[PATCH 2/2] Shared MMU initialization for ARM BSPs and RaspberryPi MMU support
    Gedare Bloom
    gedare at rtems.org
    Thu Oct  3 12:56:35 UTC 2013
Thanks Alan.
Patch committed with the fix for the struct definition, and also I
reworded the commit message a little bit.
Please verify,
Gedare
On Wed, Oct 2, 2013 at 10:53 AM, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> It looks good to me. I updated my RTEMS git and tools, then I compiled and
> ran it on the raspberry Pi.
> The only thing that did not work:
> In the file arm-cp15-start.h, I had to move
> typedef struct {
>   uint32_t begin;
>   uint32_t end;
>   uint32_t flags;
> } arm_cp15_start_section_config;
> to be before
> extern const arm_cp15_start_section_config bsp_mm_config_table[];
> It did not compile if the bsp_mm_config_table declaration was first.
> Alan
> On 9/28/2013 12:07 PM, Gedare Bloom wrote:
>> Looks good on my end. Alan or Sebastian have any comments?
>> -Gedare
>> On Sat, Sep 28, 2013 at 4:08 AM, Hesham AL-Matary
>> <heshamelmatary at gmail.com> wrote:
>>> The newly added ORed flag: ARM_CP15_CTRL_XP is vital to get RaspberryPi
>>> MMU working properly and to share the container function between various
>>> ARM BSPs. The new ORed flags do not affect the current BSPs that make use
>>> of arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache
>>> function.
>>> The rest is of the patch targets MMU initialization for ARM
>>> architectures,
>>> desgined to be shared. Later patches make use of shared mminit
>>> implementation.
>>>   c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |  9 ++-
>>>   c/src/lib/libbsp/arm/raspberrypi/preinstall.am     |  8 +++
>>>   .../libbsp/arm/raspberrypi/startup/bspstarthooks.c | 22 +------
>>>   c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds  |  4 +-
>>>   .../arm/raspberrypi/startup/mm_config_table.c      | 70
>>>   .../lib/libbsp/arm/shared/include/arm-cp15-start.h | 15 +++--
>>>   c/src/lib/libbsp/arm/shared/mminit.c               | 24 ++++++++
>>>   c/src/lib/libbsp/shared/include/mm.h               | 25 ++++++++
>>>   8 files changed, 151 insertions(+), 26 deletions(-)
>>>   create mode 100644
>>> c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>>   create mode 100644 c/src/lib/libbsp/arm/shared/mminit.c
>>>   create mode 100644 c/src/lib/libbsp/shared/include/mm.h
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>> b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>> index 24d396c..a06979a 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>> @@ -27,6 +27,7 @@ nodist_include_HEADERS = ../../shared/include/coverhd.h
>>>   nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
>>> +include_bsp_HEADERS += ../../../libbsp/shared/include/mm.h
>>>   include_bsp_HEADERS += ../../shared/include/utility.h
>>>   include_bsp_HEADERS += ../../shared/include/irq-generic.h
>>>   include_bsp_HEADERS += ../../shared/include/irq-info.h
>>> @@ -35,6 +36,7 @@ include_bsp_HEADERS +=
>>> ../../shared/include/uart-output-char.h
>>>   include_bsp_HEADERS += ../../shared/tod.h
>>>   include_bsp_HEADERS += ../shared/include/linker-symbols.h
>>>   include_bsp_HEADERS += ../shared/include/start.h
>>> +include_bsp_HEADERS += ../shared/include/arm-cp15-start.h
>>>   include_bsp_HEADERS += ../shared/lpc/include/lpc-timer.h
>>>   include_bsp_HEADERS += ../shared/lpc/include/lpc-dma.h
>>>   include_bsp_HEADERS += include/irq.h
>>> @@ -83,7 +85,7 @@ libbsp_a_SOURCES += ../../shared/sbrk.c
>>>   libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>>>   libbsp_a_SOURCES += ../shared/abort/simple_abort.c
>>>   libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
>>> +libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
>>>   # Startup
>>>   libbsp_a_SOURCES += startup/bspreset.c
>>> @@ -91,6 +93,7 @@ libbsp_a_SOURCES += startup/bspstart.c
>>>   # IRQ
>>>   libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
>>> +libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
>>>   libbsp_a_SOURCES += ../../shared/src/irq-generic.c
>>>   libbsp_a_SOURCES += ../../shared/src/irq-info.c
>>>   libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
>>> @@ -127,6 +130,10 @@ libbsp_a_CPPFLAGS +=
>>> -I$(srcdir)/../../../libcpu/arm/shared/include
