[rtems commit] Shared MMU initialization for ARM BSPs and RaspberryPi MMU support
Hesham Moustafa
heshamelmatary at gmail.com
Fri Oct 4 09:07:15 UTC 2013
On Fri, Oct 4, 2013 at 9:50 AM, Sebastian Huber <
> On 2013-10-03 14:49, Gedare Bloom wrote:
>> @@ -87,9 +90,9 @@ arm_cp15_start_setup_**translation_table_and_enable_**
>> mmu_and_cache(
>> arm_cp15_set_domain_access_**control(dac);
>> arm_cp15_set_translation_**table_base(ttb);
>> - /* Initialize translation table with invalid entries */
>> + /* Initialize translation table with fixed-map read-write entries */
>> for (i = 0; i < ARM_MMU_TRANSLATION_TABLE_**ENTRY_COUNT; ++i) {
>> - ttb [i] = 0;
>> + ttb [i] = (i << ARM_MMU_SECT_BASE_SHIFT) | ARMV7_MMU_DATA_READ_WRITE;
> What is the reason for this change? I don't think that unconditional
> read-write access is a good idea.
> I made this change when I was trying to get RaspberryPi MMU initialization
to work. Also I thought
the default behavior for RTEMS is the unprotected mode, and the new
protection (limitation) attributes
are new and should be applied when needed (by configuration table at
startup or dynamically).
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20131004/92afcfcb/attachment-0001.html>
