[PATCH] Backport of development SPI SD-card patches to RTEMS 4.10.
Tue Oct 8 09:17:39 UTC 2013
Hello Pavel,
thanks.  I checked it in.
On 2013-10-08 10:53, Pavel Pisa wrote:
> Hello Sebastian,
> the patch is backport of the actual RTEMS GIT SD-card on SPI
> implementation to the RTEMS 4.10.x-git. The following
> RTEMS 4.10.99-git patch applies cleanly to the backport.
> [PATCH v2] SPI SD-Card: setup valid CRC-7 for STOP_TRANSMISSION command.
> The backport has been tested on MXS/CSB336 and we intend to use it
> in the production setup after regular full testing and I would
> provide feedback and fixes if there is some problem found.
> I left on your taste if this should go into official RTEMS 4.10.x
> Best wishes,
>                 Pavel
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