>>>   # Start hooks
>>>   libbsp_a_SOURCES += startup/bspstarthooks.c
>>> +# LIBMM
>>> +libbsp_a_SOURCES += startup/mm_config_table.c
>>> +libbsp_a_SOURCES += ../shared/mminit.c
>>>   # Network                                                    #
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>>> b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>>> index 056c5f1..a638e64 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>>> @@ -62,6 +62,10 @@ $(PROJECT_INCLUDE)/bsp/bootcard.h:
>>> ../../shared/include/bootcard.h $(PROJECT_INC
>>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
>>> +$(PROJECT_INCLUDE)/bsp/mm.h: ../../../libbsp/shared/include/mm.h
>>> $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mm.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mm.h
>>>   $(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h
>>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
>>> @@ -94,6 +98,10 @@ $(PROJECT_INCLUDE)/bsp/start.h:
>>> ../shared/include/start.h $(PROJECT_INCLUDE)/bsp
>>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/start.h
>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/start.h
>>> +$(PROJECT_INCLUDE)/bsp/arm-cp15-start.h:
>>> ../shared/include/arm-cp15-start.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h
>>>   $(PROJECT_INCLUDE)/bsp/lpc-timer.h: ../shared/lpc/include/lpc-timer.h
>>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lpc-timer.h
>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lpc-timer.h
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
>>> b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
>>> index a224168..71b2ff1 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
>>> @@ -7,6 +7,7 @@
>>> + * Copyright (c) 2013. Hesham AL-Matary
>>>    * Copyright (c) 2013 by Alan Cudmore
>>>    * based on work by:
>>>    * Copyright (c) 2009
>>> @@ -24,33 +25,16 @@
>>>   #include <bspopts.h>
>>>   #include <bsp/start.h>
>>>   #include <bsp/raspberrypi.h>
>>> -#include <bsp/mmu.h>
>>> -static void BSP_START_TEXT_SECTION raspberrypi_cache_setup(void)
>>> -  uint32_t ctrl = 0;
>>> -  /* Disable MMU and cache, basic settings */
>>> -  ctrl = arm_cp15_get_control();
>>> -  ctrl &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_R | ARM_CP15_CTRL_C
>>> -    | ARM_CP15_CTRL_V | ARM_CP15_CTRL_M);
>>> -  ctrl |= ARM_CP15_CTRL_S;
>>> -  arm_cp15_set_control(ctrl);
>>> -  arm_cp15_cache_invalidate();
>>> -  arm_cp15_tlb_invalidate();
>>> +#include <bsp/mm.h>
>>>   void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
>>> -  raspberrypi_cache_setup();
>>>   void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
>>>     bsp_start_copy_sections();
>>> +  bsp_memory_management_initialize();
>>>     bsp_start_clear_bss();
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
>>> b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
>>> index b9a0dd8..c12b348 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
>>> @@ -35,7 +35,8 @@
>>>   MEMORY {
>>>           VECTOR_RAM     (AIW) : ORIGIN = 0x0       , LENGTH = 0x8000
>>> -        RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M -
>>> 0x8000
>>> +        RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M - 48K
>>> +       RAM_MMU        (AIW) : ORIGIN = 128M - 16k, LENGTH = 16k
>>>   REGION_ALIAS ("REGION_START", RAM);
>>> @@ -58,5 +59,6 @@ bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ?
>>> bsp_stack_irq_size : 4096;
>>>   bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size
>>> : 1024;
>>>   bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ?
>>> bsp_section_robarrier_align : 1M;
>>> +bsp_translation_table_base = ORIGIN (RAM_MMU);
>>>   INCLUDE linkcmds.armv4
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> new file mode 100644
>>> index 0000000..fd85513
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> @@ -0,0 +1,70 @@
>>> + * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
>>> + *  embedded brains GmbH
>>> + *  Dornierstr. 4
>>> + *  82178 Puchheim
>>> + *  Germany
>>> + *  <info at embedded-brains.de>
>>> + * The license and distribution terms for this file may be
>>> + * found in the file LICENSE in this distribution or at
>>> + * http://www.rtems.com/license/LICENSE.
