriptor to poll */
> +       short   events;         /* events we are interested in */
> +       short   revents;        /* events found on return */
> + * Requestable events.  If poll(2) finds any of these set, they are
> + * copied to revents on return.
> + * XXX Note that FreeBSD doesn't make much distinction between POLLPRI
> + * and POLLRDBAND since none of the file types have distinct priority
> + * bands - and only some have an urgent "mode".
> + * XXX Note POLLIN isn't really supported in true SVSV terms.  Under SYSV
> + * POLLIN includes all of normal, band and urgent data.  Most poll handlers
> + * on FreeBSD only treat it as "normal" data.
> +#define        POLLIN          0x0001          /* any readable data available */
> +#define        POLLPRI         0x0002          /* OOB/Urgent readable data */
> +#define        POLLOUT         0x0004          /* file descriptor is writeable */
> +#define        POLLRDNORM      0x0040          /* non-OOB/URG data available */
> +#define        POLLWRNORM      POLLOUT         /* no write type differentiation */
> +#define        POLLRDBAND      0x0080          /* OOB/Urgent readable data */
> +#define        POLLWRBAND      0x0100          /* OOB/Urgent data can be written */
> +#if __BSD_VISIBLE
> +/* General FreeBSD extension (currently only supported for sockets): */
> +#define        POLLINIGNEOF    0x2000          /* like POLLIN, except ignore EOF */
> +#endif
> + * These events are set if they occur regardless of whether they were
> + * requested.
> +#define        POLLERR         0x0008          /* some poll error occurred */
> +#define        POLLHUP         0x0010          /* file descriptor was "hung up" */
> +#define        POLLNVAL        0x0020          /* requested events "invalid" */
> +#if __BSD_VISIBLE
> +#define        POLLSTANDARD    (POLLIN|POLLPRI|POLLOUT|POLLRDNORM|POLLRDBAND|\
> +                        POLLWRBAND|POLLERR|POLLHUP|POLLNVAL)
> + * Request that poll() wait forever.
> + * XXX in SYSV, this is defined in stropts.h, which is not included
> + * by poll.h.
> +#define        INFTIM          (-1)
> +#endif
> +#ifndef _KERNEL
> +__BEGIN_DECLS
> +int    poll(struct pollfd _pfd[], nfds_t _nfds, int _timeout);
> +__END_DECLS
> +#endif /* !_KERNEL */
> +#endif /* !_SYS_POLL_H_ */
> diff --git a/cpukit/libfs/Makefile.am b/cpukit/libfs/Makefile.am
> index c9f14b5..b8496d5 100644
> --- a/cpukit/libfs/Makefile.am
> +++ b/cpukit/libfs/Makefile.am
> @@ -33,6 +33,7 @@ libdefaultfs_a_SOURCES = \
>      src/defaults/default_node_type.c \
>      src/defaults/default_ftruncate_directory.c \
>      src/defaults/default_handlers.c src/defaults/default_ops.c
> +libdefaultfs_a_SOURCES += src/defaults/default_poll.c
>  noinst_LIBRARIES += libimfs.a
>  libimfs_a_SOURCES =
> diff --git a/cpukit/libfs/src/defaults/default_poll.c b/cpukit/libfs/src/defaults/default_poll.c
> index 0000000..7540390
> --- /dev/null
> +++ b/cpukit/libfs/src/defaults/default_poll.c
> @@ -0,0 +1,37 @@
> + * @file
> + * @brief Default Poll Handler
> + * @ingroup LibIOFSHandler
> + * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#if HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <rtems/libio_.h>
> +#include <sys/poll.h>
> +  int events
> +  return POLLERR;
> diff --git a/cpukit/preinstall.am b/cpukit/preinstall.am
> index 315ab3e..bdcc359 100644
> --- a/cpukit/preinstall.am
> +++ b/cpukit/preinstall.am
> @@ -76,6 +76,10 @@ $(PROJECT_INCLUDE)/sys/ioctl.h: libcsupport/include/sys/ioctl.h $(PROJECT_INCLUD
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/ioctl.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/ioctl.h
> +$(PROJECT_INCLUDE)/sys/poll.h: libcsupport/include/sys/poll.h $(PROJECT_INCLUDE)/sys/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/poll.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/poll.h
>  $(PROJECT_INCLUDE)/sys/statvfs.h: libcsupport/include/sys/statvfs.h $(PROJECT_INCLUDE)/sys/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/statvfs.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/statvfs.h
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