>>> +#include <bsp/start.h>
>>> +#include <bsp/arm-cp15-start.h>
>>> +#ifdef RTEMS_SMP
>>> +  #define MMU_DATA_READ_WRITE ARMV7_MMU_DATA_READ_WRITE_SHAREABLE
>>> +#else
>>> +  #define MMU_DATA_READ_WRITE ARMV7_MMU_DATA_READ_WRITE_CACHED
>>> +#endif
>>> +BSP_START_DATA_SECTION const arm_cp15_start_section_config
>>> +bsp_mm_config_table[] = {
>>> +    .begin = (uint32_t) bsp_section_fast_text_begin,
>>> +    .end = (uint32_t) bsp_section_fast_text_end,
>>> +    .flags = ARMV7_MMU_CODE_CACHED
>>> +    .begin = (uint32_t) bsp_section_fast_data_begin,
>>> +    .end = (uint32_t) bsp_section_fast_data_end,
>>> +    .flags = MMU_DATA_READ_WRITE
>>> +    .begin = (uint32_t) bsp_section_start_begin,
>>> +    .end = (uint32_t) bsp_section_start_end,
>>> +    .begin = (uint32_t) bsp_section_vector_begin,
>>> +    .end = (uint32_t) bsp_section_vector_end,
>>> +    .begin = (uint32_t) bsp_section_text_begin,
>>> +    .end = (uint32_t) bsp_section_text_end,
>>> +    .begin = (uint32_t) bsp_section_rodata_begin,
>>> +    .end = (uint32_t) bsp_section_rodata_end,
>>> +    .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
>>> +    .begin = (uint32_t) bsp_section_data_begin,
>>> +    .end = (uint32_t) bsp_section_data_end,
>>> +    .begin = (uint32_t) bsp_section_bss_begin,
>>> +    .end = (uint32_t) bsp_section_bss_end,
>>> +    .begin = (uint32_t) bsp_section_work_begin,
>>> +    .end = (uint32_t) bsp_section_work_end,
>>> +    .begin = (uint32_t) bsp_section_stack_begin,
>>> +    .end = (uint32_t) bsp_section_stack_end,
>>> +BSP_START_DATA_SECTION const size_t bsp_mm_config_table_size =
>>> +RTEMS_ARRAY_SIZE(&bsp_mm_config_table);
>>> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>>> b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>>> index 01f3104..6a2598b 100644
>>> --- a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>>> +++ b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>>> @@ -1,4 +1,5 @@
>>> + * Copyright (c) 2013 Hesham AL-Matary.
>>>    * Copyright (c) 2009-2013 embedded brains GmbH.  All rights reserved.
>>> @@ -16,13 +17,15 @@
>>>   #define LIBBSP_ARM_SHARED_ARM_CP15_START_H
>>>   #include <libcpu/arm-cp15.h>
>>>   #ifdef __cplusplus
>>>   extern "C" {
>>>   #endif /* __cplusplus */
>>> +extern const arm_cp15_start_section_config bsp_mm_config_table[];
>>> +extern const size_t bsp_mm_config_table_size;
>>>   BSP_START_TEXT_SECTION static inline void
>>>   arm_cp15_set_domain_access_control(uint32_t val);
>>> @@ -87,9 +90,9 @@
>>> arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>>>     arm_cp15_set_domain_access_control(dac);
>>>     arm_cp15_set_translation_table_base(ttb);
>>> -  /* Initialize translation table with invalid entries */
>>> +  /* Initialize translation table with fixed-map read-write entries */
>>>     for (i = 0; i < ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT; ++i) {
>>> -    ttb [i] = 0;
>>> +    ttb [i] = (i << ARM_MMU_SECT_BASE_SHIFT) |
>>> ARMV7_MMU_DATA_READ_WRITE;
>>>     for (i = 0; i < config_count; ++i) {
>>> @@ -97,7 +100,9 @@
>>>     /* Enable MMU and cache */
>>> -  ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
>>> +  ctrl |= ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_S | ARM_CP15_CTRL_I |
>>> +          ARM_CP15_CTRL_C | ARM_CP15_CTRL_M  | ARM_CP15_CTRL_XP;
>>> diff --git a/c/src/lib/libbsp/arm/shared/mminit.c
>>> b/c/src/lib/libbsp/arm/shared/mminit.c
>>> index 0000000..0ea9805
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/arm/shared/mminit.c
>>> @@ -0,0 +1,24 @@
>>> +#include <bsp/linker-symbols.h>
>>> +BSP_START_TEXT_SECTION void bsp_memory_management_initialize(void)
>>> +  uint32_t ctrl = arm_cp15_get_control();
>>> +  arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>>> +    ctrl,
>>> +    (uint32_t *) bsp_translation_table_base,
>>> +    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
>>> +    &bsp_mm_config_table[0],
>>> +    bsp_mm_config_table_size
>>> diff --git a/c/src/lib/libbsp/shared/include/mm.h
>>> b/c/src/lib/libbsp/shared/include/mm.h
>>> index 0000000..1a1eb7f
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/shared/include/mm.h
>>> @@ -0,0 +1,25 @@
>>> + * Copyright (c) 2013 Gedare Bloom.
>>> +#ifndef __LIBBSP_MM_H
>>> +#define __LIBBSP_MM_H
>>> +#include <stdint.h>
>>> +#include <stdlib.h>
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#endif
>>> +void bsp_memory_management_initialize(void);
>>> +#ifdef __cplusplus
>>> +#endif
>>> +#endif
>>> 1.8.3.1
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
